Sedla 2576 Posted April 20, 2023 Pričah u decembru o Breri,ne uradih ništa. U aprilu nisam više ni razmišljao o njoj, dodje auto na šlepu u Aranđelovac. 21 IDzO, Ivan-Topola, Milutinac and 18 others reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted April 20, 2023 10 minutes ago, Sedla said: dodje auto na šlepu Alfa je to ! Neka služi u zdravlju i veselju kupe-taxi ! 2 Dale and Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 20, 2023 Stigla mi jedno veče ova poruka... Naravno, nisu je prodali od jesenas zato što auto ima problem. Naravno da je auto došao kod mene sa problemom. Naravno da ću probati da rešim problem, jer mi deluje da nije ništa ozbiljno,da je neka glupost u pitanju...što će se dalje i otkriti šta je i kako... Nije mi đavo dao mira,morao sam da probam kako joj stoje Giulia felne Pa JAO! 15 Nikola JTD, silenci, Milutinac and 12 others reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted April 20, 2023 (edited) Čekaj, ja sad više ništa ne razumem ? Jel 159 ostala kod tebe ili je otišla u zameni ? Edited April 20, 2023 by Reacher Gilt Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 20, 2023 Dogovor je da 159 ostane kod mene dok ne sredim i dok ne registrujem Breru. Kad je budem registrovao,tada ću im poslati moju 159 u zamenu,i tada ćemo pričati o visini doplate,u zavisnosti od toga šta će sve morati da se radi i popravlja na Breri. 6 Reacher Gilt, igor0511, MS PK and 3 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted April 20, 2023 Pa bravoo bre Sedlicu! 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 20, 2023 Pa hvala, Mićo! 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Ivan 17652 Posted April 20, 2023 (edited) Iako ga ne znamo, ovde vec cuveni majstor Bure zadovoljno trlja ruke... Jos jedna na listi . Da se uozbiljim - zelim ti da brzo resis problemcice, da te lepo sluzi i da uzivas u masini! Jos mi reci da je benzina ? Steta sto u tim godinama nisu imali neki krsteniji benzinski motor, najcesce su JTS atmosferci, 2.2 ili 3.2. A od turbaka samo 1.8 TBi sa svom svojom problematikom, tako da pretpostavljam da si "osudjen" na traktorisanje i dizela u takvom autu? Tj. 2.4 petak ili pred kraj produkcije u taj model ide i 2.0 MultiJet (sto je i srpska user-friendly opcija). Jedan od automobila koji ce, bar meni licno, uvek biti pojam dizajna. I kome ni godine ni nove tehnologije, u tom smislu, ne mogu nista. Za razliku od ove danasnje gomile Copy/Paste sljastecih LED plastikanera na baterije, koji ce biti zaboravljeni vec do prvog sledeceg modela. Edited April 20, 2023 by Ivan 5 silenci, knezevic76, Sedla and 2 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 20, 2023 Vidiš, Ivan me podseti,zaboravio sam da napišem nešto više o samom autu. Brera je 2007 godište, i da, osuđen sam da to bude traktor. 2.4 JTDm, 200ks oprema onako osrednja, nije klot a nije ni vrh ponude. Fabrička multimedija, Bose ozvučenje, panorama krov,multifunkcionalni volan, tempomat, kožna sedišta. Fabričke 18" "spiderweb" felne kojih ću da se otarasim jer mi se ne sviđaju uopšte. Verovatno već imam kupca za njih, u nekim sam pregovorima, i uzeću odmah posle toga fabričke potkovice 18", ako ne budem uspeo da skupim novce za "ti" 19" ili Giulia felne. 2 Reacher Gilt and horvat reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted April 20, 2023 Ma jadan ti sa petakom i 200ks Bilo bi bolje da je 1750cm3 benzin i da trosi jedno 16l 3 3 Milutinac, dekirs, Sedla and 3 others reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted April 21, 2023 Alfa je to. Najvažniji je smešak na licu kad se pogledate. Srećno ! 2 MS PK and Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 21, 2023 On 4/20/2023 at 11:48 PM, MS PK said: Ma jadan ti sa petakom i 200ks Bilo bi bolje da je 1750cm3 benzin i da trosi jedno 16l Hahah... Pa eto,tako sam u mogućnosti... Ukratko,šta je problem sa Brerom... Auto kad je došao imao je -navodno- problem sa DPF-om. Izvadili su ga,intada su počeli problemi. Auto dimi na leru kao nenormalan, teško pali, nemirno radi itd... Menjali su više kompleta dizni,čak i remontovane stavljali, nisu mogli ništa da urade. I od jesenas,ko god dodje da pogleda auto,naravno da neće niko da ga kupi, kada vidi kako pali,radi,purnja,itd... Auto je došao kod mene, i ustanovio sam da DPF u stvari nije uopšte ugašen softverski,ili to nije uradjeno kako treba. Dečko koji im je radio to,izgleda da je samo uradio DTC off, da ne prikazuje nikakvu grešku na tabli ni na dijagnostici. Ono što treba uraditi na kolima,i što planiram da radim je sledeće: Pravilno gašenje DPF-a Softversko gašenje EGR-a Gašenje i vadjenje klapni iz usisa Čišćenje usisne grane, interkulera i svih ostalih hladnjaka I sad, računica mi je jednostavna. Za sve ovo što treba uraditi na kolima, u Beogradu ko god bi je uzeo, i plaćao majstora da uradi sve ovo, kontam da bi trebalo da uloži bar 400€, beogradjani možda mogu da kažu tačniju cifru. Ja pošto sve to radim sam sebi, koštaće me plafon 50€. Tako da imam računa da se bakćem i posvetim autu. Danas kreću radovi, pa ću vas izveštavati kako se dalje odvija situacija... 17 Reacher Gilt, Dzimbo, horvat and 14 others reacted to this Quote Share this post Link to post Share on other sites
Ivan 17652 Posted April 21, 2023 (edited) 2 hours ago, Sedla said: Auto kad je došao imao je -navodno- problem sa DPF-om. Izvadili su ga,intada su počeli problemi. Auto dimi na leru kao nenormalan, teško pali, nemirno radi itd... Menjali su više kompleta dizni,čak i remontovane stavljali, nisu mogli ništa da urade. Upravo sam to i hteo da ti kazem - mozda losa nova mapa/parametri koji su ucitani prilikom skidanja DPF. A mozda je i "zvaka" da je to uzrok i da je ranije sve bilo OK, koliko si siguran u pricu prodavca? Svakako ti zelim da sto pre resis i uzivas, sa zadovoljstvom cu pratiti temu. Apropo dizel/benzin varijante, upravo i kazem da je steta sto u tom periodu nisu imali neki omasovljeniji turbo benzinski motor (sumarno, u smislu pouzdanosti, potrosnje, itd.). Neosporno da je Fiat imao odlicne CommonRail dizelase od pocetka veka. Ali jos od daleko pre toga i od kada kao dete znam za Alfe - nikada mi uz njih kao sporCki brand nije islo traktorisanje. Ali jednostavno im je, od kada su dosli pod kapu Fiata u drugoj polovini 80-ih, ta sudbina bila neizbezna. S druge strane, takodje je neosporno da je to u nasim uslovima najrentabilnija varijanta i da je kod modela tih godista ponuda dizela dominantna. Pa se takva kupovina jednostavno namece kao najracionalnija, neki put cak i kao jedina moguca. To je vec stvar ukusa - ali tu je gomila lepih stvari, prefinjenije voznje i uzivanja kod benzinskog pogona koji bi isli uz ovakav auto. I to pricam kao neko ko se posle nekoliko godina voznje malog turbo benzinca opet vratio na smrdljivu 2.0 dizelcinu . Ide to, jeste odomaceno, jeste rentabilno, jeste najracionalnije, ali... Slicna prica kao i kod Brere - ovde samo zbog problematicnih THP motora. Da je drugacije, ne bih se dvoumio ni sekunde oko benzinjare. U Alfici pogotovo. Edited April 21, 2023 by Ivan 4 Sedla, igor0511, silenci and 1 other reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted April 21, 2023 Magnet za poglede! Želim ti brzo rešenje tih problemčića a osmeh se dobije gratis! 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted April 21, 2023 Davno su me matorci "ložili" da kupim Breru...dal bi se zakovao da sam je uzeo il ne, nikad neću saznati ali skroz je nesvakidašnji auto. Posebno kada se pogleda zadnji deo, 4 auspuha je 4 auspuha... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17652 Posted April 21, 2023 2 hours ago, ISV_01 said: dal bi se zakovao da sam je uzeo il ne, nikad neću saznati ali skroz je nesvakidašnji auto Lepo reci, je*o me pas kad je nisam uzeo . Kome naravno odgovara takva trovratna koncepcija, u karoseriji te velicine. Auto je dizajnerska perverzija i posle skoro 2 decenije od predstavljanja i evo vec 13 godina od kada je proizvodnja prekinuta. 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 22, 2023 O svaka čast,Brera je sjajna po izgledu i sto kaze Ivan da je jos pozivela sa proizvodnjom pa da se ubacuju neki moderniji motori ponajvise benzinci.Sedla ako nisi u stanju da sredis,doteraj pa da pokusam da je opravim,nisam strucnjak,al mogu da pogledam. A Ivane tebi zelim sledeci auto da bude,kao sto naš cenjeni precednik vozi,ma on se vise vozi,nego sto sam vozi. 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted April 22, 2023 Ajde Sedlicu... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 24, 2023 (edited) Ajde..... A gde ćemo? Brera....trenutno stanje: Ko je rekao da mora da se razupči motor da bi se skinula pumpa visokog pritiska? ...ali izgleda da mora da se razupči motor da bi se skinuo jbni nosač pumpe visokog pritiska. Jer zbog tog nosača ne može da se skine usisna grana, udara jedno u drugo. On 4/20/2023 at 10:18 PM, Reacher Gilt said: Alfa je to ! Neka služi u zdravlju i veselju kupe-taxi ! Klinci po kraju viču "vidi, 159-ka sa dvoja vrata!!!!" Edited April 24, 2023 by Sedla 6 3 neshaoct, ristivoje, Ivan-Topola and 6 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 24, 2023 (edited) To je otprilike to dokle sam stigao sa radovima. Došao je vikend i prvo okupljanje Alfista u Mionici,pa je trebala 159-ka da se spremi za skup. A usis na Breri... Uh... Nema puno naslaga. Samo skoro 1cm. Edited April 24, 2023 by Sedla 4 Milutinac, Ivan-Topola, horvat and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted April 24, 2023 Mislio sam da je gotovo. Jesi li je probao sa ugasenim dpf-om opet? Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 24, 2023 Nisam je probao. Skinuo sam motorni računar i poslao drugaru da ga sredi, iiii....onda sam odlučio da rasturim sve i krenem od nule. Tako ću biti sigurniji i moći ću da eliminišem više mogućih problema,za slučaj da bude nekih... 6 MS PK, darkman14, igor0511 and 3 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted April 25, 2023 5 Reacher Gilt, neshaoct, Ivan-Topola and 2 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted April 25, 2023 Zamisli tek kad vratis usis koliko ce da ima Salu na stranu, jel' ovo ipak fali malo vise konja nego sto bi trebalo na originalnom grafiku? 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted April 25, 2023 Falilo je, cekamo da reče zasto Quote Share this post Link to post Share on other sites
