djomla 8386 Posted February 27, 2020 (edited) Pod pretpostavkom da na forumu postoje osobe koje imaju potrebu za istim, otvaram temu o ćorama. Sve što bi vas moglo zanimati u vezi sa naočarima, bilo sunčanim, dioptrijskim ramovima, staklima (sa dioptrijom, samo zaštitna stakla, u boji, bela, foto) servisom naočara itd itd, savet neki, šta god, možete ovde pitati. Poyy Edited February 28, 2020 by neshaoct popravio naslov teme 7 Ivan, Djuk85, Stilisa and 4 others reacted to this Quote Share this post Link to post Share on other sites
Dale 6807 Posted February 27, 2020 Djomla, jesi li ti iz te struke ili samo "korisnik"? Quote Share this post Link to post Share on other sites
Mijailović P. 3444 Posted February 27, 2020 Opop, drmrpr.... Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 27, 2020 @Dale i jedno i drugo @Mijailović P. bez dr Nisam oftalmolog, ali radim sa njima, tako da "ukradem" štošta i od njih. Quote Share this post Link to post Share on other sites
dach@ 4904 Posted February 28, 2020 Koliko je tačno da su naočare sa polarizacijom najbolje za sunce,ili to nema veze ono samo marketinški trik za bolju prodaju.Mislim na naočare bez dioptrije Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 28, 2020 Jao Minže, Ray Ban Aviator 58mm, crne, slomio sam jedno staklo kad bi mi to našao - bio bih ti večno zahvalan... sa slike desno staklo, ovo na kojem ne pise ray ban Ili 2 stakla po nekoj normalnoj ceni. Gde god sam pitao kazu dodaj jos 10-15 pa kupi nove. Ali ne radi mi se sada to... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 28, 2020 (edited) 20 hours ago, djomla said: @Dale i jedno i drugo @Mijailović P. bez dr Nisam oftalmolog, ali radim sa njima, tako da "ukradem" štošta i od njih. Ukradi meni jedne za sunce Edited February 28, 2020 by neshaoct formatiranje 2 1 Mijailović P., djomla and Irena HGT reacted to this Quote Share this post Link to post Share on other sites
shuxx 10851 Posted February 28, 2020 putujem na posao 20km, ujutru idem na zapad, sunce bije u oči, popodne idem na istok, sunce bije u oči, uvek u kolima ( uvek tu sede ) su mi naočare, obavezno polarizovane, što je ceh od cca 2000+din, dobre su i za vožnju po snegu, tj kada ima puno relfeksije. veoma lako se proveri da li su polarizovane, kada dva para okrenete jedne ka drugima i pogledate kroz njih, budu providne, a kada drugi par zarotirate za cca 90 stepeni, poprilično se zatamni slika, tj skoro skroz neprovidno. moj lični savet je da ih treba koristiti, puno znače, manje se oči zamaraju... marka / brend / kvalitet/ staklo / plastika----- po mogućnosti ...$$$$$$ Veliki izbor polarizovanih naočara za sunce sa okvirima raznih oblika i materijala. Glavna karakteristika polarizovanih sunčanih naočara je da smanjuju odsjaj sunca. Smanjuju odsjaj koji je prouzrokovan svetlošću koji se reflektuje od polarizovane površine kao što je voda ili staklo. Sva polarizovana stakla imaju i UV400 zaštitu, pružajući kompletnu zaštitu za vaše oči. Naočare za sunce sa polarizovanim staklima se najviše preporučuje za vožnju, sportove pored vode i skijanje. https://www.naocareonline.com/category/polarizovane-naocare 2 dach@ and djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 28, 2020 (edited) Pokusavam da odgovorim ali nikako da stignem. @dach@ Nije marketinški trik, tačno je da su prijatnije za nošenje od standardnih sunčanih naočara. Već je @shuxx objasnio. Polarizacija ne propušta svetlost koja se odbija o horizontalnu površinu, npr na moru sa polarizovanim naočarima nećeš imati odbljesak svetlosti po površini vode, koji te zaslepljuju. Za vožnju su daleko prijatnije. Kontrast boja je lepši. Kada ti vozilo dolazi u susret nemas odbljesak o šofeku itd, itd. Jedina mana, na nekim kolima se ne vidi ekran. @Milutinac bači mi u iMbox sifru celu, mada ako se ne varam je 3025 L2823, pa da vidim od ponedeljka sta i kako. Danas ne stigoh. @MS PK i poštarinu da platim? Edited February 28, 2020 by neshaoct popravio tagove 3 darkman14, dach@ and Axic reacted to this Quote Share this post Link to post Share on other sites
shuxx 10851 Posted February 28, 2020 Prosle godine odemo na Staru planinu. Dan za pozeleti. Suncano. Majali se vozili motorne sanke. Ceo dan na suncu. Osim sto sedosmo na kuvano vino. Poneo sam neke kineske naocare tek da ih imam. Uvece lice izgorelo a oci me bole... I tako par dana. Odmah sam se raspitao i kupio polarizovane naocare za pecarose. Jer im je jak odsjaj od vode. Fantasticne su. Gamakatsu. Vrede svaki dinar. Oci su vam jedine i samo stare vremenom. Cuvajte ih 3 Irena HGT, djomla and dach@ reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted February 28, 2020 Imate i odredjivanje dioptrije?Skoro sam uradio dioptriju ali mi treba jača na levom a veći cilindar na desnom oku....Duplira mi slova na televizoru....a i mutno malo...Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
Smireni 524 Posted February 28, 2020 Koja tanja stakla (plastiku) bi preporučio? Probao sam dva proizvođača, i oba slučaja se u roku od godinu dana ovaj sloj spolja (polarizacija, zaštita) izgrebao. A ja sam baš pažljiv, nema ono da ih brišem čime stignem, uvek pamuk ili krpica. Sloj nije izgreban, već... Kao da je ispucao... U talasima... Preko dana nema razlike, ali uveče rasipa tačkaste izvore svetla. Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 28, 2020 @Djuk85 imamo druže. @Smireni misliš na dioptrijska stakla kad kažeš tanja? Hoya, Essilor, Zeiss, što se tiče stranih proizvođača, ima par domaćih koji su ok, ali je svakako ovo bolja priča. Šta si nosio do sad? Index tanjenosti zavisi i od same dioptrije. Tebi se (pretpostavka) oštetio antirefleks sloj. Ako pak pričamo o polarizaciji, to su sunčana stakla, koja mogu biti sa dioptrijom takođe. Quote Share this post Link to post Share on other sites
Smireni 524 Posted February 28, 2020 Jeste, dioptrijska. Antireflex, u brzini čitajući prethodne napisao polarizacija. Uzimao sam Šapcu na dva mesta, nisam siguran, tačno za proizvođače, kad bih čuo, verovatbo bih prepoznao. Sigurno nije ni Zeiss ni Hoya. Indeks tanjenosti je 1.67, za 1.74 mi je mnogo da platim, a nije tolika razlika. Quote Share this post Link to post Share on other sites
dach@ 4904 Posted February 28, 2020 @djomla druže ako bude neka dobra akcija za naočare za sunce sad za leto,javi.Unapred hvala Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 28, 2020 @Smireni Pol, Gross, OKM? Koja je tebi dioptrija? @dach@ vazi druze, će napravimo nešto Quote Share this post Link to post Share on other sites
Smireni 524 Posted February 28, 2020 @djomla 6 Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted February 28, 2020 (edited) On 2/28/2020 at 8:33 PM, djomla said: [mention=17583]Djuk85[/mention] imamo druže. [mention=18612]Smireni[/mention] misliš na dioptrijska stakla kad kažeš tanja? Hoya, Essilor, Zeiss, što se tiče stranih proizvođača, ima par domaćih koji su ok, ali je svakako ovo bolja priča. Šta si nosio do sad? Index tanjenosti zavisi i od same dioptrije. Tebi se (pretpostavka) oštetio antirefleks sloj. Ako pak pričamo o polarizaciji, to su sunčana stakla, koja mogu biti sa dioptrijom takođe. Sunčana sa dioptrijom Edited March 2, 2020 by Milutinac thumb 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 29, 2020 @Smireni kao što si rekao, nema potrebe ići na 1.74, više novca a razlika maltene neprimetna. Neki okrugao plastican ram (ako ti taj oblik stoji) i ima da izgleda kao -2 Gledaj Hoyu, Essilor, sa nekim boljim slojevima. Ta oštećenja su linije koje se od sredine stakla ka kraju šire? Quote Share this post Link to post Share on other sites
Smireni 524 Posted February 29, 2020 Više su paralelne, kao talasići bile prošli put, a ovaj put su kao tvirlovi na farbi auta, kao da im treba poliranje. Nikad mi se ovo nije dešavalo do sad, poslednjih 3-4 godine. Koji je rang cena za Hoyu i Essilor? Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 29, 2020 Deluje mi kao da je ispucao sloj (ako su bila izložena visokim temperaturama ili prejak pritisak na sama stakla prilikom ugradnje npr). 1.67 par stakala 17700 ili 21700 regularna cena. 1 Smireni reacted to this Quote Share this post Link to post Share on other sites
BGMilos 126 Posted February 29, 2020 Pozdrav, Da li je "problem" za naočare velika razlika dioptrija, čini mi se levo -2.5, desno -3.75? U jednoj radnji nisu hteli da mi urade takve naočare jer je navodno bila prevelika razlika, pa su valjda smanjili desno na -3 ili -3.25, tako nešto. Epilog, nisu mi ni malo prijale, stalno sam imao osećaj da mi se desno oko ulenjuje. Sledeće naočare sam uzeo u drugoj radnji i napisali su pravu dioptriju, te naočare sad nosim i ne vidim problem. Ima li ova priča smisla? Jedino mi pada na pamet da je možda veće izobličenje sa većom dioptrijom. Drugo, ima li boljih i lošijih antirefleks slojeva u smislu otpornosti na grebanje? Treće, koje su opcije za sunčana stakla sa dioptrijom, sad ovde videh da mogu da budu i polarizovana? Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 29, 2020 @BGMilos do 2.5 dioptrije može da se pravi razlika na naočarima, negde i do 2.75 (dosta ređe). Tebi je razlika 1.25. Tako da u prvom slučaju nisu uradili kako treba, što si i sam osetio. Vizuelno može da se primeti razlika kada te neko gleda pa je jedno oko manje drugo veće, mada je to izraženije na jačim dioptrijama. 2) ima, postoje razlike u slojevima, sve se da izgrebati nešto lakše nešto teže. Imaš nekih 4, 5 (u zavisnosti od proizvođača) kategorija antirefleksa. 3) opcije su maltene šta god zamisliš može da se napravi, polarizacija ima nekoliko boja koje se rade, imaš varijantu sa efektom ogledala kao što je kačio sliku @alfini0507 plus polarizacija, može da ide i blagi gradijent (gornji deo tamniji donji svetliji). 1 BGMilos reacted to this Quote Share this post Link to post Share on other sites
BGMilos 126 Posted February 29, 2020 @djomla Hvala, onda te definitivno cimam kad mi budu trebale sledeće naočare. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 2, 2020 On 2/28/2020 at 3:57 PM, djomla said: mada ako se ne varam je 3025 L2823, Bas ta! 1 djomla reacted to this Quote Share this post Link to post Share on other sites
