Axic 19713 Posted October 23, 2020 51 minutes ago, Ivan said: A razlika u ceni izmedju DS4 i DS5 je 15-20%, Mali off kod domaćina u temi ali taj DS4 beše onaj francuski poluproizvod kome se prozori na zadnjim vratima ama baš nikako ne mogu otvoriti. BTW Sedišta top, kao nekad VW GTI mk1 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17442 Posted October 23, 2020 1 minute ago, Axic said: ali taj DS4 beše onaj francuski poluproizvod kome se prozori na zadnjim vratima ama baš nikako ne mogu otvoriti. Tako je . Fiksno staklo kao na kupeu . I kratka zadnja vrata/uzi ulaz na zadnja sedista i spicasta zadnja vrata i svasta jos... 1 Axic reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 23, 2020 Ne kontam cemu to sa staklima... Quote Share this post Link to post Share on other sites
MS PK 7718 Posted October 23, 2020 Kako cemu? Pa eto, da Flex nema bravu na suvozacevim vratima ne bi isao sad Jugoprevozom u grad 1 6 ISV_01, rkoma1986, alfini0507 and 4 others reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 23, 2020 Nisam ja iz PK pa da mi treba prevoz do grada. 1 3 dekirs, ISV_01, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
nstyner 168 Posted October 24, 2020 Čestitke Marko! "Njuška" mu opasno izgleda! 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 26, 2020 Hvala bivsi komso Quote Share this post Link to post Share on other sites
nstyner 168 Posted October 26, 2020 Gledam dvorište i rekao bih da nismo u komšiluku više? Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 26, 2020 Ima vec godinu dana... Sad sam sremac (Petrovaradin) Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 26, 2020 On 10/23/2020 at 11:35 PM, MS PK said: Kako cemu? Pa eto, da Flex nema bravu na suvozacevim vratima ne bi isao sad Jugoprevozom u grad Samo da te obavestim da ponovo imam bravu i nema frke oko odlaska u grad. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 26, 2020 Cisto da mi se ne brines. Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 26, 2020 (edited) @Flex daj raspisi se malo,sta si mu uradio, sta je bio problem? Da budem spreman sad vidim kod tebe na temi... Edited October 26, 2020 by rkoma1986 Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 26, 2020 Neces ti imati ovu muku, veruj mi. Nisam cuo, a ni nasao bilo gde na netu da je nekome otisao mehanicki deo. Sto se tice elektronike, crkava pre ili kasnije na gomili primeraka. Nadajmo se da neces morati da menjas. 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 31, 2020 Igrao se danas malo sa Carista aplikacijom i odradio neke zanimljive stvarcice (punjenje kazaljki pri kontaktu, spustanje desnog retrovizora kad se menjac ubaci u R, pojacao dnevna svetla, otkljucao zeleni meni gde ima brdo neke customizacije). Posle toga sam proveravao stanje dpf-a preko VAG DPF aplikacije. Zbunilo me je sto je zapusenost 70% a majstor je pre mesec dana pregledao, rece da je na 14%... Nije mi prvi auto sa dpf-om ali se nikad nisam nesto interesovao oko toga. Jel moguce da se toliko zapusi za mesec dana od gradske voznje, i da li bi jedno produvavanje na AP spustilo procenat nesto znacajnije? Provalio sam kad radi regeneracije samo po obrtajima na leru, podigne za 200 otprilike, bez nekog dima na auspuhu. 1 Bingodalton reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 927 Posted October 31, 2020 A gde si gledao taj procenat zapušenosti? Ako misliš na onu gornju liniju ona pokazuje zapušenost pred regeneraciju. Odnosno kada dođe do nekih 95%onda se pokrene regeneracija i slika dpfa više nije zelena nego crvena. Kada ta linija padne na ispod 20%onda se kod mene prekida regeneracija. Na koliko Km ti radi regeneraciju? Meni je uglavnom na 450km neke mešovite vožnje. Quote Share this post Link to post Share on other sites
darkman14 5792 Posted October 31, 2020 Opet zavisi koliko si prešao u zadnjih mesec dana po gradu, ako je to tipa 10-15 km dnevno pa recimo 20tak radnih dana, trebalo bi da bude onda ok da je na 70%. Po MESu, meni delta radi regeneracije na nekih 250 km prosečno. E to spuštanje retrovizora kad je ubačen rikverc mi baš fali. Quote Share this post Link to post Share on other sites
totti 13151 Posted October 31, 2020 Neki imamo spuštanje i levog i desnog, po želji 2 Woodoo and djomla reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 31, 2020 (edited) @totti izvini sto nemam 'nema dalje opremu' @Zvezdo da, mislim na tu liniju gore. Mozda to i nije procenat zapusenosti nego interval do sledece regeneracije, Ne znam.. zadnja je odradjena pre 250 km @andreja.micovic pretpostavljam da mozes to nekako da aktiviras Edited October 31, 2020 by rkoma1986 Quote Share this post Link to post Share on other sites
totti 13151 Posted October 31, 2020 On 10/31/2020 at 2:10 PM, rkoma1986 said: [mention=10479]totti[/mention] izvini sto nemam 'nema dalje opremu' Ok, prihvatam izvinjenje 1 1 djomla and rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5792 Posted October 31, 2020 nemaju Bravo/Delta/Stilo tu opciju Pitanje je dal i tipo ima. Ne znam da mi je to neko spomenuo ko vozi FLA grupaciju Quote Share this post Link to post Share on other sites
rkoma1986 1080 Posted October 31, 2020 Smece talijansko 3 1 totti, djomla, darkman14 and 1 other reacted to this Quote Share this post Link to post Share on other sites
Ivan 17442 Posted October 31, 2020 4 minutes ago, andreja.micovic said: nemaju Bravo/Delta/Stilo tu opciju Pitanje je dal i tipo ima. Ne znam da mi je to neko spomenuo ko vozi FLA grupaciju Sta je Stildza sve imao ... Doduse u varijanti sa elektro-podesivim sedistima. Pre dve decenije, u narodnoj Compact klasi i ACC (adaptivni tempomat), Keyless Go i svasta jos. Kada vec pominjes Tipo, tehnoloski je smesan u poredjenju sa tim sta je Stilo bio kada se pojavio. Doduse, u Stila je spucana i ogromna kolicina love u razvoj, zato je i imao onakav gubitak (u odnosu na planiranu dobit) po svakom primerku. Tu tehnologiju je koristila i iduca generacija njihovih vozila. Tipo je totalna kontra, low-budget koji belezi lepu prodaju na nezahtevnim trzistima. 39 minutes ago, totti said: Neki imamo spuštanje i levog i desnog Imas dva ? 2 djomla and MS PK reacted to this Quote Share this post Link to post Share on other sites
totti 13151 Posted October 31, 2020 Krivo mi što nemam elektropodesiv i unutrašnji retrovizor 1 djomla reacted to this Quote Share this post Link to post Share on other sites
