T-JET 0 Posted May 12, 2012 prodajem izduvnu granu za navedeni auto u naslovu... Quote Share this post Link to post Share on other sites
pozarevljanin 0 Posted May 12, 2012 koliko para Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted May 14, 2012 Moze li koja slika? Quote Share this post Link to post Share on other sites
T-JET 0 Posted May 14, 2012 dodajem sutra sliku cim slikam....inace grane je supersprint nikad lupana varena i ostalo.... Quote Share this post Link to post Share on other sites
Dule 021 660 Posted May 20, 2012 Vauuu,imao sam takvu granu na mom Puntu koji je leteo a zvuk je bio fenomenalan.Svaka preporuka za tu granu! Quote Share this post Link to post Share on other sites
T-JET 0 Posted May 20, 2012 lep zvuk,lakse ide...prodaja samo zbog zamene motora Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted May 21, 2012 Zar Supersprint orginalna grana nije od prohroma. Quote Share this post Link to post Share on other sites
nesobn 2 Posted May 21, 2012 Na mom proslom Puntu je bila drugacija a isto je Supersprint! Mozda ovo nije od istoimenog proizvodjaca! Quote Share this post Link to post Share on other sites
T-JET 0 Posted May 21, 2012 Grana je supersprint al tesko da moze da ostane ovakva kao nova posto je tu malo vruce....al kako god to je ta grana...nije pravljena kuci u garazi i savijana kod gige u supi...grana se srafi sraf na sraf nema secenja i ostalog... Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted July 2, 2012 Da li je grana još uvek aktuelna ,ako jeste ostavi br. telefona. Quote Share this post Link to post Share on other sites
T-JET 0 Posted July 2, 2012 aktuelna 065 52 42 124 luka Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 12, 2012 treba mi pomoc vozim 1.2 16v i ova grana odgovara ali ovde ima samo 1 prikljucak za lambda sondu a kod mene postoje 2 lambda sonde!!!Citao sam da tu moze da bude raznih problema koje nezelim.Luka mi je predlozio da napravimo prikljucak za tu drugu sondu.Plus sam citao na supersprint sajtu da je ova grana za race!!!!Race use only!!!Ako ima neko ko zna sta da radim savet ili slicno...molio bihhvala unapred i pozdrav svim na forumu!!!!!!!!!!!! Quote Share this post Link to post Share on other sites
pozarevljanin 0 Posted July 12, 2012 ja imam istu tu granu na puntu i odlicna je.druga lamda je na katalizatoru a ne na grani. Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 12, 2012 Cekaj vozis 1.2 16v sa dve sonde.OK znam da je na katalizatoru zar nece da pravi neke lampice nebih da mi pravi probleme da me glava boli.sta se radi sa tom drugom sondom kakav je zvuk i jel se oseca malo u perfomansama trebalo bih cekam odgovor hvala unapred Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 12, 2012 ekaj vozis 1.2 16v sa dve sonde.OK znam da je na katalizatoru zar nece da pravi neke lampice nebih da mi pravi probleme da me glava boli.sta se radi sa tom drugom sondom kakav je zvuk i jel se oseca malo u perfomansama trebalo bih cekam odgovor hvala unapred Quote Share this post Link to post Share on other sites
pozarevljanin 0 Posted July 12, 2012 (edited) jedna sonda ti stoji na grani.obrati paznju dole otprilike pre krivine ima mesto za sondu ,druga je na katalizatoru.ne pali nikakve lampice a za performanse ne znam sta da ti kazem.ja ga imam oduvek sa tom granom tako da ne znam kako je bez nje .a zvuk definitivno nije kao bez nje.niko ko cuje auto ne veruje da je 1.2 16v Edited July 12, 2012 by pozarevljanin Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 13, 2012 Hvala drugar videceu da danas odem do Luke pa cemo videti sta mozemo da uradimo ako mi nece paliti lampice chech engine ili sl verovetno cu je uzeti na sajtu supersprinta sam video i granu za 1.2i i ona ima prikljucke za 2 sonde.ali na sajtu pise 1.2 16v sporting sto je moj motor doduse moj auto je i jedan od retkih 1.2 16v CVT speedgear....ako se neko jos razume ako moze neka pomogne svojim komentarima pozdrav svima na forumu!!!!!!!! Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 25, 2012 Juce sam bio do Luke kupio granu montirali je i moj auto ima 2 sonde za granu 1.Morali smo da produzimo kabal sonde lemljenjem i drugu sondu ostavili ukljucenu samo smo je vezali za karoseriju.Uglavnom upalila mi se lampica za kvar sad moram da dijagnostiku da vidim sta je a verovatno je sonda ili sl.Uglavnom problem u najavi molio bih ljude sa foruma za pomoc.Hvala Quote Share this post Link to post Share on other sites
kicerica 5 Posted July 25, 2012 Ja sam taj problem resio ovakohttp://www.arcs.org.rs/forum/viewtopic.php?f=13&t=51831&view=next Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 25, 2012 Najpametnije bih bilo navariti prikljucak za sondu.....videcu sa majstorom sta mi kaze da nezeznem motor itd bas sam se smorio i iznervirao moram da nadjem resenje ili navariti taj prikljucak ili uzeti taj slee kako se vec zove hvala puno ako moze neko jos da pomogne neka se javi.Ili cu vratiti granu Quote Share this post Link to post Share on other sites
kicerica 5 Posted July 25, 2012 (edited) Napravi onaj distancer koji se navari na granu pod blagim uglom i sigurno neces imati nikakvih problema. Ako ti nesto znaci ja mogu da ti pomognem imam drugara koji ima auspuh servis to se odradi za 20 min i kosta smesno para. Edited July 25, 2012 by kicerica Quote Share this post Link to post Share on other sites
pozarevljanin 0 Posted July 25, 2012 jel ima tvoja grana ovaj prikljucak Quote Share this post Link to post Share on other sites
bobiskaslobodan 0 Posted July 26, 2012 E hvala drugar ajde ja bih to odradio imam staru granu pa moze da se iskoristi da se navari na ovu granu.Grana je ista kao sa slike potpuno da libih moglo to da se odradi u ponedeljak trebao sam da idem na neke pripreme ali je otkazano, ja bih mogao u ponedeljak oko 13h moram da sacekam postara za pare.Gde se nalazi taj auspuh servis i ako moze broj telefona.Hvala verovatno cu i skinuti srednji lonac da dobijem rezak zvuk... Quote Share this post Link to post Share on other sites
