totti 13151 Posted July 1, 2020 A ja bih i espresso aparat u kolima Beše išao uz neki 500L? Sent from my SM-G950F using Tapatalk 1 bane1321 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17456 Posted July 1, 2020 Jeste, dobro se secas, Lavazza je bila u pitanju . "Espresso expirience" ili "Coffee experience", tako nesto se zvalo, doplata za tu glupost je bila 200 EUR. Quote Share this post Link to post Share on other sites
totti 13151 Posted July 1, 2020 Nikad bolje potrošenih 200€ ne bi bilo Sent from my SM-G950F using Tapatalk 2 2 Reacher Gilt, dekirs, Ivan and 1 other reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 3, 2020 Lavazza je dobra kafa koliko ja znam Ako ne zatvore Beograd, krecemo u projekat ugradnje Xenona i gasenje Pcv-a. I ugradnje plina ako sve prodje po planu. Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted July 3, 2020 Ja predlažem da dobro opereš PCV kako bi klapne proradile.Sakupljač uljnih isparenja/PCV je mnogo bolja stvarčica, po mojim kriterijumima.tt Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 3, 2020 (edited) Neko dublje pojasnjenje tvojih kriterijuma na ovu temu? Edited July 13, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted July 3, 2020 Nisam baš pri "vremenu" al' ukratko, Mnogi su se žalili na povišenu potrošnju ulja ne znajući da je osnovni "krivac" PC- ventil koji je usled neblagovremenog intervala zamene ulja i nečišćenjem istog(sa velikim servisom) dospeo u problematično stanje.Tada imamo situaciju da uljno/vodena isparenja umesto u komoru za sakupljanje dospevaju jednim delom na usis a drugim na kompresorski deo turbo punjača.Čišćenjem ili zamenom rešavamo problem.tt 1 1 Pluto and Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 6, 2020 (edited) Danas prva neprijatna situacija sa Bravcem, krecem da zaobilam i naglo kocim a prednji levi kraj mi se podvlaci i krece u desno, izgleda da leva klesta ne hvataju dobro i pri naglom kocenju bukvalno bacaju sa puta, odmah sam zakazao majstora za kocnice da vidimo sta se desava... Prvi put da sam doziveo ovakav ples auta, i da ovako lako baca sa puta. Edited July 6, 2020 by Branislav Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted July 6, 2020 Masivan je auto, pa se zato lako i zanese ako jedna klješta bolje rade. Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 9, 2020 Iako sam zamenio zamajac, volan mi i dalje vibrira a nekada auto radi normalno, zasto se to desava? Posebno kada motor spusta obrtaje na 1000rpm? Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 9, 2020 (edited) Nisam proveravao, ali bukvalno trese tj vibrira volan da me izludjuje.. Edited July 13, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
dekirs 4819 Posted July 9, 2020 Vrlo moguce da jesu.. Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 13, 2020 Gledam cene nosaca za bravca danas i zamalo se nisam slogirao jedan je 6000 a drugi 8500, naravno kosku nisam gledao jer je ona ok.. Quote Share this post Link to post Share on other sites
dekirs 4819 Posted July 13, 2020 Pa to je skroz okej Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 13, 2020 (edited) To skroz ok boli . Edited July 13, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Ivan 17456 Posted July 13, 2020 Pogledaj koliko je desni nosac za npr. Stila dizela, da ti bude lakse... Sto kaze Mica, taj nosac se nikome ne kvari . 2 1 gorank82, Branislav and MS PK reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 13, 2020 (edited) Kupio sam dva aditiva Liqui Moly po preporuci, pa cu ga dodati u menjac, plus provera nosaca i kupovina novog, i kocnice jos nismo popravili ali smo uzeli Remsa plocice za 3200 posto su ATE 5400... A sa Remsom imam skroz ok iskustva Edited July 13, 2020 by Branislav Quote Share this post Link to post Share on other sites
dekirs 4819 Posted July 13, 2020 Pogledaj za Giuliettu koliko je nosac sa suvozaceve strane 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted July 14, 2020 Ili za brava 2.0... 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted July 14, 2020 A za Deltu +.+ Quote Share this post Link to post Share on other sites
MS PK 7718 Posted July 14, 2020 Menjali na e klasi, w211 pre neki dan, Lemforder nosac menjaca 1800din Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
shuxx 10533 Posted July 14, 2020 Preporuka za Lamforder. Na fabiji sam menjao spone, i mehanicar mi pokaze znak, kao roda, caplja, i na originalnom delu, i na zamenskom... Sent from my POT-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
Branislav 706 Posted July 14, 2020 Dodat aditiv u menjac 2 bocice po preporuci, provereni nosaci i za divno cudo svi nosaci su i vise nego u dobrom stanju, tako da ostaje misterija zasto volan vibrira... E sad malo sam se isparanoisao da nije zbog menjaca mada ono ne verujem... Ako neko ima predlog sta dalje da gledam neka pise Quote Share this post Link to post Share on other sites
danijel55 694 Posted July 14, 2020 Jel se menja sta ako pritisnes kvacilo? Quote Share this post Link to post Share on other sites
