borat 4 Posted July 18, 2022 (edited) Pozdrav drustvo da li neko zna koji je precnik prednjih zvucnika kod crome mrzi me da skidam tapacirung da izmerim. Edited July 18, 2022 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 18, 2022 @borat General specifications of hi-fi sound system The system is composed of 8 speakers and a sub woofer box containing a five channel power amplifier. The main features of the components are as follows: - 165 mm diameter, 40W mid woofer speakers, located in the lower part of the front doors, designed for the improved reproduction of medium-low frequencies. Water resistant technology has be used for these components too. - Tweeter speakers, 40W, located in the exterior rear view mirror triangles, designed for the reproduction of high frequencies. - 165 mm diameter, 40W mid woofer speakers, located in the lower part of the rear doors, designed for the improved reproduction of medium-low frequencies. Water resistant technology has be used for these components too. - Tweeter speakers, 40W, located in the top part of the rear doors, designed for the reproduction of high frequencies. - Bass-reflex type sub woofer box, 12 litre volume, containing a speaker 165 mm in diameter, 100W, for the reproduction of low frequencies. This box is located in the boot, on the side of the right wheel arch. The five channel audio power amplifier is located inside the sub woofer box for the operation of the actual sub woofer. Sve to odavde. Usput: On 9/19/2014 at 8:40 PM, zeljkoci said: skida se ceo tapacirung i zvučnici su nitovani. Moraš polomititi nitne. Ovde. Quote Share this post Link to post Share on other sites
borat 4 Posted July 18, 2022 To znam to sam video kad sam menjao sajlu podizaca ,razbusicu pa cu stegnuti srafovima isto sam to morao onda.Hvala jos jednom. Quote Share this post Link to post Share on other sites
