Hans 0 Posted February 23, 2011 Jel' postoji osigurac za displej na kome ispisuje predjene kilometre ili mi je samo crkla sijalica? Quote Share this post Link to post Share on other sites
Martini 11 Posted February 24, 2011 Verovatno samo sijalica. Nema poseban osigurac za sijalicu. Ona ima zajednicko napajanje sa tablom na kontaktu. Quote Share this post Link to post Share on other sites
Hans 0 Posted February 24, 2011 ok hvala puno na odgovoru Quote Share this post Link to post Share on other sites
nemmen 0 Posted February 25, 2011 ista muka i mene muci a cujem da je zamena dosta komplikovana... Quote Share this post Link to post Share on other sites
Hans 0 Posted February 25, 2011 ja jos nisam isao da menjam,drugar mi kaze da se menja ocas posla.. Quote Share this post Link to post Share on other sites
Dr. Tuborg 37 Posted February 26, 2011 Skine se tabla (3 inbusa gore i dva dole kod volana) otkacis beli i zuti konektor i eto,tabla je napolju.Sijalica se zameni za 10 sekundi.Evo slike (juce sam skinuo moju tablu) da vidis gde je. Quote Share this post Link to post Share on other sites
tox 42 Posted February 26, 2011 (edited) Zar nema jos jedan sraf sa donje strane table,a prilazi mu se kada se skine poklopac osiguraca? Edited February 26, 2011 by tox Quote Share this post Link to post Share on other sites
nemmen 0 Posted February 27, 2011 korisne fotke, hvala na objasnjenju! cim uhvatim malo vremena menjam i ja sijalicu...da li znate koju sijalicu da kupim (tip sijalice,oznaka,sta vec...) i gde se moze nabaviti? Quote Share this post Link to post Share on other sites
mikisxy 7 Posted February 27, 2011 ima te sijalice u skoro svim radnjama auto delova najcesca oznaka 12V 1,2W najmanja sijalica ubodna koja ide u instrument tablu.ima sraf krstasti sa donje strane negde kod resetke za bocnu ventilaciju Quote Share this post Link to post Share on other sites
Dr. Tuborg 37 Posted February 28, 2011 @toxKod mene nije bio taj iza poklopca,mozda je kod brave drugacije posto je na tvojoj slici tabla od brave (a takvu su imali i bravo automatik).biiip li ga ali ja je skinuh bez tog,samo 3 gore i 2 dole. Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted February 28, 2011 Ja sam danas skidao instrument tablu i bio je i taj inbus kod osiguraca. Quote Share this post Link to post Share on other sites
nemmen 0 Posted March 18, 2011 i kod mene je bio taj inbus kod osiguraca...da nisam znao izlomio bih Quote Share this post Link to post Share on other sites
dj_warped 1 Posted January 21, 2012 (edited) Pozdrav Ne radi mi osvetljenje na instrument tabli za dislpley koji pokazuje predjenu kilometrazu,da li je komplikovano zameniti tu sijalicu?Koja sijalica ide?Da li je ona kao u piksli?Da li moze prilikom zamene doci do nekih problema, jer sam citao da moze doci do problema da posle kilometar sat i obrataji nisu tacni?Jos kada bi imao neki tutorial bio bih prezadovoljan Edited January 21, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
misarw 7 Posted January 21, 2012 Ta stvar bi trebalo da je vrlo slična sa takvom stvari na Fiatu Bravo a to možeš pogledati na:Dash Bulb Replacementhttp://www.fiatboo.co.uk/fix-a-bravo.htmImaš i .pdf dokument na kraju tog uputstva. Quote Share this post Link to post Share on other sites
milke_so 0 Posted October 11, 2012 (edited) Imao sam redovan kilometar sat na bravu, sa analognim brojacem kiloetara. Dobio sam drugi sat sa digitalnim displejom za kilometrazu. Na satu sve radi kako treba, ali kada upalim svetlo nemam osvetljenje displeja, nista zivo se na displeju ne vidi.Ne znam u cemu je problem pa vas molim ako neko zna neka pomazeee. Unapred hvala. Edited October 12, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
tox 42 Posted October 11, 2012 Jedan drugar je isto menjao samo obrnuto,imao je digitalni a hteo je da ubaci sat sa "pravim" brojevima i nesto nije radilo kako treba.Zato mislim da se ti satovi ne mogu menjati medjusobno.A jel to kod tebe nema nikakvih brojeva na displeju ili samo nema osvetljenja? Quote Share this post Link to post Share on other sites
Dr. Tuborg 37 Posted October 11, 2012 Koliko sam ja upucen nece da moze. Quote Share this post Link to post Share on other sites
milke_so 0 Posted October 12, 2012 sve radi ima brojeva, pokazuje kilometrazu kako treba ali nema osvetljenja Quote Share this post Link to post Share on other sites
tox 42 Posted October 12, 2012 Mozda glupo pitanje ali jesi li proverio sijalicu za osvetljenje displeja? Quote Share this post Link to post Share on other sites
milke_so 0 Posted October 12, 2012 (edited) Koliko sam ja upucen nece da moze.Nisi dobro upucen, moze samo je bila problem sijalica koja je falila za osvetljenje displejeMozda glupo pitanje ali jesi li proverio sijalicu za osvetljenje displeja?To sam i uradio i nasao resenje problemaProblem je resen bila je u pitanju sijalica pozadiskog osvetljenje displeja, izvadjena je iz lezista. Tako da ako neko ima ovakav problem neka samo zameni sijalicu Edited October 12, 2012 by miladin Quote Share this post Link to post Share on other sites
Dr. Tuborg 37 Posted October 12, 2012 I radi sve na displeju? Onda sam se istripovao,sve sam mislio da ne moze jer sam negde video na netu. Ako radi onda super. Quote Share this post Link to post Share on other sites
milke_so 0 Posted October 12, 2012 radi kompletno sve, nevidim u cemu bi bio problem da neradi kad je razlika samo u displeju za kilometrazu. Samo je bio problem u sijlici jer je nije ni bilo. Quote Share this post Link to post Share on other sites
elektro123 1 Posted April 7, 2013 (edited) juce uvece upalim auto tabla u mraku kucnem malo ona upali desna 2 cajgera kucnem ponovo ugasi ova dva a upali leva 2 treci put kucnem upali sve osim desne polovine cajgera za brzinu.Da li je neko imao ovaj soblem i kako ga je resio?Bravo 1.2 16v Edited April 8, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
tox 42 Posted April 7, 2013 Jel to pali gasi osvetljenje ili same kazaljke?Imao sam slican problem,samo sto je kod mene prekidao brzinomer,reseno skidanjem table i minimalnim krivljenjem pinova na konektorima za instrument tablu radi boljeg spoja sa konektorima koji se stekaju na tablu. Quote Share this post Link to post Share on other sites
elektro123 1 Posted April 7, 2013 meni kazaljke rade normalno samo osvetljenje mi je problem Quote Share this post Link to post Share on other sites
