Mijailović P. 3396 Posted May 29, 2021 @Ivan Ne, hvala ne poštovani kolega! Mis'im, što je previše-previše je. I ovako ne znam kako bih se ja revanširao. Quote Share this post Link to post Share on other sites
danijel55 694 Posted May 29, 2021 Lepo izgleda, jos da su druge felne,bilo bi jos dosta lepse 2 Mijailović P. and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted May 29, 2021 47 minutes ago, Ivan said: Ako si vec toliko emotivno vezan za 16'' felne. Kad dobijam distance? 2 Mijailović P. and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17449 Posted May 29, 2021 Ti imas celicne felne+ratkapne, tu nema pomoci . 16 minutes ago, Mijailović P. said: Ne, hvala ne poštovani kolega! Dobro, onda umesto distancera, prihvatices valjda bar distancere+duze srafove . 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted May 29, 2021 Ma u planu su nekak'e 17' sa letnjim da se kerimo ali ne mere kuja stići zeca. 2 Reacher Gilt and MS PK reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted May 31, 2021 (edited) @Ivan Ako nije tajna koliko kosta set distancera za bravca za fabricke sport 17ke? I kolike distancere staviti uopste napred i nazad? Edited May 31, 2021 by Branislav Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted May 31, 2021 Oko 100 evra izadje sve. Stavlja se obicno 16 ili 20mm... Quote Share this post Link to post Share on other sites
Ivan 17449 Posted May 31, 2021 (edited) @Branislav Vidjao sam najcesce distance od 20 mm u kombinaciji sa fabrickim Bravo 17'' felnama, vozi se bez problema. Koliko se secam, imao je ovde jedan Bravac sa distancima 25. Imaj u vidu da i te Sport felne (za koje pitas) postoje u verziji ET od 31 mm (pre restyle) i trunku izbacenije sa ET 26 (posle restyle). Set distancera i srafova je bio reda velicine 10.000 din u Vracaru, zavisi opet gde uzimas. Edited May 31, 2021 by Ivan 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Pluto 448 Posted May 31, 2021 @Ivan da li imaš neku skicu distancera sa dimenzijama pošto bi video da ih neko napravi? I ja sam na 16 i sada kaada razmišljam, dobro bi mi došli, točkovi su uvučeni dosta. Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted May 31, 2021 Ovako nešto... 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Bule 69 Posted May 31, 2021 Ima dečko u Batajnici pravi distancere nađi ga na Kupujem prodajem ja sam kod njega pravio 10eur kom do 20mm 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Ivan 17449 Posted May 31, 2021 2 hours ago, Pluto said: @Ivan da li imaš neku skicu distancera sa dimenzijama pošto bi video da ih neko napravi? Zvrcni i njih pa proveri cene: https://2017.tuningstyling.co.rs/ 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted June 18, 2021 (edited) @Branislav "Gde si ugradjivao plin? Koliko ti trosi plina, koliko ulja na 10k? Koliko si presao na plinu do sada? Planiram da ugradim plin pa mi trebaju informacije, Ac Babic trazi 450e za ugradnju sto je skroz korektno" Plin ugradjen kod jednog od poslednjih "Dinosaura" iz tog sveta vrsnih majstora stare skole! Pedantno i tacno! Majstor DORA sa Belih Voda! Potrosnja je vise nego zadovoljavajuca. Negde oko 8L u proseku. Do sada sam pregazio dosta bez problema. Nadam se da ce tako i ostati. Uredjaj je AC i racunar QBox+. Ja sam platio nesto vise ali nije strasno i ne zalim. "Merak nema cenu!" Sve ovo sam vec pisao u mojoj temi. Sada sam i akumulator promenio. Iako sam negde napisao da je iz '19. godine, greska. - Iz '13. je. Bilo mu je vreme a dosta je izdrzao kod mene. Sada gasni uredjaj moze samo bolje da radi. Edited June 18, 2021 by Mijailović P. 1 TheWickerMan reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted June 18, 2021 Jel ti se plin toci odmah pored benzina? Tj imas onaj nastavak ili? Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted June 18, 2021 Ne, nisam hteo tako. Dole na braniku je prikljucak. Rade ljudi po zelji. Quote Share this post Link to post Share on other sites
Ivan 17449 Posted June 18, 2021 45 minutes ago, Mijailović P. said: Taman zaboravimo i covek nas opet nervira i provocira . Ovo mi sve vise lici na kampanju koja bi trebalo da se sankcionise . 1 1 Mijailović P. and djomla reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted June 18, 2021 Udri br'te, naši smo! 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
dekirs 4818 Posted June 18, 2021 Lele.. pa gde plin na t-jeta Greota.. 2 Mijailović P. and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17449 Posted June 18, 2021 Deki, druze, aj' sto je plinadzija - nego nam postovani kolega vec duze vremena dodatno skace po ganglijama sa ovim 16'' sa velikim ET . Malo, malo pa podje*ava narod sa ovim uglovima iz kojih slika . 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
dekirs 4818 Posted June 18, 2021 Ma...Dao bih ja njima za kaznu jednog dizla koji ima par sklopova pred umiranjem, cisto da vide da im ta potrosnja benzina nije toliko strasna A sto se tice felni, znam jedne 17" sport sto stoje u podrumu 1 2 djomla, Mijailović P. and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted June 18, 2021 Ljudi, pa nije to tako strašno... Quote Share this post Link to post Share on other sites
Ivan 17449 Posted June 18, 2021 Evo Deki, vidis o cemu ti pricam. 1 hour ago, dekirs said: A sto se tice felni, znam jedne 17" sport sto stoje u podrumu Onaj sto ih koristi kao kamen za kupus? Od njega su svi digli ruke jos u startu , neozbiljan je imenjak totalno. 1 4 djomla, dekirs, ISV_01 and 2 others reacted to this Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted June 18, 2021 1 hour ago, dekirs said: A sto se tice felni, znam jedne 17" sport sto stoje u podrumu 9 minutes ago, Ivan said: Onaj sto ih koristi kao kamen za kupus? 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ivan 17449 Posted June 18, 2021 Zovi kad montiras, dolazim specijalno za tu priliku, castim sve kod Intera . 2 1 Mijailović P., Reacher Gilt and djomla reacted to this Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted June 18, 2021 @Ivan Blizu je avgust, polako Ofc dolazim bez cepova, imao sam fizicke pretnje oko istih 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
