Nikola JTD 230 Posted March 16, 2021 S'limi to obavezno 2 neshaoct and rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted March 16, 2021 Bas bi voleo da vidim izlazak Quote Share this post Link to post Share on other sites
Bingodalton 737 Posted March 16, 2021 Kaze se "Bas bih..." Nek snimi neko, bez ciscenja, samo ga isteraj. Jel kod njega Haldex ili je permanentni pogon? Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 16, 2021 Nema on tu heldex igracku od pogona, pravi je quattro Ne mrdam ga jos par sati dok malo rese puteve okolo... Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted March 16, 2021 Ju Vlado,sta ti rek'o za haldex 2 1 Ticma, vagenovac and Bingodalton reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 16, 2021 Hahaha salim se malo Quote Share this post Link to post Share on other sites
Bingodalton 737 Posted March 16, 2021 Ma videce on u junu u Haskovu sta je Haldex Sent from my SM-G960F using Tapatalk Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 16, 2021 Inace, usao sam na suvozaceva vrata i isterao iz snega, nije ni osetio, samo steta nije imao ko da snimi Sent from my VOG-L29 using Tapatalk 5 Flex, moron, Bingodalton and 2 others reacted to this Quote Share this post Link to post Share on other sites
cane 205 Posted March 16, 2021 To su oni momenti kad ti je drago sto si kupio bas taj auto Sent from my Mi 9T Pro using Tapatalk 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
Dale 6809 Posted March 17, 2021 Na tom parkingu ti je bolje da izadjes prvi jer kako ciste sneg sa okolnih kola tako bacaju na tvoja, a svima uzimaju pare za ciscenje ovi sto rade tu... Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 17, 2021 Izvlacio sam C klasu 2019 sajlom iz snega i to na parkingu, ne mogu da zamislim kako se odvezao sa planine kada na parkingu nije mogao da se mrdne... Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
srdjos 1602 Posted March 18, 2021 to je više do vozača nego do Merca Quote Share this post Link to post Share on other sites
moron 3691 Posted March 18, 2021 (edited) Imaš ti trenutke (pa i na Kopu ) kada ti ne pomaže ni da imaš "Pinzgauer". Prosto, nekada visina i kvalitet snega prevazilaze tehničke moći vozila (taman da imaš lance na svakom točku na AWD-u) i u tim uslovima sve što možeš da postigneš, jeste da naneseš štetu na svom vozilu. A najveća je blagodet ako čovek ima iskustva i mudrosti da prepozna gde je ta granica, mada tu često treba i dosta sreće. Ja sam pre sadašnjeg CRVa vozio debelo preko decenije ladu nivu i vitaru i ako nešto statistički mogu da tvrdim - za sebe - daleko više puta sam se uglavio sa 4WD, nego li sa 2WD. Ne zato što su oni 4WD bili loši, već zato što sam često srljao kao teška budala, misleći "ma može to da prodje, 4WD je .." A može moj ... Sa 2WD maltene nikada nisam imao problema u snegu, mada sam išao redovno zimi na iste planine na koje sam išao i sa 4WD. Sa prostog razloga jer sam sa 2WD postupao mudrije, opreznije. Edited March 18, 2021 by moron 3 MS PK, Dale and djomla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 18, 2021 Bravo Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 19, 2021 Ovoliko snega gore skoro nije bilo u martu da se ja secam, sutra idem ponovo, nadam se bez smetova ovaj put iznad Srebrenca. Par ljudi je ne videci sneg na putu samo uletelo i ostalo zabijeno, jedva su se iscupali. Nisam pokusavao nista extremno ali skoro pola metra nesabijenog snega gura bez muka Sent from my VOG-L29 using Tapatalk 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
moron 3691 Posted March 19, 2021 Gore na Kopu očekuju ovih dana još 70 cm snega ( tako piše na "Infokopu", prognoza za subotu i nedelju je sneg ). Ako budu čistili put i parkinge kako treba, biće ok, ali, u kontaktu sa dve osobe ovih dana sam dobio info da je po tom pitanju (bila) katastrofa. A za to da može "Audi samohotka" da prodje kroz skoro pola metra snega (bez ošetećanja), ja ti skidam kapu Npr, kada naidje na (vlažan) sneg znatno veće dubine od klirensa, Lada Niva može do neke mere da "gura" (vlažan) sneg ispred sebe, ali, kako se taj sneg sve više "nakuplja" ( a tvrd je, jer je vlažan ), u jednom trenu Lada Niva svakako stane. Nekada se (zbog oblika metalnog štitnika prednjeg mosta samo "popne" (sklizne) prednjim mostom na taj zbijen nagurani sneg ( pa prednji točkovi ostanu da vise ), a nekada prosto, kako snežna grudva ispred raste, ne može više da gura toliku snežnu santu iz spred sebe. I stane ( a točkovi proklizuju). A pri svemu tome, na Ladi Nivi nemaš napred ili ispod bilo koji plastičan deo koji bi polomio (niti je neki pomoćni agregat motora ili hladnjak nisko i pod rizikom). Ne možeš da napraviš štetu. Sa bilo kojim savremenim AWD vozilom da to probaš da uradiš u pola metra vlažnog snega, mislim da bi prošao slično, u smislu da bi pre ili kasnije svakako "stao" ( ne može ni "ULT" ili "RADOJE DAKIĆ" da gura sneg bez granica ), ali, ako bi bio baš uporan, mislim i da bi to na kraju bio i fijasko od par hiljada evra štete ( razne plastike, hladnjaci, sonde i ko zna šta još ). Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 19, 2021 Pricamo o 5 metara duzine a i manje rastresitog snega na parkingu, bukvalno je kao puder bio...Da je neka veca duzina ili da je mokar sneg verujem da ne bi vise od pola metra prosao dok se ne sabije Sent from my VOG-L29 using Tapatalk 1 moron reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted May 12, 2021 Kratka horor prica, zamena xenona sa suvozaceve strane Oko sat vremena okvirno bez pauza za psovanje sa montazom i demontazom svega... Sent from my VOG-L29 using Tapatalk 5 1 moron, PremieRacing, Mijailović P. and 3 others reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 737 Posted May 12, 2021 Svabo napravio.A kazu na Stilu teska zamena Sent from my SM-G960F using Tapatalk 1 djomla reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 12, 2021 Jel nije lakse izvuci far? Na A4 se far skine za 5 min Quote Share this post Link to post Share on other sites
Ticma 537 Posted May 12, 2021 Ovde prvo mora branik da bi se skinuo far Sent from my VOG-L29 using Tapatalk Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 12, 2021 Smece 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ticma 537 Posted May 12, 2021 A sta cu, makar je 3.0 Sent from my VOG-L29 using Tapatalk 1 1 rkoma1986 and moron reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted May 12, 2021 Nikad na forumu nismo imali toliko ozbiljnih masina. Osecam se kao da vozim skroz downsizovan motor sa 2.0 1 moron reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted May 12, 2021 Nemoj tako Igore, u temi za Tipa 1.4, si glavni racer-provokator 3 silenci, igor0511 and Axic reacted to this Quote Share this post Link to post Share on other sites
