AcaKs 9 Posted September 6, 2019 (edited) Pre par dana doterah ovaj automobil, auto je generalno u vrlo dobrom stanju. Po dolasku zamenio sam ulje. Ima pravih 180.000km, dobre gume dot 18, potrebno je napuniti klimu (živim na selu pa nisam u mogućnosti da oteram auto do grada da to završim) Cenim ga 3650e, postoji korekcija, za zamenu nisam zainteresovan. Ide na ime kupca uz mogućnost prevoza. 0642860383 Edited September 7, 2019 by neshaoct formatiranje & preciziranje naslova teme Share this post Link to post Share on other sites
kroki23 3 Posted September 6, 2019 Godiste si zaboravio. 1 neshaoct reacted to this Share this post Link to post Share on other sites
AcaKs 9 Posted September 7, 2019 (edited) Decembar 2007. Edited September 7, 2019 by neshaoct pismo Foruma Share this post Link to post Share on other sites
Milutinac 5906 Posted September 9, 2019 On 9/6/2019 at 5:43 PM, AcaKs said: potrebno je napuniti klimu (živim na selu pa nisam u mogućnosti da oteram auto do grada da to završim) Mala samo ispravka. Ovo treba da pise - klimu je potrebno srediti/popraviti. Klima nikada ne iscuri sama od sebe, bar ne toliko da potpuno ne radi. Vidjao sam kola kojima 15 godina nije dopunjavana klima - a opet radi. Moze da bude problem od 2500 dinara, a moze da bude i od 300 evra. 7 totti, djomla, polaris and 4 others reacted to this Share this post Link to post Share on other sites
AcaKs 9 Posted September 9, 2019 Radi ali slabije hladi. Share this post Link to post Share on other sites
Dule 021 660 Posted September 10, 2019 Interesantan za trkače i one koji vole da imaju snage u rezervi. Obicno izgleda a onda otrese dosta kola kad se naljuti. Jos ako se čipne..... Share this post Link to post Share on other sites
dekirs 4819 Posted September 10, 2019 Ako se cipuje ode ovo na 180ks laganih Share this post Link to post Share on other sites
darkman14 5898 Posted September 10, 2019 1 hour ago, dekirs said: Ako se cipuje ode ovo na 180ks laganih Ako pitaš cjunera da ti učita mapu sa delte tt može i na 190ks sve je to isto 1 3 Milutinac, dekirs, djomla and 1 other reacted to this Share this post Link to post Share on other sites
dekirs 4819 Posted September 10, 2019 Pa to mozda kod Safeta Share this post Link to post Share on other sites
AcaKs 9 Posted September 10, 2019 Deluje mi da prilikom malo žustrije gradske vožnje zna lepo da potroši, dok mi je recimo prosek na auto putu bio 4.8l mereno od čepa do čepa sa nemačkim dizelom. Vozio sam TDI od 103kw i primetno je da MJET ide bolje. Share this post Link to post Share on other sites
marko.jovanovic 925 Posted September 10, 2019 (edited) Hahaahhah, prosek na auto putu 4,8l/100km Kladim se da nisi prešao 120km/h. Evo duel, Fiat Bravo 1.9mjet 16v 150ks vs Golf 5 2.0TDi 140ks: http://www.zeperfs.com/en/duel1901-1200.htm Bravo ide nešto malo bolje, ne bih rekao da je to primetno bolje. Golf 5 2.0TDi 140ks je bolji u međuubrzanjima, a tu se najpre primeti koji auto ide bolje u praksi, a ne u maksimalnom opterećenju. Edited September 10, 2019 by marko.jovanovic 1 dejan_ns reacted to this Share this post Link to post Share on other sites
AcaKs 9 Posted September 10, 2019 Tempomat 130kmh sa dosta radova na putu. Prešao 245km i dolio 11.6L. Share this post Link to post Share on other sites
MS PK 7729 Posted September 10, 2019 Jedino ako ti je takva neka deonica puta bila, neko blago nizbrdo, vetar u ledja ili nije lepo sipano. Na 130km/h ocekujem skoro 6l ox njega Послато са SM-J330F помоћу Тапатока Share this post Link to post Share on other sites
AcaKs 9 Posted September 10, 2019 Zinshajm - Parsberg. Ima i ravnice i brda mešano, to je auto put od Karlsruhe ka Ninbergu i Regensburgu. Inače uvek čuvam račune od kupovine goriva i imam tačno isplanirane pumpe na kojima punim rezervoar. Trudim se da što manje upotrebljavam kočnicu i izbegavam nagla ubrzanja tako da možda i to ima uticaja, ali kao po pravilu kada sipem gorivo u Subotici potrošnja se obavezno poveća minimum za 1-1,5L. U nemačkoj dizel 1.22e a kod nas 160din. Share this post Link to post Share on other sites
AcaKs 9 Posted September 24, 2019 Gospodo, imam jedno pitanje za nekog ko se razume. Da li je normalno da kvačilo na Bravu hvata maltene na kraju, znači kada se stisne do kraja on tada tek odvoji, takođe to je propraćeno neznatnom promenom rada kada je kvačilo stisnuto do kraja kada je auto hladan, kasnije to se skoro izgubi,interesuje me šta li to može biti? Share this post Link to post Share on other sites
vagenovac 4533 Posted September 24, 2019 Trebalo bi zameniti kvacilo i druk verovatno. Share this post Link to post Share on other sites
AcaKs 9 Posted September 25, 2019 Hvala na odgovoru Share this post Link to post Share on other sites
AcaKs 9 Posted September 26, 2019 Iz gore navedenog razloga spustam cenu na 3300e. Share this post Link to post Share on other sites
