neshtry 14778 Posted May 24, 2022 Skroz,da ga nema? Zašto?Kod mene je samo plastika odustala,postala krta od sunca i pukla... Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
PremieRacing 5296 Posted May 24, 2022 E, sad... nemam pojma, naopako sam rođen? Aj' neko lakše pitanje 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted May 24, 2022 Ja koji pokušavam da se setim kada sam upalio zadnji brisač Sent from my Redmi Note 8 Pro using Tapatalk 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted May 24, 2022 Kod mene radi često,u Vojvodini ima baš puno prašine koja stiže iz atara, pogotovu kada su neki veliki radovi na njivama....drug zbog oblika zadnjeg dela,,kada pada kiša, sve baca na zadnje staklo...[mention=3605]PremieRacing[/mention] to i pitam [mention=17583 @Djuk85 https://www.facebook.com/192244702090/posts/10158625794667091/?sfnsn=mo Sent from my iPhone using Tapatalk 2 darkman14 and Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted May 24, 2022 2 hours ago, neshtry said: Skroz,da ga nema? Zašto? Weight reduction, bro . 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted May 24, 2022 Tačno 100 grama Sent from my moto g(8) using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17587 Posted May 24, 2022 1 1 neshtry and Axic reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted May 24, 2022 @Ivan skoro su u nemačkoj uhapsili lika koji je na autobanu vozio tako olakšan auto...https://www.jutarnji.hr/autoklub/aktualno/njemacka-policija-zaustavila-vozaca-a-kad-je-otvorio-vrata-ostali-su-u-cudu-na-cemu-je-sjedio-15200547 Sent from my iPhone using Tapatalk 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted June 30, 2022 Prslo mi hlađenje,izgleda dihtung glave…kako da proverim,zna li ko? koje su manifestacije loše pumpe za vodu? 1 horvat reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted June 30, 2022 Losa pumpa za vodu bi mozda curila ili se auto pregreva? A test za dihtung glave, test prisustva izduvnih gasova u rashladnoj tekucini. To imaju neki serviseri, a moze i da se kupi na KP ili po prodavnicama alata. Onako epruveta neka sa tecnoscu, pa promeni boju... Quote Share this post Link to post Share on other sites
neshtry 14778 Posted July 1, 2022 Luftiram na luftreu na hladnjaku,ima vazduha koliko hoćeš….Ide kod majstora danas,pa ću videti…Hvala Igore Sent from my iPad using Tapatalk 2 horvat and shuxx reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted July 1, 2022 Bas napisi sta je bilo... Quote Share this post Link to post Share on other sites
MS PK 7728 Posted July 1, 2022 Cim stalno ima vazduha onda je verovatno dihtung, kod punta bese puca na prvom ili cetvrtom klipuПослато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
PremieRacing 5296 Posted July 1, 2022 41 minutes ago, horvat said: Bas napisi sta je bilo... Bio kvar. 3 Axic, horvat and darkman14 reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted July 3, 2022 Beheaded….Kaže majstor dihtung glave je iz prve ugradnje Sutra kontrola glave i ravnanjeSent from my iPad using Tapatalk 4 horvat, Reacher Gilt, Djuk85 and 1 other reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted July 4, 2022 Glava sređena,ne bez problema,ali sređena…. Kupljen i termostat i dihtunzi za izduvnu granu… Sada je sklapanju Biće 14k dinara sve komplet 2 dach@ and horvat reacted to this Quote Share this post Link to post Share on other sites
shuxx 10773 Posted July 4, 2022 Jel glava prana, odmascena, izgleda Kao Nova....Koliko para je ravnanje / brusenje glave?Sent from my SM-A536B using Tapatalk Quote Share this post Link to post Share on other sites
neshtry 14778 Posted July 4, 2022 4000 je provera i ravnanje glave uvek je očiste i operu Quote Share this post Link to post Share on other sites
Ivan 17587 Posted July 4, 2022 3 hours ago, neshtry said: Biće 14k dinara sve komplet E jbg, izgleda da si sam sebe urekao pricom da na 1.2 Punticima nema nista skuplje od 5.000 din... 2 shuxx and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
neshtry 14778 Posted July 4, 2022 Dihtung glave motora 1200 dihtunzi izduvne grane 2x600 Termostat 1000 antifriz +dest voda 1500 ispitivanje i ravnanje glave 4000 ostalo je majstor 1 Nikola031 reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 4, 2022 Nije to skupo...Sent from my Redmi Note 8 Pro using Tapatalk 2 neshtry and darkman14 reacted to this Quote Share this post Link to post Share on other sites
Axic 19961 Posted July 4, 2022 Prokleti 1.2 8v, tera i tera, kad mu pukne zupčasti stavi se drugi i tera opet do besvesti ali taj jbni dihtung kad tad kod svakog napravi problem i večito masan oko glave i bloka. 2 shuxx and neshtry reacted to this Quote Share this post Link to post Share on other sites
shuxx 10773 Posted July 4, 2022 Moj je imao 53K km kad sam ga kupio, i slinavio. Sreca sto za 20€ resava se trajno problem. Sent from my SM-A536B using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
pilgrim011 166 Posted July 4, 2022 9 hours ago, neshtry said: Biće 14k dinara sve komplet Mnogo jeftino, mene na Punto mk1 1.1 koštalo sve (ali kod mene je spisak urađenog bio dosta duži od tvog, to se sećam) oko 28.000. Quote Share this post Link to post Share on other sites
darkman14 5892 Posted July 4, 2022 Ček, jel postoji razlika u ceni što se ravnanja glave tiče? Meni sve u glavi da je oko 100-120 eur za tipa 1.9jtd/mjet 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
