djomla 8386 Posted May 12, 2021 Lako mu je tamo da se k*#či sa 2.0 Sent from my 3310 using Tapatalk 1 2 Axic, horvat and igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted May 12, 2021 Zbog toga ja i kazem da 2.0, pogotovu dizel, nije nikakva trkalica, vec motor za prijatnu voznju. 2 horvat and djomla reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted May 22, 2021 Moze i 2.0 fino da se napravi ako se ima zivaca Sent from my VOG-L29 using Tapatalk 1 vagenovac reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 22, 2021 Tfsi? Moze Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Ticma 537 Posted May 22, 2021 Mogao bi, da nije djubre Sent from my VOG-L29 using Tapatalk 1 vagenovac reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 12, 2021 Pre dva dana obradjeni diskovi posto su poceli da tresu na kocenju pri malo vecim brzinama. Ako se opet javi problem stavljam Galfer racing posto je sve postalo tesko djubre sto se kod nas uvozi a garancije nema...Zaboravih nov kompresor klime pre nekih mesec dana, stari je samo zakovao bez ikakve najave Sent from my VOG-L29 using Tapatalk 2 darkman14 and Milutinac reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted August 12, 2021 Jesi obradio na autu, bez skidanja, ili klasično - skinuo i odneo strugaru? Meni je ovo prvo baš, baš pomoglo dok sam vozio B klasu... Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 12, 2021 Bez skidanja u Japan shop-u, valjda tako kompenzuju ako ima nekih nedostataka u glavcini u nekim slucajevima. Sent from my VOG-L29 using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
moron 3691 Posted August 12, 2021 5 hours ago, Ticma said: Pre dva dana obradjeni diskovi posto su poceli da tresu na kocenju pri malo vecim brzinama. Ako se opet javi problem stavljam Galfer racing posto je sve postalo tesko djubre sto se kod nas uvozi a garancije nema... Zaboravih nov kompresor klime pre nekih mesec dana, stari je samo zakovao bez ikakve najave Sent from my VOG-L29 using Tapatalk Ja sam po preporuci jednog prijatelja na 308 stavio Gafler diskove. I nikakv problem nema ni današnji vlasnik, posle oko 45 kkm. A, kako "crče" kompresor klime? Šta mu bi ? Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 12, 2021 Kompresor ostao bez ulja, ni kapi nije bilo. Kod njega je problem skinuti ga, sve je nabijeno. Nov ERA sa rukama ispade 45k...Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 26, 2021 Sta mislite, ide li ovo na A6?Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 26, 2021 Nista dok ne vidim Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 26, 2021 Pa nije da mi se bas ide do Tuzle samo da bih video Keskin KT13 je modelSent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 26, 2021 https://www.drive2.ru/r/audi/a6/504709/Sent from my 3310 using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted August 26, 2021 Prilicno katastrofalno Sent from my VOG-L29 using Tapatalk 2 PremieRacing and djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 26, 2021 Cisto da ne ides do Tuzle Sent from my 3310 using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted August 27, 2021 Ni ka ko Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 27, 2021 https://www.drive2.ru/r/audi/a6/504709/Sent from my 3310 using TapatalkAu Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Ticma 537 Posted January 6, 2022 Mozda bi ovo cucnulo, samo OOOO znak naravno...20" i stavio bi 255 (mozda 265) /40(35) Sent from my VOG-L29 using Tapatalk 3 PremieRacing, MS PK and Bingodalton reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 737 Posted January 6, 2022 Ovo bi vec cucnuloSent from my SM-G960F using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted January 12, 2022 O-ho-ho, i-te-kako To bio deda sMraz kod tebe ? Al' zaboravio poklon pa ti dao kovertu Quote Share this post Link to post Share on other sites
Ticma 537 Posted January 15, 2022 Jos uvek se neckam, prednje 8.5 a zadnje 9.5J pa gledam zbog diferencijala koje bi gume stavio Ne bih ispod 255 isao sigurno a sada da li 40 ili 35 profil video bih... Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 31, 2022 Sutra idem da probam da vidim kako izgleda na njima, model je sa A7 od 201820" 9J ET35..Sent from my VOG-L29 using Tapatalk 3 PremieRacing, moron and MS PK reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted April 1, 2022 On 9/3/2020 at 3:58 PM, Ticma said: Lepša mi ovaj njegova... Quote Share this post Link to post Share on other sites
Ticma 537 Posted April 1, 2022 Jeste lepsa ali im je vreme za sredjivanje a svakako moram letnje gume da kupujem pa kad je bal.. Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
