neshaoct 9592 Posted July 22, 2020 Sledeći tekst je poslao @danijel55, koji radi prodaju polovnih guma i tu je za sva Vaša pitanja ===== Prodaja polovnih guma iz Nemačke i Holandije Stanje detaljno prikazano na slikama. Dogovor oko slanja ili preuzimanja, dostava naravno može. Za sva dodatna pitanja slobodno pišite post, šaljite PP, ili na fon 065/824-4242 Quote Share this post Link to post Share on other sites
danijel55 699 Posted July 22, 2020 Upravo stigla roba. -michelin m+s 205-60-R16 DOT4114,sara na dve 7mm,druge 2 6mm-70e 4kom -michelin letnja 205-60-R16 DOT2114,sara na dve 5.5mm ,druge 2 malo preko 6mm -70e 4kom Iako su 14 god,nigde nisu ispucale,deluju dosta dobro -sava m+s 205-60-R16 DOT2216 ,sara na obe 7mm -50e GoodYear 225-45-R17 4 season,DOT0516,sara na dve 5.5mm,druge dve 7mm Cena-100e Michelin cross climate 225-50-R17 DOT0618 raspar,tj 1kom. Sara 6.5mm Cena 3000din Pireli 245-45-R17 DOT5015,sara 5mm 5000din cena. Quote Share this post Link to post Share on other sites
danijel55 699 Posted July 22, 2020 Jos u ponudi: -Michelin 225-50-R16 2kom -Uniroyal 185-65-R15 2kom -Michelin 185-60-R15 2kom -Continental 235-65-R16C-3kom Quote Share this post Link to post Share on other sites
danijel55 699 Posted July 29, 2020 Prodate 225 45 R17 i 205 50 R16 Stigla nova roba : 225 45 R17 Quote Share this post Link to post Share on other sites
Riki 6 Posted July 30, 2020 -Michelin 225-50-R16 2kom, koja je cena i dot? Quote Share this post Link to post Share on other sites
danijel55 699 Posted July 30, 2020 Napravih grešku. Prodate su 225 50 R16, a ja napisah 205 50 R16. Otisle su dzabe, tako da kazem. Za celih 4000din. Stigle su sledece dimenzije: -Michelin 235-45-ZR17 5.5mm,dot1213- 2kom - GoodYear 205-50-R17 2kom DOT1118, sara malo preko 5mm-2kom - 225-50-R17 raspar hankook i michelin cross.Ako nekoga zanima DOT3317 i 0618 - Bridgestone 225-45-R17 DOT2517, sara 6mm -2kom -Hankook 225-50-R17 DOT3116, sara 6mm. Imam jos 14c i 16c Quote Share this post Link to post Share on other sites
danijel55 699 Posted July 30, 2020 Od svih guma imam slike.Ako je neko zainteresovan napise dimenziju,odmah ubacim slike.Da ne bi ovako gomilao. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 1, 2020 Evo da ponudim ovde. Mozda nekome zatreba.Imam raspar 4gume.Sve su u vrj stanju 6-7mm. Hankook 225 45 R17 Michelin cross climate 225 50R17 Hankook 225 50 R17 Michelin 205 55 R16 Ako nekom zatreba slučajno neka guma od ponuđenih, lako cemo se dogovoriti. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 1, 2020 Da korigujem samog sebe.raspar 205 55 R16 nije michelin, vec dunlop. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 2, 2020 205 55 R16 4kom prodate 235 45 R17 prodate 14c prodate Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 3, 2020 185 65 r15 prodate 205 60 R16 letnje prodate Quote Share this post Link to post Share on other sites
bit 936 Posted August 3, 2020 Imaš li nešto gabaritnije 295/80 22.5 vodeće ne starije od 3g u narednih mesec, a da cena nije veća od novih, može do 310/80Nove low end 170e. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 3, 2020 Nisam imao nista u toj dimenziji. Jedino priblizno sto sam imao to je bila conti 315 80 R22.5 Pretpostavljam da ovo što si naveo je za kipera? Quote Share this post Link to post Share on other sites
bit 936 Posted August 3, 2020 Prednje za FAP mašinu 315 je mislim ok poslednja širina. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 4, 2020 225 45 R17 prodate. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 8, 2020 205 60 16 sava prodate 205 60 16 michelin prodate. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 12, 2020 Stigle su sledece gume: Michelin cross climate 205 55 R16, prodate u roku od 2h Kleber 215 55 R16 Maxis 225 50 R16 Ako je neko zainteresovan, dodacu slike Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 19, 2020 Prodato je dosta guma, a danas opet stizu. Uglavnom napraviću ponovo spisak sta sve ima, dot i sara. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 19, 2020 Na stanju sledece: 4x 195 55 R15 DOT3018, sara 6mm+ mastersteel 4x 215 55 R16 kleber dot1317, sara 6mm 2x 205 55 R17 dot13, nisu ispucale, sara 5.7mm 2x 205 50 R17, dot1118, sara 5.2mm 2x 155 65 R14, dot1317, sara 7.7mm. Quote Share this post Link to post Share on other sites
danijel55 699 Posted August 20, 2020 Ostale su mi i dve raspar gume, pa ako nekome treba u rezervi. 225 50 17 Michelin cross climate dot0618, sara 6.3mm 225 50 17 hankook all season sara 7mm + Quote Share this post Link to post Share on other sites
danijel55 699 Posted September 3, 2020 Da osvezim malo. Za 10 dana bi trebalo jos neke stice. Za sada su ostale: 4 kom mastersteel 195 55 15 DOT3018 sara 6mm 4kom 215 55 R16 kleber quadraxer 2, sara 6mm,verovatno ce za vikend otici 2kom 205 50 R17 GoodYear, dot1118 šara 5.3mm 2kom 205 60 R16 DOT0518, sara 5.3mm, michelin 2kom maxxis 225 50 R16 DOT0216, sara 6.4mm Dodacu slike po redosledu: 1-5 slika 195 65 R15 6-10 215 55 R16 11-13 205 50 R17 14-16 205 60 R16 17-19 225 50 R16 Quote Share this post Link to post Share on other sites
danijel55 699 Posted September 4, 2020 Kleber 215 55 16 i goodyear 205 50 17 prodate. Quote Share this post Link to post Share on other sites
Semi 94 Posted September 6, 2020 Imas li neke zimske od 15”? Quote Share this post Link to post Share on other sites
danijel55 699 Posted September 7, 2020 (edited) @Semi Koja dimenzija treba? Edited September 7, 2020 by neshaoct dodao tag Quote Share this post Link to post Share on other sites
