Peric187 0 Posted January 27, 2020 (edited) Cao svima imam alu romeo 159 1.9 120hp, problem je sledeci... Kada upalim auto obrtaji stoje kako treba, ali kada pustim auto u leru nizbrdo broj obrtaja porastu na 100. Hvala unapred! Edited January 27, 2020 by neshaoct preciziran naslov teme Quote Share this post Link to post Share on other sites
dejan_ns 90 Posted January 27, 2020 To je sve normalno, ne sekiraj se, samo vozi. 6 2 bit, neshaoct, djomla and 5 others reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted January 27, 2020 @Peric187 Kao što ti je več rečeno, tako treba da bude. Tako je napravljeno da bi auto lakše ''prihvatio'' kad ubaciš u drugu dok se kreće... Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 27, 2020 A i nema nikakve potrebe da ubacujes u ler nizbrdo. Nista bukvalno ne dobijas. Sent from my SM-J530F using Tapatalk 2 djomla and Ivan reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted January 27, 2020 Ako je do ustede goriva - ne dobijas nista kod novih auta (nisu karburator), ali sa drugog aspekta nema kocenja menjacem pa imas samo slobodno kotrljanje. Ako juris vecu brzinu na spustu tj duzi predjeni put bez, zato ga i izbacujes. Cesto je to i 'losa/stara navika' preostals iz voznje starijim automobilima.Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Peric187 0 Posted January 27, 2020 Hvala puno na odgovorima, mislio da je nesto ozbiljno, posto se ne razumem u automobile nesto narocito pa sam zato pitao. Quote Share this post Link to post Share on other sites
bit 936 Posted January 28, 2020 I plus vrlo je opasno voziti nizbrdo u leru, ni na jednom kursu vožnje to ne uče kandidate, uvek u brzini.Послато уз помоћ ТT 2 banjo1990 and djomla reacted to this Quote Share this post Link to post Share on other sites
igor0511 2870 Posted January 28, 2020 Samo jedna ispravka: dobija se ipak kod novih kola. Ko je vozio noviji DSG u eco modu, video je da izbacuje u ler kada se pusti gas. Ali je suvise rizicno to manuelno radiit jer nema kocenja motorom. Takodje, neka kola imaju rekuperaciju energije pri kocenju motorom. Mada su ovo sve smesne promene u potrosnji i ne treba toliko paziti. To je vec robovanje kolima. Onda lepo uzmes 1.4 dizel umesto 1.9 i ne pazis na te stvari ako je toliko bitno 2 Grafit and djomla reacted to this Quote Share this post Link to post Share on other sites
banjo1990 264 Posted January 31, 2020 Dobija se samo u određenim uslovima. Kod BMW-a u eco pro modu postoji podešavanje za ''coasting''. Tu se bira da li će menjač ubacivati u neutral pri svakom puštanju gasa ili ostajati u brzini. Izbacivanje u neutral po meni ima smisla jedino pri nekoj sporoj vožnji u gradskoj gužvi, gde bi se tako omogućilo da automobil može duže da se kreće sa minimalnim otporima kretanju. Na nizbrdicama to nema nikakvog smisla svakako, jer bi se kočnice svakako koristile da se redukuje brzina, a gorivo se ne bi uštedelo, već bi se naprotiv potrošilo više nego da je menjač u brzini. 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
Peric187 0 Posted February 8, 2020 Inace imam jos jedan problem koji ne znam kako da resim. Kazaljka za gorivo mi nije radila i majstor mi je rekao da uzmem plovak, ja uzmem novi plovak zamenimo majstor proveri sve super radi. Odma odem do pumpe sipam 12l ali skazaljka se ne pomera, pa sam opet otisao kod majstora on opet izvadi plovak proveri sve radi i tako nekoliko puta sipam ali se skazaljka retko kad pomeri. Da li moze da bude problem u satu ili u struji. Ma da mislim da nije sat. Pa ako je neko imao slicnih problema. Hvala na odgovorima unapred... Quote Share this post Link to post Share on other sites
