darkman14 5898 Posted February 2, 2022 Kad će drugi okviri tablica? Quote Share this post Link to post Share on other sites
darkman14 5898 Posted February 2, 2022 Da nisu plastični i da nemaju reklamu ajd plastični manje više, nego kad reklamiram nečiju agenciju, servis... to me jako nervira. još ako skine moje bez pitanja... Pa nemam svaki put 10% popusta na uslugu kad dođem da bih nosio nečije okvire (btw video sam da Nemanja autoanaliza prodaje svoje okvire od pre koji dan ) Ovi forumski što su bili ili oni sa fb grupe su ok, voziš fla, imaš flcs okvire mi je skroz ok ili voziš brava, imaš okvire sa bravo fb grupe isto ok 2 Ivan BG and Grafit reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 2, 2022 Pa ne opterecujem se time bas, volim da lepim tablice pa da budu bez okvira ali kad vec stavljam okvir, bas mi je svejedno sta pise na njemu. Samo da nije neki kicast, svetleci, hromiran ceo i slicno… Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
italiano 463 Posted February 2, 2022 @horvat Ako ti neko trubi iz prljavo srebrenog 500L, da znas da sam to ja! 1 horvat reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 2, 2022 4 PremieRacing, horvat, Zvezdo and 1 other reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 2, 2022 (edited) @italiano haha vazi, obraticu paznju! @YUgisa da li moze da pise "YUgisa"? Edited February 2, 2022 by horvat Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 2, 2022 Pa da misle da vozim alfino opelo, neka fala 2 1 horvat, ISV_01 and neshtry reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 3, 2022 Juce sam se vozao 280 km, sve po Subotici i okolini Vozio sam poprilicno agresivno, cesto u opsegu 5000-6500 rpm, par puta dohvatio 200 kmh, i potrosnja mi je 12L, na tom uzorku, sto mislim da nije tako opasno s obzirom na divljanje. Slika nije napravljena na kraju, pa je zato samo 220 km 5 Milutinac, Danilo1, Stilisa and 2 others reacted to this Quote Share this post Link to post Share on other sites
Stilisa 313 Posted February 3, 2022 I kakvi su utisci? Zadovoljan? Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 3, 2022 E pa mogu da napisem par reci o nekom poredjenju sa Giuliettom, sto sam uspeo da izvucem iz ove jedne, ali jace voznje... Glavni utisak je da je auto mnogo udobniji. Na to sigurno uticu i balonkastije gume (225/50 vs 225/45), ali i cvrsca karoserija na 159 i verovatno mekse vesanje. Jednostavno sve sa puta se manje prenosi u kabinu. Sto dovodi i do jedne mane, za koju jos uvek ne znam da li je posledica guma ili karakteristike auta. Pri vecim brzinama (npr 120+), kao da mi prednjica malo pliva, nemam taj osecaj postojanog kontakta sa asfaltom. E sad, putevi su bili vlazni sinoc i moguce da gume jednostavno nisu na tom nivou, pa da je zbog toga. Iako je 159 nizi auto, cini mi se da se vise naginje u krivinama, i svakako su promene pravca tromije a stabilnost u brzim krivinama nesto veca. Materijali u enterijeru su osetno kvalitetniji, sedista duza i zalegnutija. Lakse se nadje dobra pozicija za volanom. Sam volan je malo deblji i zbog hidraulike, prenosi vise informacija sa puta i prirodniji je. Kocnice mi se dopadaju, mada mogu samo da komentarisem osecaj na pedali, jer gripa ni izblizu nemam dovoljno da mogu da kazem nesto o stvarnom zaustavljanju. Cini mi se da je ovde zbog 4 klipnih kljesta, tacno onako kako sam zeleo na Giulietti da postignem sa kljestima od 166. Tvrdja je pedala i sa jacim stiskom ne propada toliko, nego se samo pojacava pritisak/snaga na nju. Da napomenem, moja Giulietta ima 281mm disk, odnosno najmanji moguci. Ozvucenje je nesto malo bolje, al nije nebo i zemlja. Menjac mi je losiji u 159. Hodovi su slicne duzine, rekao bih, ali je dosta teze menjati u 159, kao da ima neki metalan osecaj, najgore je kad se prelazi iz 2. u 3. Pedala gasa je poznata 'boljka' na JTS, i to se definitivno oseca. Najveci problem je nekonzistentna reakcija. Imam utisak kao da su pokusali da kompenzuju manji obrtni moment kod atmo motora, time sto pri kretanju mali stisak pedale zapravo doda velik gas, dok npr. kad je izbacen iz brzine i treba da se zaturira, potrebno je stisnuti puno pedalu da uopste odreaguje. Motor na malom gasu i/ili manjim obrtajima zvuci bas nezanimljivo, kao usisivac, ali kad se da pun gas i predje nekih ~3-4 hiljade, onda bas fino zarezi, dopada mi se. Potrosnja u ovih ~280 km kombinacije grada i jurcanja na otvorenom je oko 12L. Ne verujem da ce mi ici preko toga, s obzirom na to kako sam vozio... Imam neko hukanje za koje jos uvek nisam nacisto od cega dolazi. Prvo sam sumnjao na nesto od mehanike, ali sinoc sam pomislio da je mozda ipak od guma. U svakom slucaju, i da nije od guma, Nexen mi se ne dopada, trebao sam se ispruziti barem za BF Goodrich/Kleber, ali dobro, i to je skola. Bezbedno je to, udobno, sve u redu, ali ovako u ostrijim uslovima se pokazu te neke razlike. 13 Dzimbo, shuxx, dach@ and 10 others reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3432 Posted February 3, 2022 HUNTER 1 1 Axic and djomla reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 3, 2022 Ovaj put nema potrebe, nista ne trese! Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted February 3, 2022 2 hours ago, horvat said: kao da mi prednjica malo pliva, nemam taj osecaj postojanog kontakta sa asfaltom. E sad, putevi su bili vlazni sinoc i moguce da gume jednostavno nisu na tom nivou, pa da je zbog toga. Iako je 159 nizi auto, cini mi se da se vise naginje u krivinama, i svakako su promene pravca tromije a stabilnost u brzim krivinama nesto veca Vidi amorte za ovo "plivanje", čisto da nije do njih, a zanošenje...159 je ipak teži od Giuliette, masa je mama Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 3, 2022 Da, gume, optika, amorti, tim redom proveravam… svakako nije predvidjeno da se tako ponasa Quote Share this post Link to post Share on other sites
Quadrifoglio Verde 9319 Posted February 3, 2022 Jednostavno si navikao na Đulijetinu vožnju pa ti je sad 159 možda malo čudna. Takva je ona, teža, mekša i pliva... Rekao bih da je sve u redu s njom. Recimo, buljavoj guzu teško da možeš da izbaciš u krivini, dok se kod debele to relativno lako radi na standardnom ogibljenju. Uostalom, nisi je za trke uzeo. Srodićeš se s njom vrlo brzo. 3 dekirs, horvat and shuxx reacted to this Quote Share this post Link to post Share on other sites
Zan Batist 252 Posted February 4, 2022 23 hours ago, horvat said: E pa mogu da napisem par reci o nekom poredjenju sa Giuliettom ka seminarski bog te vidio... 2 horvat and darkman14 reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 4, 2022 Danas odradjena optika, sve perfektno. Majstor pohvalio, a i sve vrednosti su u merama, jednake po stranama. Milina. 5 neshaoct, Quadrifoglio Verde, dekirs and 2 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 4, 2022 Hunter danas 5 10 Reacher Gilt, Quadrifoglio Verde, Dzimbo and 12 others reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 4, 2022 Hahahahaha Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted February 4, 2022 On 2/3/2022 at 9:00 AM, horvat said: Imam neko hukanje za koje jos uvek nisam nacisto od cega dolazi. Može da bude ležaj točka. Češće je dosta sa prednjim točkovima zbog težine napred... 1 horvat reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 4, 2022 Pomogao mi jedan clan sa arcs foruma, izgleda da je unutrasnji lezaj poluosovine. Veoma se slicno cuje kao lezaj tocka, samo se zvuk ne pojacava u krivini i prestaje na stisak kvacila... Sam lezaj nije skup, ali ga je jako tesko pronaci, posto nema kataloski broj, nego se uzima po dimenzijama. 5 dekirs, djomla, Quadrifoglio Verde and 2 others reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 5, 2022 Danas zamenjen prednji znak. Poucen iskustvom sa Giuliette, prelakirao sam ga bezbojnim lakom u nadi da ce potrajati duze Takodje sajle menjaca podmazane sprejom za lance. I u kabini i u motornom prostoru. Osetna razlika, lakse ide rucica sad 5 Dzimbo, Mijailović P., djomla and 2 others reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 6, 2022 25 IgorBG, YUgisa, Dzimbo and 22 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 7, 2022 Auuuuu Horhe vrhunski gledao sam slike 15 minuta 3 djomla, horvat and neshtry reacted to this Quote Share this post Link to post Share on other sites
