Dejan1991 0 Posted January 14, 2020 (edited) Dobar dan drugari imam problem jedna u pitanju je grande punto. Gori mi lampica za sijalicu a sve sijalice rade. Dali zna neko kako mogu da otklonim kvar. Hvala unapred Edited January 15, 2020 by neshaoct precizirao naslov teme Quote Share this post Link to post Share on other sites
neshtry 21947 Posted January 14, 2020 Stavljena od 5w a treba id 10w 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Vladajbg 1 Posted January 14, 2020 (edited) @Dejan1991 Dejane, zdravo. I ja Sam imao Taj problem sa lampicom sve rade a Gori lampica na instrument tabli. Resio tako sto otisao do elektricara i proverio sve lampice. Bila lampica od 5w a treba 10w. Edited January 15, 2020 by neshaoct dodao tag 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Dejan1991 0 Posted January 20, 2020 OK druže hvala ti sutra idem kod elektricara Quote Share this post Link to post Share on other sites
neshtry 21947 Posted January 20, 2020 Ma samo zameni sijalicu is 5w onom od 10w Quote Share this post Link to post Share on other sites
Lufti 821 Posted January 20, 2020 A koja je sijalica u pitanju? Pozadi u stop lampi za poziciju ili? Quote Share this post Link to post Share on other sites
ISV_01 5299 Posted January 21, 2020 @Lufti Te koje su uglavnom 'nevidjeni' (jerbo svetle pa ne znas koja je) su za kocenje jer su 10W (dvojna funkcija - svetle ko pozicija i kao kocnica) a odgovara u leziste i 5W. Za poziciju mogu biti ako su LED bez canbus-a ili otpornika (ponistavaca greske). E sad koja je... Ako mozes po odsjaju kocnice videti tim bolje. 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
Nikola 1.6 301 Posted January 21, 2020 Kod mene je bio problem u uzemljenju stop svetla. Quote Share this post Link to post Share on other sites
Luka051 1 Posted April 11, 2020 Poz, stavljao sam na svoj GP LED zarulje kao kratka svjetla, bilo je sve u redu jedno mjesec dana i onda mi se pojavilo upozorenje i poruka da provjerim svjetla. Vratio sam odmah originalne zarulje ali mi se upozorenje i poruka i dalje pojavljuje kada upalim pozicijska ili kratka svjetla. Sve zarulje sam provjerio i rade normalno, ali mi se zato kad dodam kontakt kod motora cuje kao neko kuckanje ili zujanje pa pretpostavljam da je tamo neki problem. Da li netko mozda zna do cega je to ili je imao slican problem? 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Ivan 28113 Posted April 11, 2020 @Luka051 Nepotrebno otvorena tema spojena je sa postojecom. Ni veci Fiati (Stilo, Bravo) nisu imali proveru sijalica na srednjem svetlu. Tako da problem nije do tih LED sijalica koje si stavljao (na stranu sto je to funkcionalno pogresno resenje ). Tako da je problem u nekom drugom sijalicnom mestu i generisanoj neodgovarajucoj otpornosti. To mogu da budu pozicije, sijalice tablice, migavci, stopke, zadnje maglenke ili dnevna svetla ako postoje. Ispisuje li se nesto dodatno na ekranu kada se upali upozorenje? Na Stilu i Bravu je pisalo tacno sijalicno mesto, sa dodatnom strelicom na kojoj strani je problem. Quote Share this post Link to post Share on other sites
Luka051 1 Posted April 11, 2020 (edited) Na tabli mi pise check running lights i sve mi sijalice gore normalno, samo to cudno zujanje/kuckanje kod motora iza suvozackog fara di ulaze neke tanke zice prema motoru Sve su sijalice sad originalne tako da nemam ideje o cemu se radi Edited April 11, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Ivan 28113 Posted April 11, 2020 Za tu poruku, pogledaj i ovu temu (nadam se da si procitao prethodne postove u ovoj temi sa kojom je spojeno tvoje prvo pitanje)...: Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted April 16, 2020 (edited) @Ivan Reseno je to odavno,hvala Edited April 16, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
jevta 309 Posted April 16, 2020 @Goksi1980 I šta je bilo Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted April 17, 2020 (edited) gubila kontakt, kablaza Edited April 17, 2020 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
neshtry 21947 Posted April 17, 2020 I meni u zadnje vreme (od kada je korona, pa auto stoji puno), radi upozorenje za levu zadnju poziciju. Upali se ujutru na prvo jutarnje paljenje, a kada drugi put upalim prestane i nema ga do kraja dana. Sumnjam na šteker koji ide u zadnju lampu, za vikend skidam sve i prskam sa Wirthom za čišćenje,pa šta bude. Quote Share this post Link to post Share on other sites
virke 81 Posted June 25, 2021 Treba mi save od kolega sa foruma :D) Desava mi se da kada pritisnem kocnicu dobijam upozorenje da preverim dnevna svetla i stoji mi kao da mi je crkla neka sijalica. Kad pustim kocnicu ta poruka nestane i sve je ok. Sve mi sijalice rade. Danas bas kolega vozio iza mene i kaze da se pale svetla od kocnice kada kocim. Ima li neko ideju gde da gledam? U cemu moze biti problem. To je pocelo pre nekih 2 nedelje da se desava. Pa nije par dana pa sad opet. Quote Share this post Link to post Share on other sites
neshaoct 9797 Posted June 25, 2021 (edited) 29 minutes ago, virke said: Ima li neko ideju gde da gledam? Imam ja ...da pogledaš ranije napisane postove teme na kojoj smo, i tako pročitaš ovo: On 1/21/2020 at 8:24 AM, Nikola 1.6 said: Kod mene je bio problem u uzemljenju stop svetla. Plus i link ka ovoj temi: - https://www.fiat-lancia.org.rs/forum/index.php?/topic/78178-grande-punto-signalizacija-otkaza-oboreno-svetlo/ Edited June 25, 2021 by neshaoct zamenio link 1 virke reacted to this Quote Share this post Link to post Share on other sites
virke 81 Posted June 25, 2021 Procitao sam vec. Imao sam problem sa dnevnim svetlima. Generalno mi crkavaju sijalice na 3 meseca odprilike i kad mi se pojavi t greska znam odmah sta je. Ovo je nesto novo i kapiram ja da je neki kabal problem ali ne znam koji Sad da prevrcem sve kablove ne ide Imam drugara koji se razume u struju ali kad sam bio kod njega sve je radilo NIje se pojavljivala greska,sve lampice svetle. Quote Share this post Link to post Share on other sites
neshaoct 9797 Posted June 25, 2021 @virke Skini zadnja svetla (kreni od levog), verovatno je ista stvar kao kod Punta mk.2: - https://www.fiat-lancia.org.rs/forum/index.php?/topic/40481-fiat-punto-mk2-problem-sa-zadnjim-svetlima/ On 2/24/2010 at 10:30 AM, chikavili said: desava mi se da kad upalim auto i drzim kocnicu, prijavljuje mi na tabli gresku u svetlosnoj grupi On 2/24/2010 at 3:50 PM, slobelix said: Jedan od kontakata se slepi sa plastikom u konektoru za zadnje svetlo, njega iscackajte iz plastike, povucite na gore, poprskajte svemocni wd40 i radice kao novo ;-) Naravno mora da se skine zadnja svetlosna grupa... On 2/24/2010 at 9:58 PM, mikisxy said: zadnja zica u konektoru stop svetla crne boje ,masa ima los kontakt sa lampom.ocisti i malo nategni buksnu u konektoru resice ti zez On 2/25/2010 at 11:31 AM, banetv said: I kada već rasturaš, očisti i zajedničku masu koja ti je na limu odmah ispod levog stop svetla. On 3/1/2010 at 1:34 PM, chikavili said: Rasturio sve, kontakti od mase bili skroz razdvojeni, patinirali, cak je i plastika malo progorela. Ocistili, "stisnuli" i sada sve opet funkcionise normalno 1 virke reacted to this Quote Share this post Link to post Share on other sites
virke 81 Posted June 25, 2021 Hvala. To je to sto mi treba. To mogu i sam Valjda Quote Share this post Link to post Share on other sites
virke 81 Posted June 26, 2021 (edited) Rasturio sam danas stop svetla. isproveravao sve. Nista nigde nije nagorelo. Dzekovi su okJedino na kontakt limu gde ide sijalica ima malo oksidacije. To sam skinuo i vratio. Prilikom parkiranja auta nije se pojavljivala greska. Da li sam nesto uradio videcemo sutra Edited June 26, 2021 by virke 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
virke 81 Posted June 28, 2021 Juče sam se malo vozio i za nekih 150km nije se nijednom upalila greska. Izgleda da sam rešio problem. Kakva glupost! Hvala svima na pomoći i savetima! 2 Nebek and stex_pb reacted to this Quote Share this post Link to post Share on other sites
MISHONNIUM 15 Posted March 1, 2023 Da li je moguce da one tri skroz male lampice u modulu ventilacije upale gresku? Ne znam da li je to koincidencija ali meni se upalila greska nakon zamene tih lampica. Gresku nije javljao dok su te lampice bile defektne. Ziveli Quote Share this post Link to post Share on other sites
ISV_01 5299 Posted March 1, 2023 Te su 2.3W, ako su stavljene odgovarajuce, ne bi trebalo. Imao sam i LED kao osvetljenje isto tu ali nisam imao gresku, pa se vratio na zarulje...vise traju. Proveri tablice, migavce, pozicije ali i sijalice za kocenje. Kod Brava one imaju dve zarulje, jedna kao pozicija, druga za kocenje, pa vidi da neka nije crkla. Nema prijave greske za duga i oborena svetla, maglenke i rikverc svetlo. Quote Share this post Link to post Share on other sites
