vladap88 0 Posted April 17, 2016 Stavio sam neki koji sam dobio uz nju... trebalo bi da je ok jacina... Posto se nesto ne razumem u elektroniku, jel ima veze na koju stranu sam ga okrenuo? Quote Share this post Link to post Share on other sites
Axic 20048 Posted April 17, 2016 Cek, jel si stavio otpornik na pozitivan (+) pol ? Quote Share this post Link to post Share on other sites
vladap88 0 Posted April 17, 2016 (edited) Da, na pozitivan pol... Nego sam otpornik da li ga treba zalemiti na jednu ili drugu stranu, da li to ima neke veze... Edited April 17, 2016 by vladap88 Quote Share this post Link to post Share on other sites
Axic 20048 Posted April 18, 2016 Koliko se secam nije bitno. Quote Share this post Link to post Share on other sites
vladap88 0 Posted April 18, 2016 Ok, hvala, ne znam kako da utvrdim sta je problem i otkud air bag lampica u toj prici Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted April 18, 2016 Možda nešto oko mase i te priče? https://www.fiat-lancia.org.rs/forum/index.php?/topic/45033-fiat-punto-mk2-problem-sa-strujom/&do=findComment&comment=1291838 Quote Share this post Link to post Share on other sites
vladap88 0 Posted April 18, 2016 Ranije sam sve mase po autu pretresao i sredio... Ne verujem da je to Quote Share this post Link to post Share on other sites
Axic 20048 Posted April 18, 2016 On 4/18/2016 at 11:31 AM, vladap88 said: Ok, hvala, ne znam kako da utvrdim sta je problem i otkud air bag lampica u toj prici Sad nesto razmisljam i setio sam se da je i kod mene AIR bag lampica blinkala ali jedva da se primecivalo i to je trajalo svega 4-5 sekundi, posle toga prestane. Medjutim na fabrickom radio kasetofonu se od tada pocelo desavati da blinka lampica ispod tastera za paljenje/gasenje kasetofona. Posle nekog vremena sam skinuo diodu a verujem da je bio problem do jacine otpornika nego me je mrzelo da probam i trazim "problemcic". Evo na snimku mozes da vidis o cemu se radi... http://tinypic.com/player.php?v=nvuuxh&s=8#.VxVWoHqsjeU Quote Share this post Link to post Share on other sites
vladap88 0 Posted April 19, 2016 Aha, znaci dioda zbunjuje elektroniku... Imam i daljinsku centralnu bravu i po semi vidim da moze na nju da se nakaci dioda pa cu probati na taj nacin... I kod mene airbag lampica svetli malim intenzitetom i po malo blinka... Quote Share this post Link to post Share on other sites
Axic 20048 Posted April 19, 2016 Ajde bas probaj i slobodno postavi shemu i nacin povezivanja na centralnu ako budes uspeo da uradis. Quote Share this post Link to post Share on other sites
vladavuj 0 Posted April 25, 2016 pozdrav jel moze neko da mi kaze koji se otpornik stavlja na diodu -oznaka,ili nesto da znam koji da narucim? Quote Share this post Link to post Share on other sites
Axic 20048 Posted April 25, 2016 @vladavuj Mozes naruciti sa kupinda, uz diodu stize i otpornik. Od koliko oma je otpornik ne znam ali je verovatno dovoljan da dioda ne pregori.https://www.kupindo.com/LED-trake-i-sijalice/9486857_BLINK-DIODA-ZAMENA-ZA-ALARM Quote Share this post Link to post Share on other sites
Nennad 3 Posted April 26, 2016 Otpornik se bira na osnovu tri stvari: 1. Napon izvora 2. Napon diode koju ugradjujemo 3. Potrosnja struje diode koju ugradjujemo Ima puno kalkulatora po netu, ukucate ova tri parametra i sve se samo kaze http://led.linear1.org/1led.wiz Da dodam, posto se pominjalo negde unazad, nije vazno kako se okrece otpornik, vazno je samo da se stavi na plus pol diode, jer struja ide od pravca plusa ka minusu, pa kada bi se otpornik stavio na minus pol diode, onda on ne bi imao funkciju. Quote Share this post Link to post Share on other sites
djordjedisic 0 Posted August 11, 2018 Pozdrav Znam da je tema stara ali imam jedno pitanje. Povezao sam blink diodu i kao i nekima ovde i meni upali lampicu za airbag...da li neko zna kako ovo resiti? Predpostavljam da dioda vraca taj stalni plus na zicu na kojoj nema napajanje kada je kontak ugasen samim time dovede napajanje na tu drugu zicu koja nema napajanje kada je auto ugasen i samim time aktivira nesto od tih lampica u ovom slucaju airbag.... Quote Share this post Link to post Share on other sites
Axic 20048 Posted August 11, 2018 @djordjedisic možda staviti otpornik od više oma ali nisam siguran. Ja sam moju posle nekog vremena skinuo. Quote Share this post Link to post Share on other sites
djordjedisic 0 Posted August 11, 2018 2 minutes ago, Axic said: @djordjedisic možda staviti otpornik od više oma ali nisam siguran. Ja sam moju posle nekog vremena skinuo. hm..pa ja ne znam pokusavam da nadjem na net-u kako je neko resio ovo ali za sada nista. Jedostavno dioda propusta napon na drugu zicu sa koje dobija - i zato verovatno se te lampice i upale...moguce da ako dovedem manji napon na diodu da cu tada resiti problem... Quote Share this post Link to post Share on other sites
