DraganUS 450 Posted October 7, 2020 Apsolutno, novo je novo. 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted February 26, 2021 (edited) Kreće se polako sa radovima, do kraja marta bi trebalo sve završiti. Za sada se pakuje 2.4 sve na novo, kvačilo, hladnjak vode, svi servisi naravno. Sve ću updatovati kako se radovi budu odvijali i šta se bude radilo. Edited February 26, 2021 by neshaoct prebacio slike na FLCS server 5 Sedla, Gagy.GM, neshaoct and 2 others reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted February 26, 2021 8 minutes ago, Majstor_Paja said: Sve ću updatovati kako se radovi budu odvijali i šta se bude radilo. 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
MS PK 7729 Posted February 27, 2021 Aj nek je srecno 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted February 27, 2021 Stigao si i ti na red vidim. 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted February 27, 2021 Konačno bio je i red..Dok se poklopilo sve trebalo je malo vremena.Mislio sam da ću to sve da završim i ranije ali majstor i keš nisu mogli da se poklope u isto vreme Quote Share this post Link to post Share on other sites
dellas 1556 Posted February 27, 2021 Srecno sa novim setupom Svaka cast za entuzijazam 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted February 27, 2021 Ne idem po kafanama, ne drogiram se, ne pijem Moram nešto Quote Share this post Link to post Share on other sites
dellas 1556 Posted February 27, 2021 Manje bi te kostalo ovo prvo i znao bi cemu da se nadas ali dobro svako ima svoje ventile 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted February 27, 2021 Nisam ja džabe ovo izabrao, bar imam izgovor kod žene Quote Share this post Link to post Share on other sites
MS PK 7729 Posted February 27, 2021 Jeste, normalni ljudi imaju po jedan ventil, ti 20. Bas ti je izgovor 1 1 Milutinac and Sedla reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted February 27, 2021 Ne pričaj nikom Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted May 4, 2021 Radi se 5 Zvezdo, neshaoct, PremieRacing and 2 others reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted May 5, 2021 Sklopljeno sve oko motora, uzupčen , "izdeklovan" Sutra se ugrađuje, i ostalo prateće uz njega. Izbačen je AC kompresor, hladnjak i instalacija od njega 4 horvat, Reacher Gilt, Bingodalton and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7729 Posted May 5, 2021 Sto si izbacio klimu?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted May 5, 2021 Fali sušač i neka creva i nisam hteo da se bakćem to da sređujem..Drugo motor mnogo pristupačniji , hlađenje će biti efikasnije jer je hladnjak klime izbačen i malo weight reduction i bolji odziv na gas. 3 Reacher Gilt, MS PK and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted May 7, 2021 Spakovano sve i radi, dobro se sve ponasa..Turbina je gecrk naravno nije toliko strasno ali dimi ipak, kad je motor prolupao sve je nabio u nju. Tako da cu 99% da remontujem moj Garret GT2871R Bitno je da je auto u funkciji, izaci ce na ulicu uskoro kad se zavrsi sve 4 PremieRacing, MS PK, Reacher Gilt and 1 other reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5308 Posted May 13, 2021 Čestitke. Napokon na ulici 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted May 15, 2021 Još malo je ostalo do ulice, ima par stvari da se reše, turbina se skida i šalje na remont i generalna provera svega..Imamo problemčić kad se auto zagreje, gasi se i to je stari problem. Treba da stavimo airfuel da vidimo kakve su vrednosti, možda je crkla sonda, možda čip naliva previše goriva..Sve u svemu, još je rano za ulicu Ali biće uskoro Quote Share this post Link to post Share on other sites
integralac 2566 Posted May 15, 2021 Spremas ga da bude ulicar ccc Svaka cast Pajo, pre cu ja da provozam tvoj kupe nego svoj, jbga 1 Majstor_Paja reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted March 29, 2022 Sta bi sa kolima? Prolupao? Quote Share this post Link to post Share on other sites
Majstor_Paja 92 Posted March 30, 2022 Ma da. Nemam vise zivaca a ni vremena. Ako se pojavi pravi kupac da ga sredi u narednih par dana dok se ne predomislim, prodacu ga. Ili ce ostati pa da ga radim od nule onako kako meni odgovara bez "saveta" drugih. Quote Share this post Link to post Share on other sites
