Branislav 722 Posted July 27, 2020 (edited) Joj samo njega nisam zvao, sve ostale jesam, Euroauto, Ricambi, itd itd. Edited July 27, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted July 27, 2020 Isti ( gornji desni ) sam platio 13k prošle godine, Akron ,drugi nije imao. Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 27, 2020 I jel si zadovoljan? Da se razumemo to je nosac ispod akumulatora Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted July 27, 2020 A ne ne, ja sam menjao sa suvozačeve strane ,gornji. Izvini. A nisam zadovoljan ,deluje mi pretvrd, ali nije bilo izbora. Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 27, 2020 Skontao sam da je to isti nosac kao na Stilu 1.9jtd, sutra stize Swag nosac pa cemo videti... Quote Share this post Link to post Share on other sites
Ivan 17655 Posted July 27, 2020 A za Stilo JTD svojevremeno budzili sa Stila benzinca 1.8 , jer je bio jeftiniji. Rekoh ti ja odmah da "ne odustajes" od gornjih nosaca, cak cesto bude i taj kod menjaca. Po Compatiblity listi, iz originala, taj nosac za 1.4 T-Jet 88 i 110 kW ide samo na Bravo i Deltu: Quote Share this post Link to post Share on other sites
MS PK 7732 Posted July 27, 2020 Nije nekad nego jos uvek, cak sta vise retko ko stavi od dizela uopste i jos se niko nije pozalio do sada Quote Share this post Link to post Share on other sites
Ivan 17655 Posted July 27, 2020 E jbg kad ga je cica pazario Stila pre vise od 13 godina, pa se secam samih pocetaka svih mogucih budzenja . Ja sam taj od retkih , pazario 2008. u Delti original za JTD, bio je oko 80 EUR u to vreme. Salu na stranu, tada je sam model bio slabo poznat i nije bio ni 10% ovako raskupusan u sitna crevca kao danas. A oridjidji nosac je "radio" korektno, sve dok nisam prodao auto. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted July 28, 2020 On 7/27/2020 at 10:18 PM, MS PK said: Nije nekad nego jos uvek, cak sta vise retko ko stavi od dizela uopste i jos se niko nije pozalio do sada Tu bi bio posao staviti i motor od benzinca. 1.8 recimo Zasto se zadrzati samo na jednom nosacu??? 2 Ivan and horvat reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 28, 2020 (edited) Zar taj nosac na Bravu ispod akumulatora nije isti kao na Stilo 1.9 JTD? Iako je ovaj T-jet benzinac, ovakav je kod mene.. Edited July 28, 2020 by Branislav Quote Share this post Link to post Share on other sites
Ivan 17655 Posted July 28, 2020 (edited) Ja ti iznad ostavih fabricku Compatibility listu. Pa ti kako hoces, a nas covek svasta budzi, nemam nista ni protiv toga... Evo ti za referencu fabricki nosac za JTD. I to obe varijante - levo je stariji sa pocetka produkcije od 2001. Desno je ovaj masivniji, sa primetno vise amortizujuce gume, koji je i fabricki isao od restyle 2004. i koji smo svi svojevremeno stavljali na Stildzu. Kasnije je krenulo i jeftinije karabudzenje sa nosacem od 1.8, samo je onda morao duzi sraf, koliko se secam... Evo slike za JTD: Edited July 28, 2020 by Ivan 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted July 28, 2020 Sacekaj malo prikupi para pa stavi originalni nosac i zaboravi na vibracije. Nije to nista hitno osim sto nervira, po meni mnogo bolje nego budziti nosace sa Stila itd.. Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 31, 2020 (edited) Promenjen nosac motor i rezultat je porazavajuci, stari nosac nije bio najbolji ali problem je sto auto trese u leru iskljucivo izmedju 1000rpm do 1400rpm u svakom drugom slucaju je kao nov, ali cim dodje u tu zonu trese mi se sediste bukv, jako sam poludeo zbog ovoga jer pucam pare i svoje zivce... Edited August 1, 2020 by Ivan Prebaceno Quote Share this post Link to post Share on other sites
Ivan 17655 Posted July 31, 2020 Kupio si dizela ili promasio temu ? 3 bit, djomla and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted August 1, 2020 (edited) Izgleda da sam kipio T-JTD motor. Edited August 1, 2020 by Ivan Ne citiraj prethodni post ;) 2 Mijailović P. and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted August 1, 2020 Kako u leru izmedju 1000 i 1400 obrtaja? To mi deluje da ti trese na pipanje gasa? Quote Share this post Link to post Share on other sites
Branislav 722 Posted August 1, 2020 (edited) Da da dodam gas i kada pustim gas i dok vraca na 800rpm on trese u opsegu od 1400-1000rpm i kad dodje ispod 1000 smiri skroz I kad ga upalim hladnog pa drzi na 1200rpm isto trese dok ne spusti na ispod 1000. Edited August 1, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 1, 2020 Ne znam da li išta znači, meni je Stilo pre zamene nosača levog (ispod akumulatora) tresao na leru. Čim dam minalan gas prestaje da trese. Čini mi se da je i sa paljenjem klime mirnije radio. Quote Share this post Link to post Share on other sites
bit 937 Posted August 1, 2020 Ako ti trese pri smirivanju, može biti na kvačilu neki problem, na pr zamajac. Probaj sa stisnutom pedalom kvačila. Ako i dalje trese pri smirivanju onda je nešto od obrtnih delova motora u disbalansu Quote Share this post Link to post Share on other sites
Branislav 722 Posted August 1, 2020 (edited) Zamajac je menjan nije presao 1000km pre bih rekao ja je jos neki nosac nego motor... Edited August 1, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
bit 937 Posted August 1, 2020 Da li je tresao i pre zsmene Quote Share this post Link to post Share on other sites
Branislav 722 Posted August 1, 2020 (edited) Da i pre zamajca se identicno ponasao... Edited August 1, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Ivan 17655 Posted August 1, 2020 @Branislav Molba da na postove odgovaras sa Reply, a ne sa Quote (sem ako ne citiras neki poseban post ili njegov deo). Tako se samo nepotrebno duplira sadrzaj postova, a mi "idemo iza tebe" i ispravljamo svaki tvoj post . Hvala unapred na razumevanju. 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted August 27, 2020 (edited) Konacno resen problem vibriranja auta, nakon toliko patnje, promene dva nosaca, provere uzupcenja motora ispada da je treci nosac bio u kvaru tj onaj koji drzi motor i sasiju sa suvozaceve strane, veliki kamen mi je pao sa srca ali i dzep mi je ozbiljno pogodjen... Idemo dalje Edited August 27, 2020 by neshaoct prebačeno 4 MS PK, Reacher Gilt, horvat and 1 other reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted August 27, 2020 Vec sam pisao u necijoj temi za Lanciu Deltu T-Jet... Ima nas 4 na forumu samo, kojima je otisao taj desni nosac I svima je uzrokovao bas gadne simptome. Cene su se razlikovale od auta do auta, i od godista do godista, al simptomi svima isti - grozne vibracije, a nosac na oko perfektan. 2 1 Branislav, dekirs and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
