Nikola JTD 230 Posted March 27, 2021 Pa samo sto sam okacio, jednu stranu u nazad vidi, ima 2 linka. Share this post Link to post Share on other sites
PremieRacing 5297 Posted March 29, 2021 Odjava - STOP. Share this post Link to post Share on other sites
Nikola JTD 230 Posted April 16, 2021 Proba bez dtc-a, zimski set jos uvek: https://streamable.com/wg6c4v Share this post Link to post Share on other sites
DraganUS 449 Posted April 16, 2021 7? 1 Bingodalton reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted April 16, 2021 Ma da, al sam i u prvoj i u drugoj otisao u blokadu na sec. Ne mogu telefon, volan, menjac, al spustam ga ispod 7 samo da prebacim na letnji set i da nabavim neku kamericu, ovako ne moze...i narqvno da vezbam Share this post Link to post Share on other sites
Nikola JTD 230 Posted May 7, 2021 (edited) Mala proba na auto putu. 210 na 3650rpm. Isao sam do 220, snage ima za vise naravno ali su gume T oznake i nije za neko eksperimentisanje... potrosnja na otvorenom na 230km 5.6 sa klimom . Pun auto ko cep, rez do vrha. Iznanadio sam se recimo na 160 kad se doda gas kako povlaci da osetis povlacenje. Edited May 7, 2021 by Nikola JTD 4 vicent, Axic, vagenovac and 1 other reacted to this Share this post Link to post Share on other sites
danijel55 699 Posted May 7, 2021 Taj motor i bez čipa ide iznenadjujuce dobro 2 vagenovac and MS PK reacted to this Share this post Link to post Share on other sites
vagenovac 4533 Posted May 8, 2021 Fenomenalan motor, neverovatno kvalitetan i izdrzljiv. Koji bi drugi motor izdrzo onakva lupanja i rad sa losim diznama da ne progori blok ili ko zna sta. A uz to izuzetan razvoj snage, potrosnja, ma sve. Jedino sto ima skup veliki servis... Share this post Link to post Share on other sites
Nikola JTD 230 Posted May 8, 2021 To se jednom uradi, kazu kad se uradi zamena lanca, vise se ne radi jer su svi zamenski setovi sa tim poboljsanjima...bar tako kazu majstori, a i na stranim forumima sam isto nasao. Kod mene je zamenjen tako da ne brinem, radi kO doxa. Uskoro se rastajemo nazalost, i bice bolno... Stize mi sluzbeni auto pa ce biti ovde na oglasima. Share this post Link to post Share on other sites
vagenovac 4533 Posted May 8, 2021 Razumem te skroz, brat ima sluzbeni auto 24h koji moze da koristi i u privatne svrhe, te svoj auto pali bukvalno jednom nedeljno da se provoza za svoju dusu. A posto nema gde da ga drzi kod sebe, drzi ga kod mene, ajd ne smeta mi, ali mu nije pri ruci i kada zeli da ga provoza, vec mora da se cima. Share this post Link to post Share on other sites
Nikola JTD 230 Posted May 8, 2021 Pa da, gubi se svrha registrovati nesto sto ces paliti retko...pritom i odrzavanje , a ima pametnijih stvari za uloziti nego u auto koji stoji. Sluzbeni dobijam na korisnjene 24/7/365 i gorivo, tako da Bembina mora na oglase. 1 MS PK reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted July 26, 2021 Auto ce kroz 10-15 dana biti na prodaju. Mozda i ranije. Ako ima zainteresovanih, javite se. Ide sve uz auto sto imam, 18ice+16ice, zamajac, dizne, registrovao sam ga pre mesec ipo dana, pa ko zeli nek se javi Share this post Link to post Share on other sites
PremieRacing 5297 Posted July 27, 2021 Ima. Cena ispod 5 ? Share this post Link to post Share on other sites
Nikola JTD 230 Posted July 27, 2021 (edited) Stranci na ime su oko 4200-4500 Stock verzije. Cena moja za forum ce biti 5300e ( Bez alu felni/guma, dizni, zamajca moze za 5000e kome se isplati ) Registrovan je do 11.6.2022 Mali servis uradjen pre 4000km Lanac je takodje menjan ( Servis Floyd potvrdio, a i ne cuje se ni hladan ni vruc ni najmanje ) na GP Evo mi se nov lanac cuo, ovde ne. Na autu su celicne felne sa gumama Hankook oko 7mm sare, 2019god M+S. Te je i ste strane vlasnik miran ako ne zudi za 18icama Edited July 27, 2021 by Nikola JTD Share this post Link to post Share on other sites
Nikola JTD 230 Posted August 25, 2021 Drustvo, treba uskoro da se ide na dug put . Primetio sam u prethodnih par dana kad idem uzbro prvom, drugom, ili spustam se nizbrdo i kocim motorom, kako stisnem kvacilo, zacuka i zazvekece ispod auta onako primetno. Nikakvih dodatnih drmanja nema pri paljenju, gasenju, ubrzavanju. Dal je to zamajac sta mislite? Share this post Link to post Share on other sites
Nikola JTD 230 Posted September 22, 2021 Kako je sluzbeni auto odlozen zbog nekih problema u Kini s racunarima Brmba je otisla na more 10 dana i presla 2000km. Prosecna potrosnja je bila 5.4l sa ni malo neznom voznjom jer sam ovaj put bas iskoristio kako sam zeleo vozacki. Bilo je tu i tamo hyper matrix led farova koji su hteli da me pregaze ali su se lepo naruckali ocajne makedonske nafte. Jedan A4 2.0T ukrajinac me je i zaustavio da me pita da li je 330d cipovan, nije verovao dok nije video Put za razliku od prethodnih idenja na isto mesto ove godine nisam osetio. Auto me je odusevio po stoti put, malo smo i probali driftovati jer sad je zadnja vuca pa ko zna kad... Sve u svemu uzivanje. Policije u Grckoj nigde, Makedonija rigorozna i na svaki spust sa 120 na 100 na autoputu su imali kontrole, kao i posle tunela. Srbija zive duse....ali nam je autoput ocajan. 1 vagenovac reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted November 27, 2021 Dosao red da se nesto i servisira. Pukla je neka racva kod Vodene pumpe i tu malo pusta antifriz. Pojavilo se ulje negde kod interkulera da vlazi, majstor sumnja na separator uljnih para da je zacepio, na n47 nije jednostavno, dekla se skida itd, i za nepoverovati za svo ovo vreme po BG oranju otisao je samo jedan stabilizator na levom tocku. Ramena su i dalje BMW TRW prva ugradnja. Menjac ide opet dole jer je polovni zamajac odradio svoje izgleda... Share this post Link to post Share on other sites
MS PK 7728 Posted November 27, 2021 U jbtПослато са SM-A307FN помоћу Тапатока Share this post Link to post Share on other sites
rkoma1986 1109 Posted November 27, 2021 Da se ne pravim pametan al polovan zamajac... Ili ga zamenis za nov, ili ga ne diras, ne vidim svrhu polovnog zamajca za koji ne znas koliko je do sad odradio 3 PremieRacing, Ivan BG and vagenovac reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted November 27, 2021 Polovan jer smo jurili da otkrijemo problem s pocetka, Share this post Link to post Share on other sites
Nikola JTD 230 Posted December 2, 2021 Danas zamenjen menjac na autu, on je dobio luft u spojnickoj i to bas dosta lufa. Ulje u njemu je bilo bukvalno kao srebrna krema. Sreca nije me ostavio na moru... Ulje koje curi ide iz turba, i ona je dobila luft, tako da ide i novi turbo na auto u Ponedeljak. Zamajac odlican, kvacilo odlicno, sve ostalo top. Zamenjen pk kais, antifriz, stabilizator, racva kod vodene pumpe, ceh 390e. Zeleo bih ovim putem da pohvalim BMW Servis Plavi, visnjicka banja, momak je namontirao sve ali je tako lepo sve podmazao i podesio da imam utisak novo kvacilo da vozim. Na zamajac stavio nove srafove jer kaze ili novi ili stari moraju sa posebnim lepkom, sto mi prethodni majstor nije uradio... Cene koje momak ima su super i pohvala za njega. Uskoro ide i mali servis, i verovatno cu ga menjati za nesto jeftino i rentabilnije jer sluzbeni automobil nece stici pre aprila-maja, a do tada mi nista osim obicnog puntica ili neceg slicnog nece biti potrebno... 3 MS PK, dellas and Martin reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted December 15, 2021 Zamenjen turbo, dihtunzi, mali servis. Opran interkuler, creva, karter. Auto se sada drugacije ponasa, ima dosta zustriji odziv na gas, istog momenta reaguje na niskim obrtajima, dok je pre imao zakasnjenje. Sve u svemu zadovoljan sam i jos jedna pohvala za servis koji sam gore naveo. Nema odugovlaacenje, zavlacenja, veseo , nasmejan decko i nista mu nije tesko. 1 knezevic76 reacted to this Share this post Link to post Share on other sites
dellas 1556 Posted December 15, 2021 Super je znati da postoji bar jedan servis za bmw u Beogradu , a da nije za izbegavanje 1 Nikola JTD reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted April 8, 2022 Nista dugo nisam pisao. Vozimo se i dalje, sluzbeni jos nije stigao.... Na auto se ceka duze nego na zgradu da sagrade. Skoro sam zamenio separator uljnih para koji je u dekli, pa se menja sve zajedno... Neko je vec menjao i stavljao polovnu deklu sto smo videli kad se skinula stara. Potrosnjom sam nerealno zadivljen, kako god ga vozio potrosnja je jako niska. Trenutno je na 950km od toga 2x do panceva, ostalo BG i na satu je 6.7l. Uvek sipam od cepa do cepa pa je provereno i tako da je to to. Ne znam kako cu se navici na slabiji automobil jer me ovaj impresionira i nakon godinu dana. Evo jedan klipic , lagana treca brzina, prazan prostor, kontrolisani uslovi : 1 dellas reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted April 19, 2022 Stigla nova obuca: Share this post Link to post Share on other sites
