Ivan BG 574 Posted July 2, 2021 (edited) Stig'o zamenik. Za sada je OK. Edited July 12, 2021 by neshaoct split Topic 10 Dzimbo, Axic, gorank82 and 7 others reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1056 Posted July 3, 2021 Koliko je lepsa ova tabla u restylingu.. kao i volan. Moze vise slika slobodno 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
totti 12525 Posted July 3, 2021 FLCS 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
igor0511 1763 Posted July 3, 2021 Neka te lepo sluzi naslednil napisi malo o poredjenju Leona i Alfe i kakvi su prvi utisci. Bas me zanima da li dolazi do izrazaja razlika u klasi 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
MS PK 6527 Posted July 3, 2021 Ma jok, isto sve 1 1 gorank82 and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted July 4, 2021 (edited) On 7/3/2021 at 8:53 AM, rkoma1986 said: Koliko je lepsa ova tabla u restylingu.. kao i volan. Moze vise slika slobodno Evo koje slike: On 7/3/2021 at 10:38 AM, igor0511 said: Neka te lepo sluzi naslednil napisi malo o poredjenju Leona i Alfe i kakvi su prvi utisci. Bas me zanima da li dolazi do izrazaja razlika u klasi Hvala. Oseca se razlika, jos je rano za utiske, idemo za CG veceras, pa cemo da vidimo kako ce da se ponasa. Edited July 12, 2021 by neshaoct formatiranje 7 Mijailović P., igor0511, Axic and 4 others reacted to this Quote Share this post Link to post Share on other sites
danijel55 595 Posted July 4, 2021 Ne gine ti crna boja.Nek sluzi auto. 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted July 12, 2021 (edited) Bili do CG, vratili se, Leon je to pregurao bez ikakvih problema. Od kad sam ga uzeo (pre 9 dana) presao sam sa njim nesto preko 1300km, od toga put do CG (H. Novi) preko BIH je bio 1135km, dole po primorju se nismo puno vozali jer smestaj u kom smo bili nije imao svoj parking, vec smo "zaboli" neko mesto i tu bili do kraja, s'tim da smo se jedan dan spustili do Perasta. Potrosnja po bordu je na tih 1135km, 4.7L, prosecna brzina 53km/h, u cekanju na granicnim prelazima smo sigurno proveli 4h, klima tu i tamo zavisno od potrebe. Cepovan je 2 puta u Bosni pa cu sa nekim od sledecih tocenja proveriti sta bord kaze i koliko laze. Preuzeo sam ga sa potrosnjom od 6.0L (po bordu) na 100km, kod prethodnog vlasnika je vozen na relaciji Ledine - B. Kosa - Ledine. Odprilike da smo dobili sta smo trazili, manji auto koji se lakse snalazi u gradu a koji opet koliko-toliko dobro snalazi na otvorenom putu. Razlika u klasi u odnosu na AR 159 se oseti, koliko mi je Alfa bila bolja da otvorenom toliko mi on bolji u gradskoj voznji, realno enterijer je kvalitetniji kod Alfe, ume i on da "skripucka", zvucna izolacija je tu negde, buka koja dolazi od podvozja prigusenija kod Alfe, ali je zato motor tisi kod Leona (1.9 TDI, 105ks, 250nm), oseca se da je slabiji od nje (1.9 JTDm, 150ks, 305nm), za moje potrebe i ocekivanja Leon, vuce sasvim dobro, a sto se tice udobnosti, po mojim merilima Leon je udobniji od AR 159. Jeste da je germanizovani Španac, ali nije bas toliko sterilan kao ostali modeli iz WAG grupe tih godina a posto je kao model restyle, tabla mu je dosta lepsa od one koju je nosio pre restajlinga, ali bi i dalje mogla biti dalekooo lepsa, posebno onaj centralni deo, satove i volan su lepo resili. Nisam napisao nesto o autu od podataka, uzet je od vlasnika kod je bio od uvoza (dec. 2018). Model je za 2010-tu, AMSS ga je vratio na '09, proizveden je decebra 2009, prva reg. je 29.12.2009.-te, uvoz je iz Francuske, sa 203k na satu (video sam slike sa licitacije, ta KM je na slikama), ta KM je na papirima od uvoza, na slikama dok je bio na šlepu....odmah po uvozu mu je uradjen veliki servis i mali servis kao i zamena seta kvacila sa plivajucim zamajcem (203859km), a zatim kasnije tokom upotrebe, kompresor klime, akumulator...i sl. sve uredno zavedeno u servisnoj iz servisa V&B Auto Centar na Ledinama, pa gume zimske pa gume letnje.... Igla je stavljena, OBD izmesten, servisna istorija od uvoza u SRB poznata, uzeo sam ga sa 221600km, prvi vlasnik je presao sa njim nekih 18.000km za 2.5 godine. Odmah po preuzimanju napravio sam mu rezervni kljuc i sa ECU-a odjavio onaj sto je izgubljen. Nisam stigao pre puta da mu uradim mali servis (poslednji je uradjen na 214k ali decembra 2019-te pa je probio vremenski interval), pa sam mu danas uradio mali servis sa zamenom svih filtera, zamenu zadnjih diskova i plocica i zamenu zadnjeg silen bloka na levoj viljusci, nema potrebe za drugim trenutnim ulaganjima. To je za sad to.....videcemo kako ce biti na dalje. Edited July 12, 2021 by Ivan BG 9 djomla, Dzimbo, gorank82 and 6 others reacted to this Quote Share this post Link to post Share on other sites
Dale 5364 Posted July 12, 2021 1 hour ago, Ivan BG said: Jeste da je germanizovani Španac, ali nije bas toliko sterilan kao ostali modeli iz WAG grupe tih godina WAG su sterilni-bezlicni, ali je zato leon ruzan! Sala naravno! Uvek me je odbijao enterijer kod ove generacije, ali je restajlingom to malo popravljeno. Inace je utisak uzivo lepsi nego na slikama i takodje, vrlo je praktican unutra. Bas mi je bilo prijatno iskustvo kada sam vozio jedan beli FR iz te generacije. Definitivno prakticniji auto od prethodnog ako su tvoje potrebe takve kako kazes, vecinom grad. U 159 nije uopste lako uci i izaci ako si malo iznad proseka visine, dok je Leon mnogo prakticniji plus laksi za parking. Mislim da ces i motorom u njemu biti zadovoljan. Da te sluzi lepo, cestitam na kupovini! 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted August 1, 2021 Pali, radi, ide, ispunjava trazeno.......prodje mesec dana i 2000km od kad sam ga uzeo. Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted September 12, 2021 (edited) Odusevio me je potrosnjom, sipao sam do cepa, bilo je vise od rezerve, 50.35L je stalo. Presao sam 990km, range je pokazivao da ima goriva za jos 40km, do cepa sam uspeo da sipam 57.68L. Zanimljivo da mu je odredjivanje autonomije tacno, pun do cepa je pokazivao da ima goriva za 960-1050km (smenjivao je te dve cifre) a eto presao sam 990+40 sto je pokazao da moze jos. Rezervar je po uputstvu 55L, prvo cepovanje stalo je 50L, drugo 57L, kapiram da max moze da stane 62/63L. Prvo cepovanje u rezervaru je bilo jos da kazemo 1/4, mozda nesto sitno manje, a drugo cepovanje, upalila se rezerva. Gorivo je naravno sipano u BIH. Edited September 12, 2021 by Ivan BG Sredjivanje slika i dopuna. Quote Share this post Link to post Share on other sites
danijel55 595 Posted September 12, 2021 5.7l potrosnja? Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted September 13, 2021 Tako ispada. Posle potrosnje koju sam imao sa AR 159, od 8-9-10 ili cak i vise litara na 100km, ovo je vise nego odlicno. Quote Share this post Link to post Share on other sites
danijel55 595 Posted September 14, 2021 Koja je prosecna brzina sa tom potrošnjom? Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted September 19, 2021 Nemam pojma, posto prosecnu brzinu pokazuje na dnevnom nivou, nema je ono da racuna dok ne resetujes bord. Uglavnom 50% otvoreno, 40% grad i 10% po Borci, relacije po 1-2-3 km. Odprilike da je takav sastav voznje. 1.6 TDCi (HDI) koji sam imao u bivsem C Max-u, je imao slicnu potrosnju, od 5.8 do 6.2L. 1 Axic reacted to this Quote Share this post Link to post Share on other sites
sasami 0 Posted October 9, 2021 Lep autić ali neozbiljan naslednik posle 159-ke, gde je giulijeta 2.0jtd 170ks? Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted October 9, 2021 Kako dosta vremena provodim u gradu, gde ima kamera i radara na svakom cosku/raskrsnici....nema se gde voziti kako treba ni ovih 105 ks. Videcemo mozda za godinu ili dve padne neka Gullietta, nikad se ne zna. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted November 5, 2021 (edited) Pre par dana sam Leona oterao da kod lakirera da mu sredim haubu, desno krilo i suvozaceva vrata. Hauba je imala ostecenja od kamencica, a desno krilo i suvozaceva vrata su bila ostecena, takav je kod mene stigao, (takav je i uvezen u SRB, na slikama sa šlepa sa kraja 2018-te, se vide sva ova ostecenja) sa napomenom da sam ja napravio ovo ostecenje na krilu, iznad samog tocka, pre nekih mesec dana nesto bio u krugu KCS, kisa, tesno, i prislonim ga uz jedan visoki stubic. Zadovoljan sam uradjenim, boja i broj kristala je savrseno pogodjen, bas treba strucno oko da bi primetilo da je ista farbano. Eto slika pre i posle, ove posle nisu nikakve i napravljne su odmah po preuzimanju auta jer nema smisla prati auto, kad konstatno vec par dana pada kisa. Pre: Posle: Edited November 5, 2021 by Ivan BG 3 darkman14, dach@ and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted November 20, 2021 (edited) Summer... Winter... Edited November 20, 2021 by Ivan BG 1 silenci reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted December 11, 2021 (edited) Produzena registracija, total 31500 na premijski stepen 4. od tih 31500, 4500 je tehnicki pregled. Prosao je bez ikakvih problema. Miran sam do decembra sledece godine. Edited December 11, 2021 by Ivan BG 1 silenci reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted January 23, 2022 (edited) Čari crne boje.... Edited January 23, 2022 by Ivan BG 1 3 1 Rile_bg, ISV_01, PremieRacing and 2 others reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1056 Posted January 23, 2022 Moj je ocaran od oktobra do aprila 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted January 23, 2022 Ja se trudim koliko mogu da bude cist, prvenstveno zbog sebe, perem na samousluznoj perionici 2 puta nedeljno, al crna je crna i tu nema mnogo ponoci. 2 PremieRacing and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
gorank82 163 Posted January 23, 2022 Katastrofa je crna boja video sam to na Meganu, malo mi je laknulo od ove sive iskreno... Quote Share this post Link to post Share on other sites
Ivan BG 574 Posted January 23, 2022 Ja sam rekao posle AR 159 da vise necu uzeti karavana i crn auto. Karavan sam izbegao, a crnu boju nisam, izbor je bio takav da je bilo ako ne uzmem ovog (Leona) ne idemo na more, jer sam uspeo da prodam 159, 15 dana pred polazak...i tako uze ponovo crn auto. Gledao sam prvenstveno sive primerke A3 i G5, kao i Leona, ali ne vredi, nisu valjali. 1 gorank82 reacted to this Quote Share this post Link to post Share on other sites
