Desmo 430 Posted January 10, 2021 Pogledaj snimak od 3:33, prebaco je na tocak koji je u vazduhu i tek kad je blokirao centralni diff je uspeo da izadje, jer su oba prednja tocka na zemlji. Snimak neovlascenog sam gledao i ne bi ga komentarisao "The main disadvantage of the Torsen differential is when no torque is sensed on one of the axles, the differential does not lock. Torsen differential is not capable of transferring 100% of torque to one of the axles. In real life this means that when a single axle loses grip completely (very low traction on ice, or if wheels raised in the air) the car is not able to move. " https://www.awdwiki.com/en/torsen/ 2 PremieRacing and horvat reacted to this Quote Share this post Link to post Share on other sites
Zan Batist 252 Posted January 10, 2021 sto ne bi komentarisao neovlascenog? ovo sto si citirao 1 hour ago, Desmo said: Torsen differential is not capable of transferring 100% of torque ja i ne tvrdim.. Quote Share this post Link to post Share on other sites
Desmo 430 Posted January 10, 2021 On 1/8/2021 at 9:36 AM, Zan Batist said: nikako, pa to bi onda bio obicni otvoreni diferecijal. Kad se zatvori tockovi se vrte istom brziom bez obzira na uslove. 4 hours ago, Desmo said: If no torque is sensed on one of the axles, the differential does not lock Quote Share this post Link to post Share on other sites
nemke 92 Posted January 11, 2021 On 1/8/2021 at 8:30 AM, clover said: Prelep auto! Vidjam slicnu u Obrenovcu..kazem slicnu jer ima iste felne, hrom retrovizore, ali ne znam da li je Q. Volan je ispao . Gde si radio? Storeli je radio volan 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
nemke 92 Posted January 24, 2021 (edited) Zatamnjeni stopovi sa 20/25% folijom u planu imam i farove. Edited January 24, 2021 by Ivan Sredjene slike 3 silenci, Danilo1 and horvat reacted to this Quote Share this post Link to post Share on other sites
Branislav 721 Posted January 24, 2021 Ko ti je radio i koliko kosta? Quote Share this post Link to post Share on other sites
clover 78 Posted January 24, 2021 Meni lepse fabricki. Ovako previse zatvoreno i crno. Ali dobro...100 ljudi 100 ukusa. 4 Axic, Desmo, vagenovac and 1 other reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 24, 2021 I meni lepse fabricki, al ako je vlasnik zadovoljan super Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted January 24, 2021 nije lose ni bavarsku fasadu da stavis na farove! neki kukaju da slabo svetli i silne novce daju da bolje svetli a ti bi jos i tamnu foliju stavljao! zaista ne razumem! 3 darkman14, Reacher Gilt and totti reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 24, 2021 2 hours ago, clover said: Meni lepse fabricki. Ovako previse zatvoreno i crno. +1 Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted January 24, 2021 Stvar ukusa...meni nikad neće biti jasno vid zatamnjivanja štopaljki i uopšte svetala radi nekog izgleda a na uštrb vidljivosti (a primećuje se, da se ne lažemo). 1 totti reacted to this Quote Share this post Link to post Share on other sites
werp690 454 Posted January 25, 2021 Meni je lepse ovako zatamnjeno. Kao sto se i kaze, stvar ukusa. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted January 25, 2021 Meni se to generalno svidja ali konkretno na ovom crnom autu ne Quote Share this post Link to post Share on other sites
PremieRacing 5299 Posted January 27, 2021 On 1/24/2021 at 12:59 PM, Branislav said: Ko ti je radio i koliko kosta? Bolje pitanje je kad treba na tehnički i kako misli da prođe Inače, meni je Quote Share this post Link to post Share on other sites
nemke 92 Posted January 31, 2021 Folija od 300din uzeo fen i sam zatamnio. Sto se tice vidljivosti vidi se lepo. Inace je light folija 20/25% Ovo sam cisto hteo da vidim kako izgleda nece mene ovo dugo drzati. A i lako se skida 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
nemke 92 Posted May 25, 2021 (edited) Doslo vreme i za servise Ugradio sam sve dayco i champion filtere i naravno selenia 5/30 wr Inace jedva sam nasao i opruge eibach prokit i cekam ovih dana da ih ugradim Odradio sam i registraciju auta sve je proslo kako treba osim onih folija na stop lampama od 20% koje sam morao da skinem ali nema veze Edited May 25, 2021 by neshaoct formatiranje 8 Branislav, Dzimbo, horvat and 5 others reacted to this Quote Share this post Link to post Share on other sites
Desmo 430 Posted May 25, 2021 Bas dobar auto 1 nemke reacted to this Quote Share this post Link to post Share on other sites
nemke 92 Posted May 25, 2021 Danas spusten Q2 vs Eibach prokit 8 horvat, MS PK, Stilisa and 5 others reacted to this Quote Share this post Link to post Share on other sites
nemke 92 Posted May 28, 2021 Da li moze neki savet? Hteo bi da zamenim ulje u menjacu pa me zanima koje ulje ide 75w90 ili 75w85? I koje ulje sipati tutela, motul ... Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted May 28, 2021 18 minutes ago, nemke said: Hteo bi da zamenim ulje u menjacu pa me zanima koje ulje ide 75w90 ili 75w85? Synthetic-based lubricant, SAE 75W-85 grade. API GL-4 PLUS, FIAT 9.55550 specifications Iz vlasničke knjižice, klik OVDE (sada radi, popravljen je link). Quote Share this post Link to post Share on other sites
nemke 92 Posted November 23, 2021 (edited) Malo da obnovim temu.. Ima par novina na kolima za ovih par meseci sto me nema na forumu ali na inter svratim kad imam vremena. Odakle poceti? Dugo sam jurio ove felne i napokon su moje top stanje samo gume da uzmem i krace ventile. Inace ovo je Q2 et32 8j 5x98 koja je isla na GT moja omiljena Jurim neke dobre gume 215/40/18 ili 225/40/18 Zimski set sam peskirao i farbao kod Pistrea na Medaku. Speedline 7J 5x98 17 na zimskim gumama 215/45/17 Trenutno se radi usisna grana skida se plasticna sa klapnama i stavlja se aluminijumska sa 140ks Menja sedesna poluosovina i stavlja se nov zglob i nove mazetne sa lagerom. Skidam moju i stavljam stari tip na srafove: Levu poluosovinu sam ostavio moju ali sam zamenio krst i mazetnu. Menja se i letva volana koja je dobila malo lufta i kad se vec radi nek se radi. Edited November 23, 2021 by Ivan Sredjene slike 7 horvat, Reacher Gilt, Milutinac and 4 others reacted to this Quote Share this post Link to post Share on other sites
Desmo 430 Posted November 23, 2021 (edited) @nemke Koja je razlika izmedju starog i novog tipa poluosovine? Edited November 23, 2021 by neshaoct dodao tag Quote Share this post Link to post Share on other sites
nemke 92 Posted November 23, 2021 (edited) @Desmo Stari tip ima zglob a novi krst i flansu Edited November 23, 2021 by neshaoct dodao tag Quote Share this post Link to post Share on other sites
nemke 92 Posted September 21, 2022 Malo da osvezim Na kolima manje vise nista se nije menjalo osim felni Q2 18' sam vozio 2-3meseca pa sam prodao set i uzeo jos nesto redje.. Ducati Corse 18' veoma retka felna koja je isla na samo 500 primeraka 147 DC i u veoma dobrom fabrickom su stanju Gume Hankook K127 215/40/18 preporucujem svakom gume Osim servira bilo je vreme da se zamene diskovi i plocice. Stavio sam ATE komplet sve i Valeo ulje Uradjen remont menjaca kod Brane u Vranicu i zamenjen set kvacila LUK i Tutela Matrix ulje menjaca I taman kazem to je to sad mogu da se vozim kad upali mi check. Dodje kolega Ivan sa foruma pogasi greske. P2015 Greska je koliko znam za klapnice? A klapnice su povadjene.. Pobrise Ivan greske nije proslo 5dana opet je upalio gresku auto se ponasa normalno sve je ok ali gori check na tabli. Sta raditi? 6 Nikola031, Nikola JTD, Grafit and 3 others reacted to this Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted September 22, 2022 Jel ti auto bio na oglasima ili mi se cini ? Quote Share this post Link to post Share on other sites
