IlijaBogi 0 Posted February 11, 2021 Radio sam mali servis i dijagnostiku juce nista mi ne pokazuje, a na kompijuteru mi izbacuje da mi greje motor i moram da stanem, antifriz je pun. Sta moze da bude? Quote Share this post Link to post Share on other sites
skile86 539 Posted February 11, 2021 Mozda neki senzor temperature brljavi. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 11, 2021 Vidi dijagnostiku, moze da bude glupost, a moze da bude i nesto ozbiljno. Nemas potrebu da rizikujes, a mi samo mozemo da nagadjamo. Quote Share this post Link to post Share on other sites
IlijaBogi 0 Posted February 12, 2021 (edited) Nista ne pokazuje i to sam bas bio u bmw servisu motor je perfektan i ocuvan samo mi dize temperaturu... Edited February 13, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 12, 2021 Sta ti kazu u servisu, na sta oni sumnjaju? Quote Share this post Link to post Share on other sites
IlijaBogi 0 Posted February 12, 2021 (edited) Kazu da je mozda hladnjak zapusio ili neki termostat, sada ne rwzumem da moze neki deo da ode pokazalo bi na dijagnostici kvar Edited February 13, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Falcon 4 Posted February 12, 2021 (edited) pa ako je senzor temperature verovatno bi videli na dijagnostici ,ako je termostat onda nece videti na dijagnostici Edited February 12, 2021 by Falcon Quote Share this post Link to post Share on other sites
Falcon 4 Posted February 13, 2021 ako je termostat u pitanju ili zapusen hladnjak a senzor temperature na dijagnostici zaista pokazuje vecu temperaturu onda jeste nesto od tog dvoje ,,ako je temp na dijagnostici normalna onda vec treba traziti ,e sad pitanje dali su oni tebi rekli da se zaista greje ? jer ako ti kazes da dijagnostika nista ne pokazuje kod njih ,pretpostavljam da je temperatura normalna to me buni Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 13, 2021 Racunam da decko hoce da proveri koliko je realno to sto su mu majstori rekli, da ne pokusavaju da ga osisaju. Mislim da je skroz realno da bude termostat ili zapusen hladnjak, to nece prijaviti, jer nema senzor na njima, ali ima senzor temperature, on detektuje temperaturu i ne zna zasto je doslo do pregrevanja recimo. Quote Share this post Link to post Share on other sites
IlijaBogi 0 Posted February 13, 2021 (edited) Pa o tome ti pricam, bio sam u ovlascenom servisu i racunam da planiraju da me oderu. Videcu sa nekim privatnim majstorom koji radi kod kuce sta i kako, javlja povecanje temperature, a meni je problem zato sto nemam da mi pokazuje kolika je temperatura moj model nema to na kokpit tabli. Edited February 13, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 13, 2021 Imas foru da udjes u skriveni dijagnosticki meni.Izgleda ovako otprilike, malo se razlikuje od modela do modela ali prikazuje te podatke koji te zanimaju.Послато са Mi MIX 2 помоћу Тапатока Quote Share this post Link to post Share on other sites
Falcon 4 Posted February 13, 2021 (edited) odakle si ? ako si u ns javi da pogledamo, sto kazu nisam ovlascen al mogu da pogledam Edited February 13, 2021 by Falcon Quote Share this post Link to post Share on other sites
totti 13160 Posted February 13, 2021 Ti prvo sebi sredi taj check engine sa avatara Sent from my SM-G770F using Tapatalk 1 Falcon reacted to this Quote Share this post Link to post Share on other sites
