Ticma 537 Posted December 3, 2012 Desava mi se da dok auto radi na gas-u pocne da se zalece od nekih 500 do 1000rpm i postalo je iritirajuce. Bio sam u servisu, menjani su filteri a sve drugo je prekontrolisano i ok je. Na benzinu je sve savrseno. Leptir ociscen, kablovi novi. Ja sumnjam na onaj MAP sto ide uz plinski uredjaj ali ne znam kako da ga proverim pa ako neko ima neku ideju . . . Quote Share this post Link to post Share on other sites
boki 10 Posted December 3, 2012 Meni to lici na step motor... Quote Share this post Link to post Share on other sites
Mijailović P. 3451 Posted December 3, 2012 +1 Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 Pa step bi ga zaletao i na benzinu valjda? Quote Share this post Link to post Share on other sites
Gusar 4 Posted December 3, 2012 nije step da je step kavao bi ga i na benzinu... Quote Share this post Link to post Share on other sites
boki 10 Posted December 3, 2012 nisam ni video da si napisao da auto radi na benzinu ok,pa onda je nesto do plina nema sta idi negde neka ti provere..ja znam da bi ti voleo da to resis sam ali tesko... Quote Share this post Link to post Share on other sites
Gusar 4 Posted December 3, 2012 probaj da raskacis plinski maf da vidis sta ce da bude.... Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 (edited) Bio sam danas u servisu, nakacili su komp i sve ok. Ici cu u sredu u drugi da pokusaju nesto i glavom da urade umesto sto odmah uzmu lap top i blenu u ekran . . .Gusare, ovde na NBG toliko brije vetar da mi se ni gepek ne otvara a kamoli hauba Edited December 3, 2012 by Ticma Quote Share this post Link to post Share on other sites
boki 10 Posted December 3, 2012 nemoj ni slucajno da ides u servis,ja verujem da bi ti to mogao da resis sam... sad ozbiljnoako ti auto radi na benzinu ok nema sta da trazis po servisima idi kod plinadzije... Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 Na plinski servis sam i mislio Ma samo da je malo toplije rasturio bi ga na komade al jbg Quote Share this post Link to post Share on other sites
Mijailović P. 3451 Posted December 3, 2012 Naspricaj malo Sprej za ciscenje klapne pa ako to ne pomogne svecice , kablovi itd. Negde si pominjao da si menjao nesto od toga ali sam najbolje znas... Inace , sve ovo na plinu mora besprekorno da radi inace ...problemi.Na benzinu se manje osete ovi nedostatci. Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 Ociscen komplet usis carb klinerom, kablovi novi, bombine proveravane na osciloskopu, ma sve je ok. Ovo zaletanje je tipa kao da mu ja dajem i oduzimam gas, nije ono cimkanje. Ja sumnjam samo na taj map/maf od plina ali aj videcu jos sutra. Ne desava se stalno, danas je pocelo kad sam ga opleo trecom do 110-120 a nekad pocne cim ga upalim . . . Quote Share this post Link to post Share on other sites
Mijailović P. 3451 Posted December 3, 2012 Plinska dijagnostika mora da pokaze neispravnost uredjaja. Mozda je poceo da vuce fals vazduh ?! Quote Share this post Link to post Share on other sites
Martini 11 Posted December 3, 2012 Pa neka koriguju gasnu mapu u problematicnom podrucju. Bar to nije problem. Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 (edited) Moguce ali ne znam gde, jedino na nekom crevcetu posto je ceo sklop sa leptirom predihtovan diht masom od strane mene tako da tu nema sanse da vuce, usis je skidan i lepo je vracen i sve je stavljeno novo sto se moglo naci. Vrednosti motornog map-a su ok.Moguce da je mapa losa, nije mi palo na pamet, hvala Edited December 3, 2012 by Ticma Quote Share this post Link to post Share on other sites
kicerica 5 Posted December 3, 2012 Vidi ti ko je to pozeleneo. Quote Share this post Link to post Share on other sites
kicerica 5 Posted December 3, 2012 Dobro je samo da nije od izduvne grane. Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 3, 2012 Od toga se crveni. Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 4, 2012 Evo danas sve naj normalnije . . . Quote Share this post Link to post Share on other sites
Gusar 4 Posted December 4, 2012 ma bilo mu zima juce... pa nije znao kako da ti kaze... Quote Share this post Link to post Share on other sites
Ticma 537 Posted December 4, 2012 Idem sutra na stelovanje u svakom slucaju pa nek kuka onda! Dosta prelazim pa pop..dim kad nesto ne radi kako treba! Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted January 30, 2013 I sta bi na kraju sa celom mukom? I ja imam isti problem na istom motoru. Ima skoro 4000km od ugradnje Landi uredjaja. Quote Share this post Link to post Share on other sites
Ticma 537 Posted January 30, 2013 Zaboravih da napisem trebalo je samo prestelovati uredjaj, nije imao dovoljno goriva tj gasa na tom rezimu rada pa je bilo potrebno korigovati mapu na odredjenim mestima. Za onoga ko zna sta treba da se uradi je to posao od 5-10 min max Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted January 30, 2013 Ee, dobro da je resenje lako. Dok je tako blesavio, da li ti se culo iz motora kao da da je dizel. od 1000 do 2000 obrtaja dok radi na plinu? Na benzinu radi kao sat. Quote Share this post Link to post Share on other sites
