integralac 2566 Posted June 20, 2021 Ok, taj filter menjam kakav god da je, ostalo ce ici na proveru Sutra ce valjda biti auto kod mene, sporo ide carina Quote Share this post Link to post Share on other sites
Ivan 17663 Posted June 20, 2021 (edited) 9 hours ago, DelPiero said: A i cuo sam da mogu da imaju problema i sa ventilom pritiska turbine,taj wastegate. U tom slucaju osovinica WG na izduvnom delu "zvrci" na oduzimanje gasa i oseti se u vuci pogotovo na vecim brzinama. Zavisi i u kom polozaju glavi. Resenje je ili reparacija u turbo servisu ili da se pokusa da se nadje samo njen izduvni deo (sto je igla u plastu sena jer naravno niko to nece da rasparuje). Generalno su turbine na benzincima mnogo vise na udaru, zbog dosta vecih temperatura izduva. Na MultiAir su pored ulja, dodatno hladjene i vodom. Edited June 20, 2021 by Ivan 1 DelPiero reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted June 21, 2021 (edited) 9 hours ago, Ivan said: ... Generalno su turbine na benzincima mnogo vise na udaru, zbog dosta vecih temperatura izduva. ... Edited June 21, 2021 by PremieRacing 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Ivan 17663 Posted June 21, 2021 Prsavela. IHI mozda, neke od njih su sklone tome? Quote Share this post Link to post Share on other sites
integralac 2566 Posted June 21, 2021 Protrulelo od stajanja Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted June 21, 2021 Jok, od vožnje...pun gas 8h, k'o na endurance p.s. jeste Ihi 1 horvat reacted to this Quote Share this post Link to post Share on other sites
integralac 2566 Posted June 21, 2021 Ja cu onda mojoj da skine, ako je nema ne moze ni da rikne 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted June 21, 2021 Ma nije turbo sa Delte, a i kad se koristi kako treba - sve moze da traje A kad teras 'bez mozga' moz' i nakovanj da slomis... 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17663 Posted June 21, 2021 6 hours ago, integralac said: Ja cu onda mojoj da skine, ako je nema ne moze ni da rikne Kod tebe bi trebalo da je Garrett, tacnije GT1238. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
integralac 2566 Posted June 21, 2021 Ma, nacipovacemo to pa sta bude 1 1 PremieRacing and Ivan reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted June 22, 2021 Dec D Spirit 2 Reacher Gilt and Ivan reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted June 22, 2021 Nego, ne reče kako se poredi s bravom ta delta, koliko bolje povlači, je l' manje bučan motor, i tako to? Za udobnost neću ni da pitam, ne sumnjam da je komforna. U zdravlju da služi, i da je lako prodaš kad dosadi! Quote Share this post Link to post Share on other sites
Ivan 17663 Posted June 22, 2021 (edited) @Rasta Trebalo bi da je primetna razlika sa MultiAir (ako mislis na poredjenje sa T-Jet 120). Bar je moj utisak bio takav kada sam probao sve njih (ukljucujuci i dizelase). Zato sam se i opredelio za tu verziju, koja me je na prvu voznju kupila lepim performansama za malog benzinca. Naravno, pod uslovom da je sve tip-top, pogotovo turbo (a iz Svice znaju da dodju sa problematicnim). Bravo je u toj verziji laksi oko 60 kg od Delte i ima trunku manji koeficijent otpora. Ali s druge strane, imas 20 KS i vise i sto je mnogo bitnije, skoro 30 Nm vise. Primetno lepse povlaci, pogotovo iz nizih obrtaja. A ako jos ima Sport mode - razlika je poprilicna, tu je MA 140 na skoro +60 Nm. Vidi se lako i po medjuubrzanjima i teoretski i u praksi (pogotovo "iz bunara" sa obrtajima), a i sam weight-power za ta dva auta je 10.5 vs 9.4 kg/KS. Takodje, trebalo bi i da je za tih 15%-ak posto stedljiviji. Edited June 22, 2021 by Ivan 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
integralac 2566 Posted July 1, 2021 (edited) Registrovana, ide, savrsenstvo, sredjuje se polako, zbog nekih obaveza ne stizem da zavrsim pa da poslikam malo Jedan jedini problem koji ima je Znaci treba mi jedna opruga, moze i par, ako neko zna nekoga ko zna gde ima neka ne cuti Edited July 1, 2021 by integralac Quote Share this post Link to post Share on other sites
Ivan 17663 Posted July 1, 2021 U kakvom je stanju turbo, da nisi slucajno kacio na dijagnostiku da ispratis parametre? To generalno na benzincima zna da bude slaba tacka. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
integralac 2566 Posted July 2, 2021 Nisam jos stigao, uhvatili me da radim neki namestaj pa zurim to da otkacim Ulje sam zamenio a ne stigoh ni da resetujem, svitka mi kilometraza non stop Za par dana cu da joj se posvetim kako treba, bacicu izvestaj ovde, mislim da je dobar poprilicno Jedino moram ovu oprugu da resim brzo, kaze majstor moze ovako da ide ali zasto rizikovati Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 2, 2021 Znaci na Fiat grupaciji opruge pucaju posle 200k kao od sale... Bar sam i ja to preziveo bez posledica. Danas sam se sagnuo ispod golfa 6 2010god uvezen iz nemacke i prizor me je zaprepastio, auto truo odole naopako most od zadnjeg trapa truo kao djavo, tako da pucanje opruge nije strasno Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted July 2, 2021 Meni isto ovako pukla opruga pre par meseci, bukvalno isto. Nova fabrička opruga, jedna, je 180€. A par Eibacha je 100 €... Gesendet von meinem KB2003 mit Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17663 Posted July 2, 2021 10 hours ago, integralac said: Ulje sam zamenio a ne stigoh ni da resetujem, svitka mi kilometraza non stop Ako nisi - MA filter, MA filter, MA filter . Koje uJe si sipao? Quote Share this post Link to post Share on other sites
integralac 2566 Posted July 3, 2021 Ovih dana, samo da namontiram ovu kuhinju sto radim, gastarbajteri vole to precizno u dan, nema kasnjenja Oprugu moram brzo da resim, ne znam kako lezi sad u solji, mozda izleti, dal pasuje od Brava? Quote Share this post Link to post Share on other sites
Ivan 17663 Posted July 3, 2021 Zavisi verovatno i od verzije i motorizacije. Unesi svoj VIN u ePer, pa proveri Compatibility listu za svoje prednje opruge. Da li mozda iste idu na jos neke modele grupacije. Pogledah upravo cisto informativno da li bi ti pasovalo sa mog MultiAir - ali tamo kaze da su samo za ovu Sport verziju (to su one najnize opruge sa 3 tackice). Tj. fizicki mozda i moze , ali u ePer nije navedeno zbog verzija. Quote Share this post Link to post Share on other sites
integralac 2566 Posted July 3, 2021 Rekao bih da ne pasuju https://www.pekidi.com/navi?SGRP_COD=1&VEHICLE_NO=01106070&MONTH=3&COMM_MODEL=DEL&SBMK=L&COUNTRY=001&DRIVE=S&MVS=181581101000&YEAR=2013&COLOUR=423&MAKE=L&CHASSIS_NO=ZLA84400001114846&DAY_OF_MONTH=14&CAT_COD=TN&GRP_COD=443&SGS_COD=44301-020&ENGINE_NO=1798893&LANGUAGE=3&ALL_FIG=0&RMODE=DEFAULT&KEY=PARTDRAWDATA&EPER_CAT=SP&GUI_LANG=3&ALL_LIST_PART=0&PRINT_MODE=0&PREVIOUS_KEY=SUBGROUP_7&SB_CODE=-1&WINDOW_ID=1&ALL_LIST_PART=0# Quote Share this post Link to post Share on other sites
Ivan 17663 Posted July 3, 2021 Po ePer je tako, e sad da li budze ... Kaze samo za Deltu T-Jet 120 i MA 140 (bez SDC): Quote Share this post Link to post Share on other sites
integralac 2566 Posted July 3, 2021 More cu da zbudzim nesto 2 Ivan and Dale reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted July 4, 2021 Zavari jbt il stavi vezicu Послато са SM-A307FN помоћу Тапатока 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
