Nenad90 2 Posted July 1, 2021 (edited) Pozdrav,imam problem na Gp 1.48v.... Hladnjak,tj ventilator se pali dok je motor hladan.... Ponekad upali iz prve a nekad tek posle dva do tri puta...od skora mi i gori lampica check engine... Da li je mozda neki senzor u pitanju ili je nesto ozbiljnije ? Ako je neko imao slican problem neka napise... Edited July 11, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted July 1, 2021 Nesto sa temperaturom mozda, cim pali ventilator na hladan motor... Senzor istih, termodavac i ostalo? Quote Share this post Link to post Share on other sites
totti 13151 Posted July 1, 2021 Ventilator tako može odmah da pali i zbog neispravne lambda sonde npr... Quote Share this post Link to post Share on other sites
Nenad90 2 Posted July 1, 2021 Inace lampica prestaje da gori posle 5-10 min voznje.... Primetio sam da malo slabije vuce izmedju prve i druge,ali imam ga od skoro...mozda je to samo do lenjog motora... Quote Share this post Link to post Share on other sites
Nenad90 2 Posted July 6, 2021 U pitanju je senzor temperature motora.... Ako neko bude imao ovakav problem,da se zna 1 1 neshaoct and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Nenad90 2 Posted July 11, 2021 Zamenjen senzor temp.motora,problem i dalje ostao... Jutros pri paljenju isti problem i naravno lampica je i dalje tu.... Ima li neko ideju u kom pravcu sad krenuti ? Dijagnostika uporno ukazuje na senzor.... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted July 11, 2021 25 minutes ago, Nenad90 said: Zamenjen senzor temp.motora Stavljen nov? Baci pogled na ovu temu, videćeš tamo šta sve može da bude uzrok: - Punto mk.2a - non-stop se pali ventilator Quote Share this post Link to post Share on other sites
Nenad90 2 Posted July 11, 2021 Stavljen je nov.... Quote Share this post Link to post Share on other sites
jevta 251 Posted July 11, 2021 (edited) MAP senzor ? Isključi za probu Edited July 11, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Nenad90 2 Posted October 2, 2021 Da li su ovo simptomi Map senzora?.Poceo je da pravi probleme opet od kako je pocelo malo hladnije vreme... 1.Upali,digne malo obrtaje...gasi se. Ventilator ostaje da radi jos pola minuta nagon gasenja. 2.Kada konacno upali,posle 7-8 puta....nece da primi gas. Polako mu dodajem gas sve dok ga u jednom momentu ne primi I onda se gasi ventilator I normalno vozi. 3.Dijagnostika samo pokazala lose sagorevanje pri cemu mi je majstor zamenio svecice. Skidao sam Map senzor nije bio prljav,malo sam ocistio... Posle toga je tri jutra palio na pola kljuca ali se onda vratio problem... Ako je neko u skorije vreme imao ovakav problem neka napise... Quote Share this post Link to post Share on other sites
stex_pb 736 Posted October 16, 2021 @Nenad90Proveri creva na usisu. U mom slučaju je bio problem sa probušenim crevom za iberlauv, i tu je vukao falš vazduh i poremetio sve moguće. 3 dana sam se zezao sa MAP senzorom a nije bilo do njega. 1 1 Nenad90 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
Nenad90 2 Posted October 20, 2021 (edited) Dijagnostika pokazuje senzor temperature vode ?? Da li je moguce da ima dva senzora temperature vode i motora ? Senzor temp.motora sam promenio. Edited October 20, 2021 by Nenad90 Quote Share this post Link to post Share on other sites
stex_pb 736 Posted October 28, 2021 Svaki auto ima senzor temperature vode i senzor temperature uja u motoru. Quote Share this post Link to post Share on other sites
