faketaxi 9 Posted June 7, 2020 (edited) Pozdrav svima eto zanima me jedna stvar ludim vec 3 dana :/ Dakle imam fiat kao što sam napisao u nazivu međutim upalim ga i čuje se neko kvrckanje kod remena ne mogu odrediti što je to dali mi može netko pomoći? Edited August 9, 2021 by neshaoct preciziranje naslova teme Quote Share this post Link to post Share on other sites
MS PK 7732 Posted June 7, 2020 Majstor ili neko ko se razume Mora prvo da se skine kajs i proba bez njega, ako ne krcka, onda je nesto u pk krugu, roler, alternator, kompresor.. verovatno je do alternatora ali ne moze nista napamet i preko tastature. Quote Share this post Link to post Share on other sites
faketaxi 9 Posted June 7, 2020 (edited) Hvala ti brate Edited June 7, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
MS PK 7732 Posted June 7, 2020 Za hvala nema nista da se kupi Napisi u cemu je bio problem kada ga budes resio. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
faketaxi 9 Posted June 7, 2020 (edited) Svakako cu napisati Edited June 7, 2020 by Ivan Ne citiraj prethodni post ;) 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
faketaxi 9 Posted June 11, 2020 On 6/8/2020 at 10:10 AM, Zvezdo said: Vodena pumpa? Upravu si prijatelju vodena da .... Nažalost pukla je doista nezgodno i curilo je van tekućina sad mi je jasno sta je lupalo ... ali eto sva sreća imam frenda koji ima identičnu i sve tako da sl.tjedan če ju srediti .....Onda cu i slike staviti hvala svima na informacijama koje su pružali... 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted June 12, 2020 Nije skupa nova pumpa. Ne stavljaj polovnu! Ako već nisi zameni i PK kaiš i španer. Quote Share this post Link to post Share on other sites
Flex 1778 Posted June 12, 2020 Obavezno nova, kakva crna polovna i "sredjivanje" na taj nacin. Quote Share this post Link to post Share on other sites
faketaxi 9 Posted June 13, 2020 Nova je stavljena 97€ preko kolege iz italije stigla mali ide koooo zmaj evo slike da vidite bebu hvala svima 2 ISV_01 and silenci reacted to this Quote Share this post Link to post Share on other sites
mujezinovic.b 0 Posted July 27, 2020 Pozdrav društvo. Vozim GP 1.3 multijet, zadnjih par dana sam primijetio nekakvo čudno zujanje kada je auto na kompresiji kad se spušta niz brdo. To zujanje je nekako najbliže onom kao kad ne ubodeš aux kabal u telefon do kraja .. Da li se neko slučajno susreo sa sličnim problemom? Quote Share this post Link to post Share on other sites
KikoA33 0 Posted December 30, 2020 (edited) Cudan zvuk iz motora, u pitanju je 1.3 multijet, sa 150 000km. Sumljam da je lance, ali nisam siguran. Posle neki 30 minuta, obrtaji padaju, upaljuje se check engine i pocinje da trese po malo. https://drive.google.com/file/d/1JC-...ew?usp=sharing Hvala! Edited December 30, 2020 by neshaoct spojeno Quote Share this post Link to post Share on other sites
werp690 459 Posted December 30, 2020 (edited) Preglasno je ovo da bi bio lanac, mislim da nije... Po zvuku bi rekao da je neka remenica,ima tu jos stvari koje bi mogle da budu, svakako proveri sto pre.. Za pad obrtaja i check engine je najsigurnija dijagnostika, sve ce tu da pise da ne lupamo bzvz. Recimo regulator pritiska goriva, maf... Itd.. Edited December 30, 2020 by werp690 3 KikoA33, neshaoct and Zvezdo reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted December 30, 2020 Majko moja ali traktoriše! Ima taj mnooogo više od 150hiljada. Kao što Kolega werp 690 kaže lanac nije sigurno! Proveri vodenu pumpu i PK Španer. Alternator mislim da nije. Što se greške tiče bez dijagnostike ništa ali na osnovu zvuka mnogo toga se je tu nakupilo! 1 1 KikoA33 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
ToniHr 0 Posted March 14, 2021 (edited) Pozdrav! Radi se također o grande puntu 1.3 mjt., 2007. Što se tiče vožnje čini mi se da sve radi normalno, ulje Selenia je dodano nedavno, no nakon par dana počeo je ispuštat neki ritmični jednoličan zvuk u pozadini otprilike kao "ckckck". Nebitno bio u vožnji ili da stoji u mjestu. Video istog; https://vimeo.com/523372767 Edited March 14, 2021 by ToniHr Quote Share this post Link to post Share on other sites
daca punto 5 Posted August 8, 2021 (edited) Pozdravljam drugari. Evo mene opet posle kraće pauze sa kvarovima. Elem pojavio mi se skoro problem sa nekim čudnim zvukom iz motornog dela pomislih kao i svako što bi da je turbo vrisnuo posto vozim GP 1.9 ali zvuk koji je sporan čuje se više sa leve strane e sad da ga opisem kao kad slovo ŠŠŠŠŠŠŠŠ pojačavaš pri dodavanju gasa podseca kao da metal o metal pri velikim obrtajima grebe a to se dešava kad opteretim auto odnosno kad krecem i kad je auto pod opterecenjem u leru je prica drugačija tek negde od 3 do 3500 rpm se cuje isti zvuk al ponavljam negde sa druge strane čini mi se. Pitanje je dal je neko imao sličnih problema ili bar nagovestaj šta bi moglo biti? Pozz. Edited August 9, 2021 by neshaoct spojeno Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted August 9, 2021 13 hours ago, daca punto said: a kao da metal o metal pri velikim obrtajima grebe Turbo u kakvom je stanju, zna li se ? Da nije dobio luft u osovini pa šeta okolo. Drugo, to ŠŠŠŠ kada nabija pritisak može biti i da je negde mizerna pukotina na crevu pa vuče falš vazduh kada se dostiže određen pritisak u grani. Quote Share this post Link to post Share on other sites
daca punto 5 Posted August 9, 2021 5 hours ago, ISV_01 said: Turbo u kakvom je stanju, zna li se ? Da nije dobio luft u osovini pa šeta okolo. Drugo, to ŠŠŠŠ kada nabija pritisak može biti i da je negde mizerna pukotina na crevu pa vuče falš vazduh kada se dostiže određen pritisak u grani. Pa sad turbina nije baš u zavidnom stanju al opet nije ni toliko možda loša cula se ali nije to bilo ništa strašno da kažeš malo je fijukala. Moraću da proverim sva ta creva od usisa i onako planiram da ih menjam sve u kompletu. Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted August 9, 2021 28 minutes ago, daca punto said: nije ni toliko možda loša cula se ali nije to bilo ništa strašno Samo sam aludirao na nju zbog metalnog zvuka, zato mi prvo pada na pamet. Ako je luft u osovini, kada je skineš, videćeš koliko šeta. Ako je solidno - verovatno za remont. Creva proveri, možda su ok pa ih nema potrebe menjati. Quote Share this post Link to post Share on other sites
daca punto 5 Posted August 9, 2021 57 minutes ago, ISV_01 said: Samo sam aludirao na nju zbog metalnog zvuka, zato mi prvo pada na pamet. Ako je luft u osovini, kada je skineš, videćeš koliko šeta. Ako je solidno - verovatno za remont. Creva proveri, možda su ok pa ih nema potrebe menjati. Ima jedan video sam pronašao jako je sličan zvuk kao i kod mene doduše Fiat stilo je u pitanju možda se zna šta je. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 9, 2021 52 minutes ago, daca punto said: ...možda se zna šta je. Zna se, ali moraš da odeš do majstora da se vidi šta je od tih mogućih razloga, npr. : - bušno neko od creva - riknuo turbo - riknuo dihtung na izduvnoj grani - pukla izduvna grana - puklo kućište filtera vazduha Nije moguće da ti bilo ko ovako ''daljinski'' kaže jednu stvar bez da se pogleda auto. 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
daca punto 5 Posted August 9, 2021 (edited) Svakako će ići kod majstora samo bih voleo da izbegnem baš ako mogu kvar turbine creva i ostalo cu valjda moći finansijski da podnesem. Edited August 9, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 9, 2021 @daca punto Voljenje ili ne...to neće promeniti ono što već postoji kao problem. Forum ti je pomogao da saznaš šta sve može da bude (slažem se, nešto od toga je lakše, nešto je teže za džep)...ali tu se pomoć Foruma u konkretnom slučaju iscrpljuje (možemo samo da se vrtimo u krug 10 puta) - sad mora neko i uživo da pogleda. Quote Share this post Link to post Share on other sites
