mudri 63 Posted October 28, 2014 (edited) Izgleda da je poceo da me zeza termostat na punticu, dugo mu treba da se zagreje ili se uopste ne zagreje do normalne temperature. Jutros sam presao preko 100km, auto put vecinom, 120-160km/h termeratura na 25% skale. Koja je cena termostata i sta bi jos moglo da bude problem? Edited October 28, 2014 by mudri Quote Share this post Link to post Share on other sites
Branko 23 1 Posted October 28, 2014 Nije ti to ni skupo ni strasno,sam uradis Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted October 28, 2014 Termostat vernetov je oko 1100-1200 dinara i uzmes jos 2l antifriza i isto toliko vode destilovane i sam zamenis, nista tesko niti strasno Quote Share this post Link to post Share on other sites
toma ks 19 Posted October 28, 2014 Ja sam kod mene menjao.Imas da odvijes dva srafa i isto toliko da zavijes heheh Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted October 28, 2014 Nisu li 4?! Dva za creva dva za termostat Quote Share this post Link to post Share on other sites
mudri 63 Posted November 27, 2014 Kako da znam da limoj punto ima ABS? Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted November 27, 2014 Zaleti se malo nabodi na koncinu i ako imas osecaj da ce se auto raspasti onda imas :-D ili otvori haubu i iza akumolatora bi trebao da imas nesto cetvrtasto iz kojeg izlaze cetiri crevca. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted November 27, 2014 Otvori haubu, ABS izgleda ovako Quote Share this post Link to post Share on other sites
mudri 63 Posted November 28, 2014 Hvala momci. Quote Share this post Link to post Share on other sites
Stilisa 313 Posted November 28, 2014 U Rile al si ga posavetovao. :D Dobro je kad nije pitao za esp. Je l' i kod punta vazi kao kod Stila -sta sija na tabli kad se da kontakt, to ima? I kolega, imas li abs na kraju? Quote Share this post Link to post Share on other sites
mudri 63 Posted December 19, 2014 Ima ima, ovih dana se palio non stop, celave mi bile gume. Danas kupio 2 nove Wintere. 8000 din sa sve montazom i balansiranjem. Quote Share this post Link to post Share on other sites
mudri 63 Posted February 4, 2015 Danas zamenio zadnje amortizere i drzac motora. Sad je punto u savrsenom stanju Quote Share this post Link to post Share on other sites
mudri 63 Posted February 27, 2015 Danas sam pocastio punta novim USB playerom. Quote Share this post Link to post Share on other sites
Stilisa 313 Posted February 27, 2015 Sad odvrni muziku pa kroz glavnu gore-dole. Nego, je l' ti prekida HIT fm po gradu? Kao da secne pesma na trenutak? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted February 27, 2015 To ti je do Visteona Quote Share this post Link to post Share on other sites
Stilisa 313 Posted February 27, 2015 Pa kako samo bas na HIT fm-u? To nije istina. Quote Share this post Link to post Share on other sites
paun 1 Posted February 27, 2015 (edited) Pa ti slusaj TDI,tamo nista ne prekida. Kolega odlican puntic,nemoj da te brine potrosnja.Svrati neki put na skup u Kg,znaju momci iz Ar kada se okupljamo. Edited February 27, 2015 by Paun Quote Share this post Link to post Share on other sites
Stilisa 313 Posted February 27, 2015 A ne moze kod nas da se uhvati TDI. Punto super, samo nikako da ga nahvatam u gradu negde, ima dosta slicnih...jedino da jurim ovu BG registraciju, ako je i dalje ona. Naravno ako je kolega raspolozen za povremeno druzenje u KG samo neka kaze, lako cemo se iskombinovati. A i po gradu kad se skupljamo moze da navrati, da nas bude celih cetvoro-petoro. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted February 28, 2015 Cuti,ako su Nislije do skoro mogli da imaju dva ipo auta na okupljanjima, mozemo i mi celih 4 - 5 automobila da iskrpimo. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted February 28, 2015 Ma nema opasni ste vi Quote Share this post Link to post Share on other sites
mudri 63 Posted March 4, 2015 Sad odvrni muziku pa kroz glavnu gore-dole. Nego, je l' ti prekida HIT fm po gradu? Kao da secne pesma na trenutak?Nisam primetio, mada retko slusam radio. A ne moze kod nas da se uhvati TDI. Punto super, samo nikako da ga nahvatam u gradu negde, ima dosta slicnih...jedino da jurim ovu BG registraciju, ako je i dalje ona. Naravno ako je kolega raspolozen za povremeno druzenje u KG samo neka kaze, lako cemo se iskombinovati. A i po gradu kad se skupljamo moze da navrati, da nas bude celih cetvoro-petoro. Nije vise BG, sad je AR. Ima samo 2 siva sportinga u gradu, Jedan sa kukom i 15" felnama i moj. Dogovoricemo za skup, da se jos malo prolepsa vreme pa mozemo neki rostilj da organizujemo. Kolega odlican puntic,nemoj da te brine potrosnja.Hvala. Imam sekvent plin, potrosnja je smesna. A auto ide skoz fino. Quote Share this post Link to post Share on other sites
Stilisa 313 Posted March 5, 2015 Ma moze sve aaaa. Vidjao sam tog sa kukom, verovatno i tvoj samo nisam znao da si ti. (veliki grad) U medjuvremenu ako vidis sivi Stilo AR-022-BA ti blicni, radi nesto bilo sta samo nemoj da mi uleces u traku. Pre ces mozda sresti teget Maxi taxi Lybru, on je ne gasi, njemu isto sve kao meni + mozes i direktno na njega. Poz Quote Share this post Link to post Share on other sites
Sedla 2576 Posted March 5, 2015 Aleksa bre!!! Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted March 5, 2015 Znaci moz vam ga svirne kako ste vi dobrodusni Quote Share this post Link to post Share on other sites
mudri 63 Posted March 14, 2015 Sinoc kad sam se vracao iz Kg-a izleti mi zec, sjebe mi branik i hladnjak. Smorio sam se totalno, sta mislite da jurim polovan hladnjak ili da krpim ovaj? Quote Share this post Link to post Share on other sites
