Branislav 722 Posted January 17, 2022 (edited) 3 minutes ago, horvat said: Da li je ovo realno, ne mogu da verujem. Kad si radio veliki servis? Nema 25000, plus skidao kais da proverim zupcenje kad mi je nosac crkao ako se secas da smo pricali ja i ti o tome da proverim Prvo sam pomislio ventil izgoreo, medjutim nije dimio niti je svukao kap ulja a presao sam 1000km od servisa. Pretpostavio sam onda da je prezubio Edited January 17, 2022 by Branislav 1 horvat reacted to this Quote Share this post Link to post Share on other sites
darkman14 5898 Posted January 17, 2022 ciganka... da te sreča prati... 3 1 djomla, Branislav, ISV_01 and 1 other reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 Sutra cekam zvanicnu potvrdu da je prezubio i da vidimo kolika je steta ako je ima, kakve sam srece bice svih 16 Quote Share this post Link to post Share on other sites
Reacher Gilt 2175 Posted January 17, 2022 Šesnajs mu milije majki ... da je moj strošio bi ga sčekić ! Rešavaj to i udavaj ! Quote Share this post Link to post Share on other sites
Mijailović P. 3432 Posted January 17, 2022 A u qvac! Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 (edited) Necu da ga prodajem ne pada mi na pamet, ima da se teramo namerno sad Ne moze on mene hebati koliko ja mogu da ga trpim Edited January 17, 2022 by Branislav 6 ISV_01, darkman14, djomla and 3 others reacted to this Quote Share this post Link to post Share on other sites
darkman14 5898 Posted January 17, 2022 Suludo je prodavati. ISčačkati sve i onda voziti... Eno ti i @Milutinac kako je prošao a kakav auto sad vozi... Prvi deo teme bio Muke po Milutinu a sad labud Quote Share this post Link to post Share on other sites
Reacher Gilt 2175 Posted January 17, 2022 Pa dokle više u qrac krasni ... 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 (edited) Bas unlucky za mene, ali dobro nadam se najboljem da nije pokrivio nista i da cu uzeti novi kais i to i vratiti ga nazad i to je to. Ako ne zna se. Komplet glava i 16 ventila...... Ugasio me je kao cigaretu. Ali dobro nadam se da ce doci kraj Edited January 17, 2022 by Branislav 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 17, 2022 Neverovatno, ne znam sta drugo reci... 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 14 minutes ago, Milutinac said: Neverovatno, ne znam sta drugo reci... Zamisli kako je meni, na autoputu sedim u kolima gledam u jednu tacku i mislim u sebi "Da li si me ovako sjebao"? Strasno sta da kazem. Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted January 17, 2022 Čitam, ne verujem.... Baš čudno iz čista mira kao i kod tog tipa, šta je bio epilog kod njega ? Neki zamor materijala ? 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 Just now, ISV_01 said: Čitam, ne verujem.... Baš čudno iz čista mira kao i kod tog tipa, šta je bio epilog kod njega ? Neki zamor materijala ? Ne znam nije napisao, samo je napisao da mu je iz cista mira prezubio i da mu je majstor rekao da je on drugi tjet koji je prezubio sa kaisem citavim. Ja sam treci kojem se to desilo iz cista mira... Smeo sam da se zakunem u motor da moze bilo gde sa njim ali eto. Bolje da cutim Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted January 17, 2022 Nešto je zakočilo kaiš ? Kontam da baš sam od sebe ne može tek tako..ili zubci na kaišu nisu bili nešto (iako novo) ili nešto levo što se okreće a uslovilo je zaustavljanje i preskakanje kaiša..da li je moglo nešto tečno da "podmaže" i preskoči ?? Bem ti sreće baš.... Ajd, nadajmo se najboljem, da nema neke štete. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted January 17, 2022 Ne mozes ti da imas toliki inat koliko on moze da te j. To je kao Yugo, celu noc smislja kako ce ujutru da te zezne Svakom u zivotu naleti tako neki baksuz, samo je neko svestan toga pa proda djubre odmah a neko se bori, bori..pa opet na kraju proda. Najjace u celoj prici je sto taj auto obavezno sluzi drugog vlasnika bez ikakvog problema 3 debelizmaj, Reacher Gilt and Dale reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted January 17, 2022 Flex likes this 2 Reacher Gilt and MS PK reacted to this Quote Share this post Link to post Share on other sites
MiloshBg 999 Posted January 17, 2022 Na kvalitet delova se sve vise stavlja znak pitanja! Dok sam radio u ovl. servisu desavalo se da pri ugradnji originalnog seta majstor ne moze da nategne zupcasti jer je spaner u problemu!? Isto tako se desavalo i da prezubi i upali check (verovatno samo 1 zub) ali srecom bez stete. Isto spaner bio felerican... Motori su bili bas 1.4 16v atmo i 1.4 tjet. Desilo se jednom i na 1.6 mjet E6D. 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
totti 13160 Posted January 17, 2022 21 hours ago, Branislav said: Sutra cekam zvanicnu potvrdu da je prezubio i da vidimo kolika je steta ako je ima, kakve sam srece bice svih 16 A veliki servis si ti radio ili prethodni vlasnik? 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 17, 2022 Radio prethodni vlasnik nema sta sve stavljeno novo ja ga razubljavao da proverim, moguce da je los kvalitet kaisa ko zna 18 hours ago, MS PK said: Ne mozes ti da imas toliki inat koliko on moze da te j. To je kao Yugo, celu noc smislja kako ce ujutru da te zezne Svakom u zivotu naleti tako neki baksuz, samo je neko svestan toga pa proda djubre odmah a neko se bori, bori..pa opet na kraju proda. Najjace u celoj prici je sto taj auto obavezno sluzi drugog vlasnika bez ikakvog problema Ja sam odlucio da idem tezim putem. Prvo jer sam ga sredio full i necu da ga poklanjam nekome, drugo i da dobijem sve pare koje sam dao nemam sta drugo da kupim a da budem sig da me nece razvlaciti Opet ruku na srce ovo je prvi kvar koji mi se desio sve ostalo je bilo povuci potegni sa dosta gresaka sto mojih sto majstora. Ali ovakav kvar nisam ocekivao i ovo je ujedno i prvi kvar na autu pravi koji nisam mogao da sprecim. Ipak sam presao 20000 bez problema osim kocnica tj abs modula i tog dzeka famoznog. Quote Share this post Link to post Share on other sites
totti 13160 Posted January 18, 2022 Pitam zbog reklamacije. Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 18, 2022 (edited) A nema sanse da reklamiram nemam racun bacio sam ga pre godinu dana. Mislim ko bi ovo ocekivao. Ostaje mi da se nadam danas najboljem, u krajnjem slucaju to je sto je radim glavu pa sta Bog da Edited January 18, 2022 by Branislav Quote Share this post Link to post Share on other sites
darkman14 5898 Posted January 18, 2022 Mislio je da reklamiraš radove. Imaš valjda upisano u servisnoj knjižici, potpis, pečat... Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 18, 2022 (edited) 19 minutes ago, andreja.micovic said: Mislio je da reklamiraš radove. Imaš valjda upisano u servisnoj knjižici, potpis, pečat... To bih mozda i mogao ali onda moram auto da vucem u Bg da se natezem i slicno. Videcu da li je sjebao glavu ili ne pa cu onda da vidim sta i kako Ubija me to sto sam zakazao regu i atest plina i sve i sada se trkam sa vremenom da to sredim ili da otkazem, a auto mi treba stalno Edited January 18, 2022 by Branislav Quote Share this post Link to post Share on other sites
Šajbi 43 Posted January 18, 2022 14 hours ago, Branislav said: juce na autoputu za Ns Pri kojoj brzini ti se ovo desilo? Quote Share this post Link to post Share on other sites
Branislav 722 Posted January 18, 2022 17 minutes ago, Šajbi said: Pri kojoj brzini ti se ovo desilo? 80-90 otkud znam Quote Share this post Link to post Share on other sites
