ivan.ik 625 Posted September 4, 2012 @ lomisaOsnovu sam ti izračunao pa ti dalje možeš sam. Namerno sam stavio fabričke gume ,(možda će nekom još trebati a vozi na fabričkim) a ti za tvoje dodaj 1,5 %.Tablica je za nove gume, brzinomer (inače svi lažu) uporedi sa navigacijom. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 15, 2012 (edited) Fiat Stilo 1.9 JTD 80/100 KS 3v, 5v i MW80/100 ks pri 4000 o/min196 Nm/1500 o/min 200 Mn pri 2000 o/min1. 3,909............................. 38.9 km/h2. 2.238..............................68.0 km/h3. 1.520............................100.2 km/h4. 1.156............................131.7 km/h5. 0.919............................165.7 km/hR. 3.909..............................38.9 km/hDif .............................................3.053max 171 km/h pri................4128 o/min120 km/h.............................2897 o/min130 km/h.............................3138 o/min150 km/h.............................3621 o/minPneu 195/65 R15 O=1.937 m Edited October 15, 2012 by ivan.ik Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 23, 2012 Mercedes Benz 190 E 1.8 prenosni odnosi brzina pri 6000 o/min pri 4000 o/min pri 2500 o/min1. 3.910:1 50.4 km/h 33.6 km/h 21,0 km/h 2. 2.170:1 90.8 km/h 60.5 km/h 37.8 km/h3. 1.370:1 143.8 km/h 95.7 km/h 59.9 km/h4. 1.000:1 197.0 km/h 131.3 km/h 82.0 km/h5. 0.810:1 243.3 km/h 162.2 km/h 101.3 km/h R 4.270:1 46.1 km/h Dif 3.460:1 120 km/h V 2959 o/min 130 km/h V 3206 o/min 150 km/h V 3700 o/min 0-100 km/h- 12.3 smax 185 km/h pri 4562 o/minpneu 185/65 R 15 O=1.894 mpotrošnja 90 km/h-6.7 l 120 km/h-8.7 l grad -11.3 l težina 1150 kg nosivost 500 kg nosivost krova 100kgmotor1797 ccmprečnik x hod klipa- 89.0 x 72.2 mmkompresija 9.1:1snaga 80kW (109 KS) pri 5500 o/minobrtni momenat 150 Nm pri 3700 o/min Quote Share this post Link to post Share on other sites
Red Dragon 1 Posted October 24, 2012 Lybra 1.8, 131ks100km/h --- 3000 o/min120km/h --- 3600 o/min140km/h --- 4250 o/mn160km/h --- 4750 o/mingume 195/65 r15Da li je ovo normalno ili kliza malo lamela Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 24, 2012 Lancia Lybra 1.8 131 KS/6300 o/min 164 Nm/3800 o/minprenosni odnosi..........brzina pri 4000............przina pri 6000 o/min1. 3,909.........................31,88 km/h......................47,82 km/h2. 2,238.........................55,68 km/h......................83,52 km/h3. 1,520.........................81,99 km/h......................122,9 km/h4. 1,156........................107,81 km/h.....................161,7 km/h5. 0,970........................128,48 km/h.....................192,7 km/hR 3,910..........................31,87 km/h.....................47,80 km/hDif 3,730max 201 km/h pri 6257 o/min120 km/h V pri 3735 o/min130 km/h V pri 4047 o/min140 km/h V pri 4358 o/min150 km/h V pri 4669 o/min160 km/h V pri 4981 o/min Quote Share this post Link to post Share on other sites
Red Dragon 1 Posted October 24, 2012 hvala na tabeli, izgleda da je to to najbrže što sam vozio to je bilo 180km/h ali nisam obraćao pažnju na obrtomer. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 24, 2012 (edited) Nema potrebe da se opterećuješ, odstupanje imaš zbog brzinomera.I ima nešto kraći diferencijal tj menjač jer 120 u V bruju na 3735 o/min mogli su bar za 300 (imaju slabija kola-ispod 100 ks) ili 500 obtraja (preko 1,8 i 100 ks). Rasteretio bi motor.Uporedi sa 190-ticom. Lakši auto, slabiji motor i puno duži prenos i kotrlja se. (isti prenos i 190 E 2.0) Edited October 24, 2012 by ivan.ik Quote Share this post Link to post Share on other sites
Red Dragon 1 Posted October 25, 2012 Istina, mnogo lepše zvuči motor na 140km/h nego na 120km/h. Ne opterećujem se uopšte, pošto sam pre ovoga imao z101 pa na 130 u 4. brzini poleće Inače mogao je da razvije 150km/h i to bez muke Quote Share this post Link to post Share on other sites
sonem 0 Posted December 12, 2012 (edited) Kod mene lancia Kappa 2.4 JTD na 3000 obrtaj ide 140 dok sam na you tube gledao snimke gde ista lanca sa istim motorom na istim obrtajima motora ide 160! Da li mi neko moze objasniti kako to? Edited December 12, 2012 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
Martini 11 Posted December 12, 2012 Daj snimak pa da vidimo. I moja je isla na 3000rpm 140. Quote Share this post Link to post Share on other sites
sonem 0 Posted December 12, 2012 Evo snimak 160 ide malo preko 3000 obrtaja..Martine koja je kod tebe maksimalna brzina kod mene je 190 na 4000 obrtaja da napomenem da auto ide super od kad sam ga kupi ali preko 190 nece!? Quote Share this post Link to post Share on other sites
Lancist 0 Posted March 20, 2013 Ja sam moju lx turbo sw fotografisao u voznji i recimo 120 u V brzini je na 2200 obrtaja, 3400 obrtaja na auto putu je 180 kmh. Odgovor je da kappe imaju izuzetno veliki obrtni momenat, posebno turbo i 16 i 20V od 300Nm na 2750 obrtaja, pa nije cudno sto je ekonomicno voziti ih brzo, a u stvari na malim obrtajima i relativno ekonomicno. Quote Share this post Link to post Share on other sites
Dr cosworth 5 Posted March 20, 2013 Kod mene lancia Kappa 2.4 JTD na 3000 obrtaj ide 140 dok sam na you tube gledao snimke gde ista lanca sa istim motorom na istim obrtajima motora ide 160! Da li mi neko moze objasniti kako to?Kraci prenos to jest manji ili ti nizi tockovi pa pokazuje vise km Quote Share this post Link to post Share on other sites
diskusija 9 Posted April 15, 2013 ivane bas studiozno. svaka cast!!! Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted April 15, 2013 Videći malo kasnije da napravim sa GP 75 ks, 90 ks 1.6 i za 1,9 to bi bilo dobro upoređivanje. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted April 15, 2013 (edited) Grande Punto 1.3 MJ75 KS/4000 o/min190 Nm/1750 o/minprenosni odnosi..........................brzina pri 4000 o/min1. 3,909:1.............................................32.02 km/h2. 2.238:1.............................................55.93 km/h3. 1.444:1.............................................88.70 km/h4. 1.029:1............................................121.66 km/h5. 0.767:1............................................163.22 km/hR 3.909:1..............................................32.02 km/hDiferencijal..................................................3.560:1Gume175/65 R15...........................................O=1.857 m120 km/h V............................................2940 o/min130 km/h V............................................3186 o/min150 km/h V............................................3676 o/minmax..............170 km/h...........................4166 o/min0-100 km/h...................................................13.6 s0160 km/h.....................................................77.7 snorma....................................................6.2/3.5/4.5masa...................................................1105/1665 kgGrande Punto 1.3 MJ90 KS/4000 o/min200 Nm/1750 o/minprenosni odnosi..........................brzina pri 4000 o/min1. 3.818:1...............................................32.0 km/h2. 2.053:1...............................................59.5 km/h3. 1.302:1...............................................93.9 km/h4. 0.959:1.............................................127.4 km/h5. 0.744:1.............................................164.2 km/h6. 0.614:1.............................................199.0 km/hR 3.545:1................................................34.5 km/hDiferencijal.................................................3.720:1Gume185/65 R15..........................................O=1.894 m120 km/h V/VI..............................2922/2412 o/min130 km/h V/VI..............................3166/2613 o/min150 km/h V/VI..............................3653/3015 o/minmax.......175 km/h.......V/VI...........4262/3517 o/min0-100 km/h...................................................11.9 s0-160 km/h...................................................47.4 snorma....................................................5.9/3.7/4.5masa..................................................1130/1690 kgGrande Punto 1.6 MJ120 KS/3750 o/min320 Nm/1750 o/minprenosni odnosi......................brzina pri 4000 o/min1. 3.818:1...............................................32.6 km/h2. 2.158:1...............................................57.7 km/h3. 1.300:1...............................................95.8 km/h4. 0.959:1.............................................129.9 km/h5. 0.744:1.............................................167.4 km/h6. 0.614:1.............................................202.9 km/hR 3.545:1...............................................35.1 km/hDiferencijal.................................................3.650:1Gume185/65 R15..........................................O=1.894 m120 km/h V/VI..............................2867/2366 o/min130 km/h V/VI..............................3106/2564 o/min150 km/h V/VI..............................3584/2958 o/minmax.......190 km/h........V/VI..........4540/3747 o/min0-100 km/h.....................................................9.6 s0-160 km/h...................................................28.4 snorma...................................................5.9/4.1/4.8masa..................................................1190/1750 kgGrande Punto 1.9 MJ120 KS/4000 o/min280 Nm/2000 o/minprenosni odnosi..........................brzina pri 4000 o/min1. 3.818:1...............................................35.5 km/h2. 2.053:1...............................................66.1 km/h3. 1.302:1.............................................104.2 km/h4. 0.959:1.............................................141.5 km/h5. 0.744:1.............................................182.4 km/h6. 0.614:1.............................................221.0 km/hR 3.545:1...............................................38.3 km/hDiferencijal.................................................3.350:1Gume185/65 R15..........................................O=1.894 m120 km/h V/VI..............................2632/2172 o/min130 km/h V/VI..............................2851/2353 o/min150 km/h V/VI..............................3290/2715 o/minmax.........190 km/h.......V/VI.........4167/3439 o/min0-100 km/h...................................................10.0 s0-160 km/h...................................................29.1 snorma...................................................7.5/4.5/5.6masa..................................................1205/1765 kg Edited April 15, 2013 by ivan.ik Quote Share this post Link to post Share on other sites
diskusija 9 Posted April 16, 2013 ivan ik je LIK )))IVANE a jel bi moglo malo pojasnjenje ovog tvog izlaganja??? Quote Share this post Link to post Share on other sites
igor0511 2882 Posted April 16, 2013 Na nekih 1750 obrtaja koliko sam video sa grafika tvoj Punto ima max obrtni moment, tj najbolje počupa, ali najviše trpi i kvačilo. Oblast visokog obrtnog momenta ti je do nekih 2500 obrtaja, mada se i dalje drži prilično visoko. Na tih 1750 obrtaja imaš ~33kW na raspolaganju,a najveća snaga ti je na 4000 obrtaja i iznosi 55kW, mada se i do 4500 fino drži Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted April 16, 2013 Ivane ajde okaci za stllo 1.2 16v 3v ,redak je automobil pa nema tih podataka.Please @igor0511 zasto najvise trpi kvacilo na 1750 rpm?Zar ne trpi najvise na najvisim obrtajima? Quote Share this post Link to post Share on other sites
igor0511 2882 Posted April 16, 2013 Kvačilo trpi najviše tamo gde je najveći obrtni moment. Vidi na grafiku kako ide obrtni sa obrtajima, na max obrtajima je jednak obrtnom na 1000 obrtaja tako da nema nekog optrećenja po kvačilo Inače, pisao je Dovla čini mi se da njegov Bravo 1.6mjet pali kvačilo ako se ide uzbrdo u regionu max obrtnog momenta pa je potrebno prešaltati u brzinu niže da se ne muči. Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted April 16, 2013 E ovo nisam znao Ispade da je bolje po kvacilo da se vozi u vecim obrtajima Ali to steti nekim drugim stvarima pa se zbog toga preporucuje voznja u zoni max obrtnog momenta.A kvacilo je i onako potrosni materijal Quote Share this post Link to post Share on other sites
igor0511 2882 Posted April 16, 2013 (edited) Nisam baš dobro napisao, ovo se samo odnosi samo da nabiješ gas na maksimalnom obrtnom momentu,tj za ovog Punta da ga vozih na 1800 obrtaja i nabodeš pun gas, kažu ljudi da zamensko Valeo kvačilo zasmrdi posle 10ak takvih radnji A kolima čak i prija da ih voziš u toj oblasti. Npr ja uvek auto vozim u regionu 1800-2200 obrtaja. Edited April 16, 2013 by igor0511 Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted April 16, 2013 Ako je ispravna korpa teško da će kvačilo da ikada zasmrdi. Kvačilo zasmrdi kada ga maltretiraš sa punim gasom i lagano puštaš da krene i sl. egzebicije.Ja sam mog non-stop patosirao i nikad nije ni bilo blizu da zasmrdi. Lagano krećem bez gasa, jedino ako je veći uspon malo ga dodam i gledam da kvačilo što pre spoji (što manje proklizavanja). Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted April 16, 2013 (edited) Fiat Stilo 1.2 16 V 6 speed Active 3V80 KS pri 5000 o/min114 Nm pri 4000 o/minprenosni odnosi........................brzina pri 4000.........................brzina pri 6000 o/min1. 3.909:1..................................29.2 km/h.........................................43.8 km/h2. 2.158:1..................................52.8 km/h.........................................79.3 km/h3. 1.480:1..................................77.1 km/h.......................................115.7 km/h4. 1.121:1................................101.9 km/h.......................................152.8 km/h5. 0.897:1................................127.3 km/h.......................................191.0 km/h6. 0.765:1................................149.3 km/h.......................................223.9 km/hR 3.818:1..................................29.9 km/h.........................................44.8 km/hDiferencijal 4.070:1Gume195/65 R15.......................................................................................O=1.937 m120 km/h V/VI...........................................................................3769/3214 o/min130 km/h V/VI...........................................................................4083/3482 o/min150 km/h V/VI...........................................................................4712/4018 o/minmax 172 km/h V/VI......................................................................5403/4608 o/min0-100 km/h................................................................................................13.4 s0-160 km/h.................................................................................................60.8 snorma.................................................................................................7.9/5.3/6.3masa................................................................................................1090/1600 kgZna li neko da odradi ovakav dijagram menjača na kompu, bilo bi od koristi svima Ove tablice (podaci) su generalno zbog izrade ovakvih dijagrama. Tu po vertikali označiš obrtaje gde motor postiže max. obrtni momenat i max. snagu, malo proučavaš i pohvataš u kojem bi području motor trebalo držati (naročito korisno za vozila bez obrtaljke). Lepo je znati i neke teoretske (nizbrdo) maximume. Edited April 16, 2013 by ivan.ik Quote Share this post Link to post Share on other sites
