simonen 81 Posted October 4, 2022 (edited) Pozdrav drugari, Skoro kupih Brava T-jet 150ks i odmah problem.Procureo mio zaptivac na hladnjaku ulja,gumeni. Izgleda ovako,naravno nigde ga nema,ako neko ima ideju gde traziti.... Edited October 4, 2022 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Ivan 17587 Posted October 4, 2022 Ne moze da se uzme odvojeno cak ni kod ovlascenih. Posto izmenjivac i kuciste filtera idu zajedno u kompletu (55212027, i to je kod njih oko 260 EUR). Znam da je imala varijanta iz aftermarketa, radili su Poljaci, cena dihtunga negde oko 30 EUR (eBay i sl.). Ako u medjuvremenu neko nije poceo da stancuje. Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted October 4, 2022 Spominjala se Pazova na AR forumu. Možda neko izrađuje... Ja sam naleteo na ... Quote Share this post Link to post Share on other sites
simonen 81 Posted October 13, 2022 Nasao na Ebay-u https://cart.payments.ebay.co.uk/ 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted October 20, 2022 Da dodam i ovaj post iz Predstavljanja automobila clanova, ovde u opstu tehnicku temu: 2 hours ago, Branislav said: @andreja.micovic Evo link od poljaka koji prave za Tjet https://m.olx.pl/d/oferta/uszczelka-chlodnicy-oleju-do-fiat-bravo-2-doblo-punto-tjet-CID5-IDmr47v.html Hvala @Sem za info oko ove gumice Quote Share this post Link to post Share on other sites
simonen 81 Posted November 8, 2022 (edited) Stigla gumica od brata Poljaka.Hvala lepo. Iako sam moju predihtovao i za sada je OK,ipak neka stoji. Edited November 8, 2022 by simonen 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted November 8, 2022 8 hours ago, simonen said: Stigla gumica od brata Poljaka Koliko te izaslo na kraju, koliko si cekao? Mozes da ostavis i link, posto onaj gore nije ispravan. Sigurno ce nekome znaciti informacije . Quote Share this post Link to post Share on other sites
simonen 81 Posted November 8, 2022 Narucio 22.10. stiglo 08.11....Ukupno sa postarinom 32 eura. Nazalost ovaj prodavac ih vise nema,ja sam uzeo poslednji.Imalo ih je jos na Ebay-u ali su bili skuplji. 2 neshaoct and Ivan reacted to this Quote Share this post Link to post Share on other sites
simonen 81 Posted February 23, 2023 (edited) Pojavile se na Aliju: https://www.aliexpress.com/item/1005001680040624.html?gatewayAdapt=4itemAdapt Edited February 23, 2023 by Ivan Dodat PrintScreen, sredjen format 2 Mijailović P. and Ivan reacted to this Quote Share this post Link to post Share on other sites
BaneAK74 113 Posted March 10, 2023 Nakon sto sam provalio da su mi gumice otisle na hladnjaku ulja bacam se u njihovu potragu, koja moram priznati nije bila laka Nailazim na podatak da novo kuciste kosta 260e sto je po meni jako skupo s' obzirom da su kod mene samo popustile gumice. Gumicu koja ide izmedju hladnjaka ulja i kucista ulja sam narucio od poljaka koji je opste poznat na forumima. Jer je jedini koji je kopirao fabricku, odnosno po meni, napravio ju je boljom(fabricka je dosta tanja). Zamenska-Poljska Fabrcka Inace ova gumica pase na Bavise do 2009 godista br. 55212027 I nije je moguce naci iz originala. Dok za novije posle 2010 ide ova: 55236756 Sto se tice gumica na srafu izmenjivaca toplote(tako sam nasao da se zove), one mogu da se nadju iz originala br. 55211316, ali ih nema u Srbiji. Poslao sam mail u par Fiat kuca u Srbiji i niko mi nije odgovorio. Tako da sam cackajuci po netu naleteo na dimezije tih o-ring gumica. Neki mucenik nije mogao org. da nadje, pa je doznao dimezije Rekoh sto da ne kad je ovom uspelo sto ne bi meni. Nadjem firmu koja se bavi izradom o-ringsa, posaljem dimezije, i za 3-4 dana ih dobijem. Naravno, trazio sam da budu otporne na toplotu, ulje, pritisak. Naravno, mogu preko e-Bay da se naruce. Ja sam ih nalazio za 20-30e Sam sraf ovako izgleda. Procitao sam da kad na njemu popuste gumice moze da dodje crkavanja turbine. Koliko je to tacno, ne znam. Sto se tice zamene ovih gumica ja sam to odradio bez skidanja celog kucista.Jer je lako prici kucistu sa donje strane auta. Sam hladnjak se drzi na sest srafova, a izmenjivac toplote ili ti sraf se odvije sa kljucem 20(ako se dobro secam). Ko bude hteo da se prihvati sam da menja nek pripremi 1l ulja i oko 2.5 antifriza. Ako neko ima neko pitanje, tu sam da pomognem koliko mogu. Pozz 1 2 Ivan, MiloshBg and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted October 24, 2023 (edited) @BaneAK74 Vidim da je i kod mene počelo da rosi na šrafu pa me interesuje dimenzija tog o-ring zaptivača. Svakako ću da krenem sa potragom i zaptivača hladnjaka ulja preventivno. Samo me interesuje kako je @simonen to rešio predihtavanjem bez zamene, kako sam razumeo iz navedenog. edit: @BaneAK74 Da nije to ova... Edited October 24, 2023 by Mijailović P. Quote Share this post Link to post Share on other sites
simonen 81 Posted October 25, 2023 14 hours ago, Mijailović P. said: @BaneAK74 Vidim da je i kod mene počelo da rosi na šrafu pa me interesuje dimenzija tog o-ring zaptivača. Svakako ću da krenem sa potragom i zaptivača hladnjaka ulja preventivno. Samo me interesuje kako je @simonen to rešio predihtavanjem bez zamene, kako sam razumeo iz navedenog. edit: @BaneAK74 Da nije to ova... Uzmes klingerit 0.5mm precrtas konture gumice,i iskrojis zaptivku identicnu obliku gumice.Jeste dangubno ali ja tada nisam imao drugo resenje.Tu zaptivku ubacis u kanal pre gumice,pa onda gumicu preko zaptivke,na taj nacin si povecao dihtovanje gumice za 0.5mm. Namazes tanko kvalitetnog silikona i to je to.Ja sam iskreno mislio neka traje dok ne stigne nova,ali evo vec godinu dana suvo(da ga ne ureknem) 1 1 Mijailović P. and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted October 25, 2023 Isto sam imao na umu samo mi je trebala potvrda kako bih se upustio u igranku. Hvala kolega! 2 Reacher Gilt and simonen reacted to this Quote Share this post Link to post Share on other sites
BaneAK74 113 Posted October 25, 2023 @Mijailović P. 2.5*18*23 - 2.5*25*30 Ja sam ove dimezije nasao. I evo vec sam presao dosta od montaze i nema curenja. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
sasa ns 1 0 Posted December 5, 2023 On 10/25/2023 at 5:48 PM, BaneAK74 said: @Mijailović P. 2.5*18*23 - 2.5*25*30 Ja sam ove dimezije nasao. I evo vec sam presao dosta od montaze i nema curenja. da li idu obe gumice na taj šraf i da li su to prave dimenzije, On 10/25/2023 at 12:06 PM, simonen said: Uzmes klingerit 0.5mm precrtas konture gumice,i iskrojis zaptivku identicnu obliku gumice.Jeste dangubno ali ja tada nisam imao drugo resenje.Tu zaptivku ubacis u kanal pre gumice,pa onda gumicu preko zaptivke,na taj nacin si povecao dihtovanje gumice za 0.5mm. Namazes tanko kvalitetnog silikona i to je to.Ja sam iskreno mislio neka traje dok ne stigne nova,ali evo vec godinu dana suvo(da ga ne ureknem) ja sam jop 2017 imao taj problem.Rešio mi je majstor sa silikonom bez klingerita i držalo je sve do proletos.Onda se pojavilo jako blago curenje moćda par kapi na 500 km.To je trajalo koju hiljadu pa je skroz stalo.Posle par meseci necurenja mi se pojavilo curenje od recimo 5 kapi na 100 km.Da li je nekom ostala ona gumica za tjet 1.4 110 kw lancia delta 2008 i da li bi je prodao. Proletos dok je bilo jako blago majstor mi je savetovao da ništa ne diram jer se boji da ponovo skida dihtong i da ga čisti od silikona da ne bi pukao . Kod onog skidanja 2017 sam skenirao dihtung i razmišljao da ako bude trebalo nađem gumu ili silikon iz table za tu namenu i isečem na voterdžetu. Ako neko ima savet ili hoče da proda gumicu nek se javi na 0641352299 saša Još nisam gledao odole jer ne mogu bez majstora. Čak nisam siguran ni da li curi na toj velikoj gumici hladnjaka jer kad pipam rukom odgore čini mi se da curi iznad te velike gumice pa ne znam tačnno da li može ulje da ide i malo na gore ili su možda ona dva O ringa na šrafu ako uopšte idu ta 2 jer i to nisam siguran.Da li idu i ona veći i manj O ring što je neko ostavio dimenzije ili samo jedan onaj sa slike. Quote Share this post Link to post Share on other sites
sasa ns 1 0 Posted December 6, 2023 da li si mazao silikon samo od gore a između klingerita i metala ili klingerita i gumice nisi Quote Share this post Link to post Share on other sites
