horvat 6456 Posted December 6, 2020 Dobro si ti razumeo, nego ja uleteo sa tom kombinacija kao indijanac 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted December 6, 2020 Ne znam, nisam nikad vozio fabricki xenon, ali sam imao morimoto i dobar xenon 4300k set, znaci bolje nego fabrika i nisam bio odusevljen preterano. Ovo mi bolje sija, vise svetla ima na putu. Nemam razloga da hvalim i lazem, samo subjektivno misljenje 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted December 6, 2020 Fabricki ksenon je roditelj, pogotovo kad ima da sam dize snop kako brze ides i jos ako ima zakretanje, maltene da ti ne trebaju duga svetla, a nikog ne zaslepljujes, a odlicno vidis. 2 neshtry and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 6, 2020 Ja sam progledao sa ovim fabrickim ksenonima, snop je savrsen bukvalno. 1 zunto reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted December 6, 2020 (edited) Pa jos da je led matrix ultra high tech far i onda jos bolje Pricam o klasicnom projektor faru sa xenonom/zaruljom i obicnom faru koji imam na ds3, podizanje spustanje, zakretanje itd jbg, normalno da ce biti bolje Edited December 6, 2020 by dekirs Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 6, 2020 Dize mi se, al' se ne zakrece. 3 Mijailović P., Axic and skile86 reacted to this Quote Share this post Link to post Share on other sites
skile86 539 Posted December 6, 2020 Tu nesto ne valja. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted December 6, 2020 Led matrix sam vozio vise puta i u odnosu na dobar xenon nema neke razlike u vidljivosti, glavna razlika jeste sto matrix ledovi uglavnom standardno imaju isecanje snopa da ne zaslepljuje druge vozace, maltene isece "kocku mraka", mada eto ja to imam i na bixenonima, ali tu se vidi razlika da ne iseca toliko ostro i precizno kao matrix, kod mene to radi prilicno primitivno, verovatno jer ima samo 4 snopa svetlosti koje rasporedi, nasram led matrixa koji ima vise desetina. 1 skile86 reacted to this Quote Share this post Link to post Share on other sites
neshtry 14829 Posted December 6, 2020 Led matrix Quote Share this post Link to post Share on other sites
Ivan 17639 Posted December 6, 2020 (edited) U odnosu na ono sto sam ocekivao kada su se pojavili, iskreno sam se uzivo "razocarao" sa LED farovima. Mislim, sija to, ali se i po ovom pitanju slazem sa @vagenovac - nikakav bitniji benefit u odnosu na xenon. Matrix eto ima tu dodatnu dzizdu da crta snop, u principu za mene samo bespotrebna novotarija za uzimanje para, a u praksi manje-vise nikakva dobit u odnosu na dobro nastelovan xenon. Sto se tice poredjenja reflektor vs projektor - svaki ima prednosti i mane. Reflektor daje malo "razbacaniji" snop, tj. nema toliko ostre razlike izmedju osvetljenog i neosvetljenog dela. Uvek baca malo odsjaja preko cut-off linije, tako da se pod srednjim svetlima vise naziru i saobracajni znaci, biciklisti, pesaci... Kod projektora je to ograniceno metalnim shield-om ispred sijalice, tako da je cut-off linija ostra. Licno mi ponekad zasmeta, jer se dobija efekat "renderovanja" kako volim da ga zovem, vise puta mi se desavalo da mi u mraku iznenada samo bljesnu potkolenice bicikliste ili pesaka pored puta. Sto je sa reflektorom malo teze da se desi. Takodje, na "stosovanju" moze da se desi da citav deo puta ostane bez svetla za trenutak. Prednost projektora je izuzetno fokusiran snop, a opet prilicne sirine, odlican za voznju po krivinama. Jos jedna stvar sa kojom se "borim" kada sebi stelujem obicne projektore (posto je levi deo cut-offa nizi) - a to je manjak svetla u levoj krivini u brzoj voznji. Pa pravim kompromis u horizontalnoj nivelaciji levog fara, tako da dobro vidim u krivini pod srednjim, a da dugo svetlo zadrzi svoj pravac. Desni projektor ima visi desni deo snopa i samo se "pukne" ravno niz desnu ivicu puta. Za mene je 4300K xenon+projektor, cak i aftermarket i dalje odlicno i jeftino resenje. Generalno Zabari imaju problem sa soljicama projektora, na novijim vozilima pije vodu i ugradnja xenona, dok na starijim mora da se radi reparacija (ili ubaci aftermarket projektor). PS: Tek sad vidim da nisam cestitao vlasniku , pa posto se ne druzimo na okupljanjima zbog Corone - da mu pozelim da ga DS lepo sluzi i da sto pre ispuni ono zbog cega je prodao Giuliettu . Izvinjavam se za duzi post. Edited December 6, 2020 by Ivan 6 horvat, dekirs, Woodoo and 3 others reacted to this Quote Share this post Link to post Share on other sites
totti 13164 Posted December 7, 2020 Mene živo zanima kakav je LED far u uslovima noćne vožnje i kiše. Imao sam priliku da ga probam u takvim uslovima, ali sa javnom rasvetom celim putem, pa mi nije merodavno. Ne deluje mi nešto obećavajuće... 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 7, 2020 Jedan fabricki xenon koji je sijao dobro, a posle ciscenja jos bolje. Naravno ocisceno je kompletno socivo kasnije, ovo sam slikao ovako cisto da se vidi "magla" i razlika... Kod obicnog fara imas "samo" da je dobra sijalica i da je ustelovan. A kod projektora, makar ja tako mislim, ima malo vise parametara da bi to sve bilo kako treba. Dzaba svakom puntu mk2 sto ima projektor/socivo kada je to sve nagorelo/izgorelo pre 10 godina...ali onda stavis "morimoto" i radis babama rendgen vilice... 3 neshtry, silenci and alfini0507 reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted December 28, 2020 (edited) Evo ideje da prekopiras od kolege Polovni Citroen DS3 DS3 2011. god. Polovni Automobili Srbija, Požarevac Edited December 29, 2020 by neshaoct dodao printscreen oglasa 1 1 vagenovac and neshaoct reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted December 29, 2020 Lebe mekani Quote Share this post Link to post Share on other sites
Ivan 17639 Posted December 29, 2020 Ulozeno puno ljubavi i truda... 2 horvat and neshtry reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4031 Posted December 29, 2020 Fali disco kugla i gajba pive.... 2 neshtry and nitro reacted to this Quote Share this post Link to post Share on other sites
totti 13164 Posted December 29, 2020 Disko kugla Sent from my SM-G770F using Tapatalk Quote Share this post Link to post Share on other sites
dekirs 4819 Posted March 21, 2021 Pali, radi, malo trosi Na prodaju! 2 horvat and djomla reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted March 21, 2021 Koliko moze da razvije Послато са Mi MIX 2 помоћу Тапатока Quote Share this post Link to post Share on other sites
dekirs 4819 Posted March 21, 2021 Moz' razvije dve krompiruse za 15 minuta 2 1 Milutinac, djomla and moron reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted March 21, 2021 Živ je Deki Sent from my 3310 using Tapatalk 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
skile86 539 Posted March 21, 2021 Ne moze bez Zabara pa to ti je. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted March 21, 2021 Deki has left the chat hahah Послато са Mi MIX 2 помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted March 21, 2021 Na pravom sam mestu da saznam sve o vozilima koja nisu FCA grupacija 2 1 totti, Milutinac and djomla reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 21, 2021 Sta ti decko radis... Sent from my SM-A520F using Tapatalk 1 djomla reacted to this Quote Share this post Link to post Share on other sites
