kolega.jankovic 23 Posted January 11, 2015 Led diode - sijalice 3528 novo upakovano u blisterHladno bela 11 din komadCrvena 13din komadPlava 13din komad Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 19, 2015 Ajmo ima jos dioda Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted January 19, 2015 Ja sam zainteresovan i ovde se teže nabavljaju ali ne bih sve radio. Recimo deo podeoka do crvenog polja na obrtaljci, par oko radioNa i slično. Sve to ipak kad se prolepša vreme. Ako imaš neku ideju imaš pravo da sugerišeš! Da, benzinac je. Nije Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 19, 2015 Moze sve, tu sam da pomognem, posavetujem..... nema veze sto je benzinac Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 29, 2015 (edited) Aktuelne diode Edited January 29, 2015 by kolega.jankovic Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted January 29, 2015 Ja pitah za ideju a ti ništa. Ae, spakuj neku kombinaciju pa mi pošalješ. Nešto nemam volje a i ovaj virus me rovari. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 29, 2015 Danas sam poslao coveku kombinaciju - od svake po 50 Znas kako, meni je i dalje plava najefektnija. Da kombinujes dve....sta znam. Mozda tablu u belo a ostalo u crveno? Da bude blizu fabrickog a ipak ne?Kad je sve belo nekako je anemicno posebno deo oko radia i ventilacije. Ako bas hoces da se zezas mozes skale na tabli u belo, displej crveno, radio u crveno, meni dugmici u crveno a podizaci u belo. Ali samo podizaci. Komande zakljucavanja i retrovizora isto u crveno. Mozes i na meni tasterima ona tri donja samo (maglenke i "P") u belo. Radi fore. Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted January 29, 2015 Dobro. Moram da prebrojim koliko kojih i gde pa javljam. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 29, 2015 Ako treba pomoc - koliko kojih gde ide - javi, pitaj.... Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted January 29, 2015 Ti mene zahembavaš. Koliko dioda ide u tablu a koliko u trandžu? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 29, 2015 AaaammmmU tabli imas:-na velikim skalama po 3 diode-na malim (gorivo-temp) po 1 dioda-svaka kazaljka po 1 dioda-displej 3 diodeCd plejer ima- 14dioda za displej- 2diode za krug oko tockica za pojacavanje- svako dugme ima po jednu dioduA ima ako se ne varam 17diodaTj dugmicaPodizaci:- desni i zadnji po jednu diodu - ukupno 3- kod vozaca imas ukupno 2 za retrovizor, po jedna za svaki podizac (znaci 2 ili 4), imas jednu za zakljucavanje zadnjih podizaca, i imas jos jednu za zakljucavanje auta.Meni tasteri - svaki taster po jedna...valjda ima 10kom Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted March 21, 2015 Aktuelno Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 4, 2016 Imam jos nesto ovih dioda pa ako kome treba... Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 4, 2016 E jbg, ja i zaboravio... Ae pošalji pedesetak komaTa kojekakvih da se sigram. Valjda će biti dovoljno?! Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 4, 2016 Moze sve, samo kazi sta te interesuje od boja? Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 4, 2016 Pa više sam za crvenu i belu. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 4, 2016 Ok. Saljem u ponedeljak po 25kom pa ih ti organizuj....na-te-na-ne Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 4, 2016 Živ bio... Svaka ti dala... Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted June 9, 2016 kolega jel imas jos ovih diodica na stanju? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 9, 2016 Kazi koliko kojih, provericu. Ima svih, e sad koliko.... Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted June 9, 2016 120 hladno belih, jos ako bi imao svetlo plave.. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 9, 2016 Svetlo plave nemam, bele imam ali moram da proverim koliko. Javljam Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted June 9, 2016 Ima 120belih nije problem Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 20, 2016 Imam jos dioda, bele/plave/crvene Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted September 20, 2016 kolega, ubacene diodice Quote Share this post Link to post Share on other sites
