ISV_01 4023 Posted February 4, 2023 Uzivo je auto vanvremenski skroz... Sredjen iz tone ljubavi i paznje. 3 nemanja84bg, horvat and dellas reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted February 6, 2023 Hvala ISV Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 3, 2023 Spreman za jedan TD na Navaku, steta ga je ne probati ne zbog nekog jurenja vremena nego za licni gust 7 Bingodalton, Milutinac, PremieRacing and 4 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5303 Posted April 4, 2023 Puuuu, extra Sad kad je Navak promenjen ionako se vremena neće gledati jwdno mesec, dva dok se ne ustali prosek i rekord. C U tamo 2 dellas and horvat reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 4, 2023 Mislim da ce se voziti stara konfiguracija jos neko vreme, ali videcemo, opremio sam se i jednim vozilom koje je bolje za pravac 2 neshaoct and horvat reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5303 Posted April 5, 2023 Vozilo za pravac je bezvezalija, krivine su mama Nego, što si škrt u vidu info. i slika, daj da vidimo o čem' se radi... 1 nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 5, 2023 (edited) Daleko od toga da je samo za pravac ali je fwd pa ima svoje limite Mali teaser Edited April 6, 2023 by neshaoct prebacio sliku na FLCS server 6 neshaoct, nemanja84bg, PremieRacing and 3 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5303 Posted April 6, 2023 Crna? iz NS? 310ks ? 1 horvat reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 7, 2023 Nije crna, nije iz NS i nadam se da nije 310hp, al znacu vrlo brzo 1 3 horvat, nemanja84bg, PremieRacing and 1 other reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1287 Posted April 7, 2023 (edited) On 4/5/2023 at 4:27 PM, dellas said: Daleko od toga da je samo za pravac ali je fwd pa ima svoje limite Mali teaser Da nije mozda iz kg-a ovaj seat ili tako nesto ima dobru felnu ? 2.0 tfsi Edited April 7, 2023 by nemanja84bg Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 8, 2023 Nije 310 5 PremieRacing, igor0511, neshaoct and 2 others reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1287 Posted April 8, 2023 Oho , dobar , meni jedini sluzbeni auto bio noviji sledeci model , lep autic mada bio 1.4 tsi menjac perfekt i kad zatvoris prozore od spolja , nista ali bukvalno nista se ne cuje i ima lepu ostrinu sa bocnog prozora ka soferci, kul autic skroz 1 dellas reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5303 Posted April 9, 2023 Auuuuu, top! 350 ponija, 450 Njutnovih i, najbitnije od svega 7100 rpm!!! Sad će Yugisha to da isproverava i da ti smanji za 30 al' lepo je imati papir na 350 Daj sad fotke auta i ispričaj odakle, šta, kako, koliko, da vidimo o čem' se radi... 2 dellas and nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 9, 2023 Ovo je mapa u tom trenutku radjena, imam i jednu jacu ali nismo jos stigli da izmerimo. Turbo konji i atmo konji jesu druga stvar, mapa na 330ci je takva da on non stop ima snagu i uz vrhunski start koji ima sa sperom, ne zaostaje puno na 402 kad se mere, a na stazi je tek upotrebljivost drugacija. Ali ovo instant zabada u sediste i ne popusta u svakoj brzini, svaki zanimljiv na svoj nacin 3 igor0511, horvat and nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted April 10, 2023 Ako imas jos jacu mapu, znaci Stage 3? Ides u Osijek? Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 10, 2023 Ti stage-ovi , svako ih krsti kako misli da treba Ja mislim da je to neki stage 2+, manje vise od hardware-a auto ima carbon usis, downpipe, IC veliki, oil catch can, za turbo nisam siguran da li je hibrid ili ne. To je neki 2+, 3 je vec kovan motor, turbo veci i sl, bar ja tako gledam.... Trebalo bi, ako resim gume jer ovako nema dobra vremena, jer nema nikakav start. Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted April 10, 2023 Da, svi to malo drugacije gledamo izgleda. Za mene: stage 1 bi bio samo mapa stage 1+ filter recimo i usisno crevo, koleno na turbini, ili interkuler,... stage 2 je sa Downpipe-om (e sad, moze bez interkulera, ali bi se na track day-u bas osetilo), mora nova mapa da se radi svakako stage 3 hibridni turbo i slicno, sta god vezano za turbo, a mora nova mapa da se radi. Ide tu nekad i pumpa i slicno... stage 4 otvaranje motora, druge dizne, dodatno podizanje snage Zato pitam, verujem da je tu vec drugi turbo kod tebe, da nije samo downpipe, interkuler i mapa. Mozda se vidimo onda tamo, ako ides 1 dellas reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 21, 2023 Vidimo se u Osijeku Resio sam gume, vremena su odmah malo bolja od 6.4 0-100 i 13.9 na 402, palo je na 5.6 0-100 i 13.5 402... Ima snage za mnogo vise ali fwd ima svoje limite... 3 horvat, Bingodalton and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted April 21, 2023 Ekstra doduse na stazi ce to biti i do pola sekunde manje, ali taman za klasu 14 Sent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
PremieRacing 5303 Posted April 25, 2023 Kad je taj Osijek? I gde 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted April 25, 2023 27. i 28. majSent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
dellas 1556 Posted June 14, 2023 Par utisaka posle kratkog Osijeka za mene (samo subota) , auto je radio savrseno...pu pu da ne ureknem. Najbolje vreme 13.3 , bolje nego sto sam ocekivao ali i dalje uz dosta klizanja, ima prostora da to jednog dana bude i bolje. @Bingodalton Kako si ti prosao, ako si bio? 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted June 14, 2023 Nedelju nisam vozio, samo subotu. Sad vidim i ti si subotu, a mislio sam da ces nedelju. Nisam ni obracao paznju na Leon. Ti si vozio klasu 14 onda? Vreme auta je 13.3 ili ukupno? Videcu da li cu ici u Zivinice sada u nedelju, ali moram bas poraniti da u pola 8 budem tamo Od 42 takmicara u klasi 13, imao sam srece u prvom krugu jer je moj suparnik odustao, tako da sam se provukao u sledeci krug vozeci samo da potvrdim vreme. Sledeci krug sam dobio nekog sa prednjom vucom, zaboravih tacno koji auto je u pitanju. Krug nakon toga se susrecem sa valjda 324td + Nitro iz Overboost tima i dobija me knap sa 13.011, napsram mojih 13.066 Kako vidim taj BMW ide lagodno ispod 13, tako da ga bas lepo dozira i trunka je falila da probije klasu. Kocio je, a i ja sam kad me je vec prosao pred cilj u nadi da ce on probiti, a ja ne. I da nisam, verovatno bih imao ~13.030. To je tu sve na 1-2m duzine. Na kraju je BMW zavrsio treci, a ja ne znam koji sam tacno, ako uopste postoji lista. Sasvim moguce 6. mesto po postignutom vremenu ili ako je neko ispao iz prvih 5 mozda i nize. 2 dellas and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted June 14, 2023 (edited) Svakako lep plasman u jakoj konkurenciji Da da 14, 13.3 je vreme auta… ne volim kocenje i kalkulacije na reakciji ali dok se jos malo ne ubrza tako je p.s. Nesin 324td je daleko od 324 Edited June 14, 2023 by dellas 1 Bingodalton reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 733 Posted June 14, 2023 Nezgodno je da auto bas ide toliko. Moj u sustini ide, na SR sam taman uz dobar start, ali eto vidis, 55 hiljaditih. Uz bolju reakciju probijem, uz losiju idem 0.1-0.3 iznad. I na to jos dodati podlogu i koliko klizne...nije lako.A bmw ne znam sta je tacno unutra, ali vidim da ga dobro steluje i startom i kocenjem. Sent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
