Aca12345 0 Posted December 12, 2020 (edited) Imam problem sa Grande Punto posle pranja upali mi sve greske Edited December 12, 2020 by neshaoct split Topic Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted December 12, 2020 @Aca12345 Da li ga puskiras? Da li su zasticeni osigiraci sa plastikom? Nesto vec brljavio elektroniku i ranije ili samo posle pranja? Dodatno, koji agregat je u pitanju? Quote Share this post Link to post Share on other sites
Aca12345 0 Posted December 12, 2020 (edited) 1.3multijet samo posle pranja i kad se osuši posle radi normalno Edited December 12, 2020 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted December 12, 2020 Kao sto pomenuh, jesu li osiguraci zasticeni (prekriveni)? Suspleh da li posedujes? Ako puskiras kroz gril gde je hladnjak ili usmeris mlaz pod pritiskom niz soferku, hoce da napravi carlamu ako nemas plastiku na osiguracima. Cim se osuse, onda ti radi normalno. Ajd jos neko ce odgovoriti, al ja sumnjam na navedeno. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Aca12345 0 Posted December 12, 2020 (edited) Edited December 12, 2020 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted December 12, 2020 (edited) @Aca12345 Kao što te je već pitao @ISV_01, imaš li zaštitnu plastiku preko table sa osiguračima u motornom prostoru? Ta tabla sa osiguračima/relejima se nalazi desno od akumulatora (ka krilu). Plus, ova slika koju si postavio ne znači ništa. Kad već hoćeš da slikaš, slikaj onda instrument tablu nakon što startuješ motor. Merodavne su jedino greške koje ostanu da sijaju nakon što se startuje motor, ne one koje sijaju kad je auto na kontaktu... Edited December 12, 2020 by neshaoct dopuna Quote Share this post Link to post Share on other sites
Aca12345 0 Posted December 12, 2020 (edited) Ovo ti je kad je startovan motor Edited December 12, 2020 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted December 12, 2020 @Aca12345 Što je onda obrtomer na 0? Ne radi ti obrtomer, ili...? Quote Share this post Link to post Share on other sites
Aca12345 0 Posted December 12, 2020 Tako cas radi čas ne Quote Share this post Link to post Share on other sites
Aca12345 0 Posted December 12, 2020 Sve je zaštićeno i osigurači i neka kutija na akumulatoru ali su malo žice gole do kompjutera mislim da to pravi problem veliki Videcu danas sam ostavio kod majstora Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted December 12, 2020 Malo gole žice do ECU?!?? Imaš sreće što uopšte pali i ide! Quote Share this post Link to post Share on other sites
