bane17 24 Posted November 18, 2015 plasticne? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted November 18, 2015 (edited) Potraži ovde http://www.kupujemprodajem.com/Styling-i-tuning-1251-611-1-grupa.htm?action=list&return_url=QXV0b21vYmlsaS1PcHJlbWEtMTI1MS1rYXRlZ29yaWphLmh0bQ%3D%3D&data%5Bpage%5D=1&data%5Bad_kind%5D=goods&data%5Bad_type%5D=&data%5Bad_kind_type%5D=&data%5Btip_oglasa%5D=&data%5Bcategory_id%5D=1251&data%5Bgroup_id%5D=611&data%5Blocation_id%5D=&data%5Blocation_radius%5D=&data%5Bhas_photo%5D=&data%5Bcondition%5D=&data%5Bperiod%5D=&data%5Border%5D=posted+desc&data%5Bcar_model%5D=&data%5Bvehicle_power_min%5D=&data%5Bvehicle_power_max%5D=&data%5Bvehicle_cc_min%5D=&data%5Bvehicle_cc_max%5D=&data%5Bvehicle_km_min%5D=&data%5Bvehicle_km_max%5D=&data%5Bvehicle_make_year_min%5D=&data%5Bvehicle_make_year_max%5D=&data%5Bcar_body_type%5D=&data%5Bcar_fuel_type%5D=&data%5Bcar_doors%5D=&data%5Bcar_gearbox%5D=&data%5Bvehicle_aircondition%5D=&data%5Bprice_from%5D=&data%5Bprice_to%5D=&data%5Bkeywords%5D=mrezica Edited November 18, 2015 by beli_Punto Quote Share this post Link to post Share on other sites
bane17 24 Posted November 18, 2015 to sam juce video na jednom zutom hgt ,to jako lose izgleda.vec sa nekih 10 metara od kola,pocinju da se vide nosaci,creva,kablovi.itd,itd Mislim na te plasticne mresice Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted November 18, 2015 A sa originalnom se ne vide? Onda uzmi alu mrežicu. Ona je sitnija i lakše se oblikuje Quote Share this post Link to post Share on other sites
bane17 24 Posted November 18, 2015 Pa original su delimicno zatvorene,pogotovo ove sto idu sa strane. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted November 18, 2015 Onda navuci ženske čarape preko mrežice Quote Share this post Link to post Share on other sites
bane17 24 Posted November 18, 2015 Ma ako nista,imam plan za prednji..izvadicu lajsnu i zatvoriti otvor.kad vec nemam lajsne sa strane a ni na zadnjem braniku, i ubacio bih resetkice sa maglenkama,koje bi bile zute boje Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 pronadjen cep za zadnji branik.. branici skinuti cena farbanja 70 evra..i plus boja tj set znaci baza,lak...400grama...3120 din, Quote Share this post Link to post Share on other sites
asterix 7 Posted November 19, 2015 Vidjen ti auto na ulazu u Baric.Skinuli zadnji branik i poceli da rade. Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 Pa ja sam bio tamo,skidao branike kola sam vratio kuci. Quote Share this post Link to post Share on other sites
asterix 7 Posted November 19, 2015 Video sam kad sam isao da je skinut branik a kad sam se vracao samo njih da smirglaju. Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 Da,da.ja otisao da narucim boju do obrenovca,i u povratku sam ih video da rade zadnji.to je bilo negde oko 11hSutra nosim boju,mada ne verujem da ce branici nazad na auto pre utorka,srede Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 Kolega svaka čast... samo da pitam da li si ti skidao branike ... zanima me jer i ja treba prednji da menjam... Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 jesam,jesam.ja sam skidao i napred i pozadi,decko mi samo pomagao,posto ni on nije znao kako se skidaju Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 ako ti nije teško napravi neki turtorial treba će još nekom.. osim meni.. i naravno srećno sa radovima.. Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 aj kad budem vracao,slikacu.za jedno 3,4 dana.ako nije problem Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 Nikakav.. nije hića.. Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 neces ga sad menjati,pred zimu od utorka sneg Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 Neću... tek posle zime... izlomio sam prednji branik... pa tek treba da nadjem da kupim.. a mozda ima neki zanimljiviji od originalnog... ako naletiš ti javi... Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 na neki branik? za mk2b ti je izbog jako tanak,ili fabricki ili HGT.e sad sa fabrickim mozes da se igras.izvadis lajsnu,stavis lip od clia ili lagune,zatvoris one bocne usisnike. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 Lep je taj hgt.. samo ko zna koliko para za njega... da li ima neki primer prerađenog originalnog sa tim dzidzama... Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 HGT se krece od 40 pa do 100evra.zavisno od stanja,koliko mrezica ima,sa maglenkama ili bez. saljem ti slike za 10tak min Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 (edited) samo za tebe kolega Dimitrijus-eovo je sa laguna spojlerom..ovakav ce sad i moj da bude prednji branik totalni clean look bez srednje lajsne HGT sa spojlerom od stila Edited November 19, 2015 by bane 17 Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted November 19, 2015 Hgt je mama... nego videh sad kolega je predstavio mk2b sport active.. da li je tu isti branik kao na hgt-u...? Hvala na sličicama... Quote Share this post Link to post Share on other sites
bane17 24 Posted November 19, 2015 jeste,isti su... ja sam se odlucio za varijantu sve u boju kola tj branik i centralna lajsna,a ove resetke cu stavim sa maglenkama (zute boje maglenke)i spojler od clia(ide u klavir piano crnu,sad ga smirglam Quote Share this post Link to post Share on other sites
