MS PK 7724 Posted October 8, 2021 Posto je? Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Desmo 429 Posted October 9, 2021 Samo sundjer oko 1000-1500 Noviji tip 2300 Komplet sa kucistem oko 3500-4000 Samo kuciste 2000 Interval zamene sundjerastog tipa je na svakoj drugoj zameni ulja, a noviji bi trebalo da radi duze Kuciste je isto za oba tipa 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Desmo 429 Posted October 9, 2021 3 meseca razlike i skoro 30% poskupljenja 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7724 Posted October 9, 2021 Pa da, sve je poskupelo od 30-200% ali smo tigrovi Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Desmo 429 Posted December 7, 2021 2 Reacher Gilt and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Desmo 429 Posted December 10, 2022 On 8/27/2020 at 11:46 AM, danijel55 said: Kako ti se cini ravenol ulje? Potrosnja na 10.400km Sledeca zamena na 300.000 Inace, drugar je prodao Golfa, verovatno ce otici u delove Quote Share this post Link to post Share on other sites
Desmo 429 Posted December 10, 2022 Nikako da se setim da resetujem servisni interval, od kako sam kupio auto. Bmw kaze: "6/2000 and later models. BMW introduced new service interval software which calculates service based on the amount of fuel used. When SII detects total fuel consumption that equals the preset limits (in gallons), the instrument cluster indicates that service is required. Using a 328i as an example: Standard transmission model: SII illuminates after consumption of 601 gallons of fuel. Automatic transmission model: SII illuminates after consumption of 667 gallons." Trenutno stanje: Videcemo za 10.000km kako ce biti raspolozen. Predpostavljam da ce biti ok jer mi je prosecna brzina oko 35kmh. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5285 Posted December 12, 2022 Koliko zanimljivih podataka oko tog servisnog intervala Mada su sve budalaštine Nisam znao da bmw računa po potrošenom gorivu, i da je kod manuelnog i automatika drugačije preset-ovano. Izračunale pametne glave da automatik manje drka motor i da može cca10% duže da ide sa istim uljem. I ovo od 650 galona tj. cca 2500 litara mi je baš mnogo... Ali 'ajde, primer je za 328 pa on možda troši u proseku 12-15l pa će zamena ulja da mu se upali oko 20.000km. Sigurno je kod svih modela (tj. motora) drugačiji preset. A kod tebe je očigledno na pređenu km pa bi se se valjda upalilo tek nakon pređenih tih 30hkm Quote Share this post Link to post Share on other sites
Desmo 429 Posted July 12, 2023 Presao na 5-40, usput prednje plocice i ubacio normalnu rezervu 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Desmo 429 Posted September 26, 2023 Da li 25.000km mnogo za interval filtera? 3 Reacher Gilt, igor0511 and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2175 Posted September 27, 2023 Ma neee ... 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5285 Posted September 28, 2023 Ako je na slici filter ulja, onda se doooobro drži...mogao je još malo, još 10ak hkm 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
Desmo 429 Posted September 29, 2023 Filter za vazduh je u pitanju, posle godinu ipo dana. Tezak smor od posla dok ga se dokopas... 1 1 PremieRacing and MS PK reacted to this Quote Share this post Link to post Share on other sites
Desmo 429 Posted January 27 On 12/10/2022 at 7:12 PM, Desmo said: Nikako da se setim da resetujem servisni interval, od kako sam kupio auto. Bmw kaze: "6/2000 and later models. BMW introduced new service interval software which calculates service based on the amount of fuel used. When SII detects total fuel consumption that equals the preset limits (in gallons), the instrument cluster indicates that service is required. Using a 328i as an example: Standard transmission model: SII illuminates after consumption of 601 gallons of fuel. Automatic transmission model: SII illuminates after consumption of 667 gallons." Trenutno stanje: Videcemo za 10.000km kako ce biti raspolozen. Predpostavljam da ce biti ok jer mi je prosecna brzina oko 35kmh. Quote Share this post Link to post Share on other sites
danijel55 699 Posted January 27 Od oca je na 330k km.Skoro remontovali turbo za smesnih 60e. Koliko sam razumeo samo je neke gumice menjao,ostalo sve po P.S-u. Quote Share this post Link to post Share on other sites
Desmo 429 Posted January 27 Kod mene turbo jos uvek ok, ali su zato dizne otisle tj jedna pa su uradili sve cetri. Postavicu slike papira koje sam dobio posle reparacije - nemam pojma sta je. Quote Share this post Link to post Share on other sites
danijel55 699 Posted January 27 Kod mene je zvizdala turbina,dizne ok sve. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 28 20k servisni interval? Quote Share this post Link to post Share on other sites
Desmo 429 Posted January 28 10,000 nego sam prosli put zaboravio da proverim kolika je razlika izmedju predjenih km i intervala koji preporucuje u odnosu na potroseno gorivo. Procitaj citat iznad pa ce biti jasnije Quote Share this post Link to post Share on other sites
Desmo 429 Posted February 4 Nece 15 na 300mm disk, probao sam za sad dva modela 46 (6.5inca et42) i 41 (7inca et47): Quote Share this post Link to post Share on other sites
Desmo 429 Posted February 9 Letnje 205.55.16 a za zimu videcu ili 15 ili 16 celicne. Poskupelo sve jbg mora za inč manje Quote Share this post Link to post Share on other sites
danijel55 699 Posted February 9 Ja mislim da na e46 320d ne može R15,cak je nema na stubicu kao ponuđenu dimenziju. Quote Share this post Link to post Share on other sites
Desmo 429 Posted February 9 (edited) U pravu su ali postoji nekoliko aftermarket točkova koji mogu preko 300mm diskova koliko su na 320d lci. Stari tip 320d je imao manje diskove (286mm čini mi se) i on je fabrički išao sa R15. Što se tiče e46 lci benzinci sa 4 cilindra su takođe išli sa R15 i 195 65: : Edited February 9 by Desmo Quote Share this post Link to post Share on other sites
