nemanja982 0 Posted September 11, 2014 Da li neko ima iskustvo sa Bosch pumpom na tipu 1.7,naime ima jedno dva meseca,kad palim ne pali na prvi zub,kao do sada vec mu treba da zaverla 3-4 zuba.Mislio sam da su grejaci,promenio sve,ali opet isto.Ujutru kad pali treba mu bas da vergla,ili samo pipnem kljuc,pa kad ponovim pali na prvu.To se desava samo kad je ugasen neki period.Kompletan remont pumpe je radjen pre 4 god,kada je uradjen i motor.Da li je moguce da je pumpa na izdisaju? Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 12, 2014 Bilo ko,bilo sta....bilo kakva ideja sta moze da bude? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 12, 2014 Mozda ti vraca naftu u rezervoar? Mozda uvlaci malo vazduha negde? Mozda sporije vergla? Jesi li radio nesto skoro? Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 12, 2014 Nisam nista skorije radio,od pre 4god kad je radjen motor i pumpa,samo redovan servis na 10000 za neki dan pada da odradim... Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 13, 2014 Proveri ovo sto sam ti pisao. Jel on nosi bese Bosh ili Lucas? Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 13, 2014 Bosch,pogledacu.Planirao sam da zamenim filter ovih dana pa cu da vidim i to. Quote Share this post Link to post Share on other sites
sindrom 18 Posted September 13, 2014 Pogledaj prvo grejace pa trek onda sve ostalo. Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 13, 2014 Promenio grejace,to sam prvo i pomislio.... Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 13, 2014 Jel dolazi struja do grejaca, baci pogled, mada ja mislim da taj motor brz grejaca ne bi ni palio uopste. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted September 13, 2014 Mislim da gresis Mico! Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 13, 2014 Mislim da jok Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted September 13, 2014 Drugaru palio na ceo jedan i tako morao da zavergla jednom pa posle odma pali. Zamenio sva cetri i sad odma pali a kaput mu motor. Trosi na 800km 1l. Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 13, 2014 Trebalo bi da dolazi,jer imam display koji mi pokazuje napon akumulatora,i vidim kad povuce struju za grejace.Ali nesto nisam obracao paznju zadnjih par dana na to :-) Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 13, 2014 Pa to sam i reko. Nece bez grejaca na prvu. Moj kad je do Nisa trosio 1l ulja palio je na zub..takav je fiat Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted September 13, 2014 Napisao si da uopste ne bi upalio. Sad te razumem Quote Share this post Link to post Share on other sites
nemanja982 0 Posted September 14, 2014 Samo da javim,izgleda da sam nasao problem,ujutru cu da potvrdim 100%.Crevo koje ide sa filtera na pumpu,je puklo,kao ziletom,dovoljno da u miru uvlaci vazduh,a da u radu pritisak odrzava da ne uvlaci vazduh.Sutra sledi potvrda :-) Quote Share this post Link to post Share on other sites
