Milutinac 5906 Posted November 25, 2019 Rade li na ovoj naplatnoj rampi kamere? Na nekima ne...rade...kazu... 2 dekirs and Grafit reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted November 25, 2019 Kako za koga 1 bglion reacted to this Quote Share this post Link to post Share on other sites
Ivan 17666 Posted November 25, 2019 Je*o te, koja glupost... Citam i ne verujem, kako stvari stoje na nasim putevima vise nista ne treba da nas cudi... Nadam se da ces uspeti da to naplatis i saniras bez problema, zali Boze izgubljenog vremena i zivaca . 5 horvat, djomla, bit and 2 others reacted to this Quote Share this post Link to post Share on other sites
Lufti 690 Posted November 25, 2019 Bitno je da niko nije povredjen. Steta za auto ali ce se sve to zameniti. Ja sam pre odredjenog vremena za malo izbegao spustanje rampe. Nisam pustio dovoljno kamion ispred sebe da prodje kroz rampu nego sam isao prakticno 10m iza njega nekih 30km/h i bukvalno sam stao na 10cm od rampe koja se zatvorila. Neprijatno ali poucno iskustvo... Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted November 25, 2019 Vec sam se toliko odomacio sa TAGom da prolazim i sa 60-70km kroz punkt, mislim da mi se malo vraca paranoja sa pocetka koriscenja taga kada sam zazirao hoce se dici ili ne rampa. 1 1 PremieRacing and horvat reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted November 25, 2019 Milion puta mi se nije digla rampa, ma ne bih nikad opusteno prosao, nema sanse Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted November 25, 2019 Citao sam takva tudja iskustva, ali srecom nikad to nisam doziveo pa sam izgleda pustio mosnice Quote Share this post Link to post Share on other sites
horvat 6456 Posted November 25, 2019 42 minutes ago, vagenovac said: Vec sam se toliko odomacio sa TAGom da prolazim i sa 60-70km kroz punkt, mislim da mi se malo vraca paranoja sa pocetka koriscenja taga kada sam zazirao hoce se dici ili ne rampa. Upravo ovo... Sa onim prvim, velikim TAG-om je stvarno bilo tripovanja svaki put, i redovno sam usporavao do ~30 km/h, ali otkako sam presao na ovaj noviji, mali, ne pamtim kad sam ispod 60 prosao Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted November 26, 2019 Tako ispadne sad iz mog konkretnog iskustva... Kad prođeš brzo, ništa se neće desiti. Ja prošao polako, gledam na ekranu koliko mi je preostalo para i bum. Zabagovao sistem. Jbmlg, ne mož' biti pametan. Nego, gledam sad osiguranje i shvatim da sam jeftinije platio kasko od obavezne polise auto odgovornosti... Kakva nebuloza Quote Share this post Link to post Share on other sites
S.V.E.T.A. 125 Posted November 26, 2019 Gde si uzeo kasko i da li je u pitanju full ili mini? Koliko te je izasao? Hvala Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted November 26, 2019 DDOR - 21.000,00 Nisam uzeo ništa od onih dodataka, skinuo sam 5-6hdin od prvobitne ponude tako, i još dobio popust za plaćanje od jednom. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
skile86 539 Posted November 26, 2019 To je bas povoljno. Meni su za Astru u Dunavu trazili oko 35k. Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted November 29, 2019 Sredžene kugle i sileni na viljuškama. Kpl remont. Ostala reglaža za danas ili sutra. Iako je sada mnogo utegnutija u vožnji, i dalje nešto famozno lupka na trapu a meni se sve čini da je pozadi... Saga tj. potraga se nastavlja. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted November 29, 2019 Primetio sam da problem sa lupanjem imaju fabricki auti 2 djomla and horvat reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted November 29, 2019 Pisalo se po forumu da Eibach Pro-Kit resava sve zvukove iz trapa 1 YUgisa reacted to this Quote Share this post Link to post Share on other sites
Quadrifoglio Verde 9319 Posted November 30, 2019 (edited) 17 hours ago, PremieRacing said: Sredžene kugle i sileni na viljuškama. Kpl remont. Ostala reglaža za danas ili sutra. Iako je sada mnogo utegnutija u vožnji, i dalje nešto famozno lupka na trapu a meni se sve čini da je pozadi... Saga tj. potraga se nastavlja. Verovatno mali luft u samom amortizeru. Na kanalu drži ruku u donjem delu amortizera dok neko ljulja auto i "osetićeš ga". Zato sam se ja i raspitivao za cene zadnjih amorta. Edited November 30, 2019 by Quadrifoglio Verde 1 1 PremieRacing and horvat reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted December 7, 2019 Montirane ziNske gume, spremamo se za ng praznike. Dimenzija 205/50 i dosta udobniji i meksi auto. Vrvtn zbog ogromnih krampona i mekane zimske smese. I na volanu meksi, cudniji, ruzniji... Quote Share this post Link to post Share on other sites
darkman14 5900 Posted December 7, 2019 Koje gume i otkud 205? Quote Share this post Link to post Share on other sites
Ivan 17666 Posted December 7, 2019 Meni je to OK izbor velicine i generalno za zimske, ako se ostaje na 17'' felni. Sama guma je uza za 2 cm i tu je najveca razlika. Sto se visine tice, maltene je identicna, 205/50/17 je visa 0.12 cm od 225/45/17. Kod Fiata su i 16'' i 17'' OEM felne identicne sirine po 7'', tako da uza guma stoji i malo lepse i manje je bokasta. Iako se 225/45/17 odavno izdvojila kao standard, vidim da dosta vozila fabricki ide upravo sa tom malo uzom 205/50/17. Mislim i da je ta dimenzija jos uvek nesto skuplja od 225/45/17. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted December 10, 2019 Ja sam hteo i na 195 da idem, ali nisam našao zadovoljavajuću kombinaciju.... Svakako mi ovo sad montirano ostaje za sve buduće zime a za leto idemo na 18+ 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
francuz69 995 Posted December 10, 2019 Opaaa, jel to znaci da si nasao "one" felne? Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted December 11, 2019 Nisam, kamo puste sreće... Tražim i nadam se da ću naći, najviše bi voleo fabričke felne ali ako do lepog vremena ne bude ništa od te zamisli lako ću kupiti nešto drugo što mi se dopadne. Već uveliko razmišljam o Bojketovim 19" ali nemojte da mu kažete 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
werp690 459 Posted December 11, 2019 Tek sada vidim temu.Prelep auto sa brutalnom motorizacijom! Puno bezbrznih km ti zelim.Posto sam iscitao celu temu boju na fabrickim plastikama mozes da vratis silikonskim sprejom.Osevezi ih i vrati im fabricki look,mana nije trajno ali uvek mozes da ga posle par pranja naprskas ponovo za bukvalno minut i po i utrljas krpom.Srecna potraga za felnama! Meni se te fabricke Lancia felne bas svidjaju,a nosi ih samo Delta i to donosi opet neku posebnu draz...Pratim.... 3 PremieRacing, Milutinac and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17666 Posted December 11, 2019 1 hour ago, werp690 said: Meni se te fabricke Lancia felne bas svidjaju,a nosi ih samo Delta i to donosi opet neku posebnu draz...Pratim.... +1 Quote Share this post Link to post Share on other sites
darkman14 5900 Posted December 13, 2019 (edited) Ono malo sinoc je bilo bas dobar osecaj, tisina u odnosu na mjtd, linearno ubrzanje... Edited December 13, 2019 by andreja.micovic gif 3 horvat, Quadrifoglio Verde and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
