ISV_01 4032 Posted August 7, 2021 (edited) Menjao sam zadnje i ostao levi zadnji zvucnik u odlicnom stanju. Dimenzija 13' sa sve drzacem. Neostecen i radio je odlicno, sve citavo. Odgovara i za Fiat Stilo i mozda za jos neki. Poklanjam ga kome treba. Ne saljem postom, licno preuzimanje na FLSC okupljanju ili licno na NBG (Enjub 45 blok) ili po nekome saljem (isti licno preuzima na gore navedene nacine). Kontak: 066-032-502 Ivan Edited August 7, 2021 by ISV_01 Dopuna 2 Reacher Gilt and igor0511 reacted to this Share this post Link to post Share on other sites
ISV_01 4032 Posted September 4, 2021 I dalje poklanjam. Share this post Link to post Share on other sites
Ivan 17666 Posted September 4, 2021 Kladim se da u oglasu nisi tagovao Micu... Ili je video, ali neces da mu platis postarinu. Ako, ako, kad si se stisao neka ti kupi prasinu. 3 Axic, Reacher Gilt and igor0511 reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted September 5, 2021 (edited) Evo ja se javljam. Počeo da trtka juče baš zadnji levi. Nego to preuzimanje me kolje... a što ne bi poslao kurirom ? Edited September 5, 2021 by Rasta Share this post Link to post Share on other sites
ISV_01 4032 Posted September 5, 2021 Iskreno me mrzi da se cimam po postama/kurir sluzbama. Mozda kada mi stigne nesto sledece sa Alija pa ponesem zvucnik i tad ga posaljem ali u ostalim slucajevima stvarno ali stvarno ne mogu da se guram sa penzosima (sa postexpressom imam vrlo pozitivna iskustva, samo zbog toga). Nista kolega @Rasta, cuvacu ga za tebe pa kada te put nanese na BG ili na Suboticu (sl nedelje sam na pruzi Horgos). Osim ako se ne smoris od cekanja pa pazaris do tada druge 1 Reacher Gilt reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted September 7, 2021 Ipak nemoj, ne znam zaista kad ću u severne krajeve, ali sigurno ne skoro. Daj ga slobodno nekom ako se javi. 1 ISV_01 reacted to this Share this post Link to post Share on other sites
ISV_01 4032 Posted September 7, 2021 Važi se, dakleM i dalje poklanjam Share this post Link to post Share on other sites
Ivan 17666 Posted September 7, 2021 Kad je tesko, zovi Micu... Lepo ti kazem da samo on moze da te spasi, doduse ako platis postarinu . 2 Axic and shuxx reacted to this Share this post Link to post Share on other sites
Dale 6809 Posted September 8, 2021 Kada i @Rasta zameni oba pozadi, onda poklonite nekom trecem par originalnih zvucnika. Stavite oglas "Poklanjamo par original zadnjih zvucnika za bravo, levi u BGu, desni u Soko Banji" Sala mala. Evo ako je u opstem interesu, preuzecu ja negde i poslacu Rasti. Jedino pretpostavljam da ce morati da saceka vikend da preuzmem jer radim popodne radnim danima dok vecina pa i @ISV_01 verovatno ujutru. 3 Reacher Gilt, darkman14 and djomla reacted to this Share this post Link to post Share on other sites
ISV_01 4032 Posted September 8, 2021 2 hours ago, Dale said: Jedino pretpostavljam da ce morati da saceka vikend da preuzmem jer radim popodne radnim danima dok vecina pa i @ISV_01 verovatno ujutru. Jedino ako ides za Horgos, na terenu sam do utorka Share this post Link to post Share on other sites
Dale 6809 Posted September 8, 2021 Ne, ali kada se sklope kockice, naci cemo se u BGu. Eto mozda na skupu nekom i onako nikada nisam isao na naki od njih. 1 ISV_01 reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted September 8, 2021 Nije problem, kad stignete, privremeno sam zatanjio zadnje da ne trtka ... Share this post Link to post Share on other sites
ISV_01 4032 Posted September 25, 2021 Ode zvucnik kod Daleta Moze lock. 1 Woodoo reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted October 7, 2021 (edited) unlock fala drugari ! stigo danas gratis zvučnjak, čak je i poštarina bila plaćena. imate od mene pijenje kad dovezete tašte u banju ! Edited October 7, 2021 by Rasta 3 3 djomla, Dzimbo, Dale and 3 others reacted to this Share this post Link to post Share on other sites
Ivan 17666 Posted October 7, 2021 Svaka cast, pravi primer pomalo utihle forumske saradnje . 5 hours ago, Rasta said: stigo danas gratis zvučnjak, čak je i poštarina bila plaćena. @MS PK na aparatima . Kako taj zvucnik nije zavrsio malo juznije? 6 1 Dzimbo, ISV_01, Dale and 4 others reacted to this Share this post Link to post Share on other sites
MS PK 7732 Posted October 7, 2021 Prepustio sam ga Послато са SM-A307FN помоћу Тапатока 4 Woodoo, Dzimbo, Reacher Gilt and 1 other reacted to this Share this post Link to post Share on other sites
Dale 6809 Posted October 8, 2021 Ne zna Rasta koliko ja mogu da popijem... Samo jos tastu da ubedim da joj treba banja... 1 2 Reacher Gilt, MS PK and Dzimbo reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted November 7, 2021 Unlock II pre neki dan reko' aj' konačno da zamenim zvučnjak, i skinem mrežicu, kad ono trtkanje prestade dakle, nije trtkao zvučnjak, već mrežica jbg. tako da ništa, ako nekom treba, šaljem kurirom o svom trošku, a može i lično naravno. Share this post Link to post Share on other sites
bogar 22 Posted April 23, 2022 Ako je jos akrivno, treba meni zadnji zvucnik. Moj zadnji desni otisao u nepovrat. Share this post Link to post Share on other sites
ISV_01 4032 Posted April 24, 2022 @bogar Nije druze odavno, dobio je kolega zvucnik. 1 bogar reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted April 24, 2022 (edited) Dobio, i na kraju ga čak (jedva) i montirao ... ima jedno mesec dana ... Tako da zvučnik više nije aktuelan, voza se u mom bravo-u već treću 'iljadu kilometara ... Edited April 24, 2022 by Rasta 1 bogar reacted to this Share this post Link to post Share on other sites
