Filip_19 2 Posted September 4, 2019 (edited) Pozdrav raja, kao prvo (Nisam u Srbiji pa nemam problema sa tehničkim... Samo napomena) pa ne morate objašnjavati to, javljam se ovdje jer bih pitao stručnije ljude da li je moguce Fiatov 5ak 2.0 20V Turbo ubaciti u Lybru, posto moja Lybra ima fabricki 2.0 5ak ali nekako mi slab i spor i dosadan, pa bi volio upakovat Fiatov motor no nisam siguran ciju struju da koristim i ciji kompjuter tj ECU da koristim Drug mi ima slupanog Fiata Coupe 2.0 20V Turba i eto mi donatora, volio bih ako je iko tako nesto slicno radio da mi da koji savjet, jer zelim da sredim ovu Lybru, ali je naravno problem to sto nikad niko jos nije ubacio taj motor u Lybru i iako bi mehanički dio rijesio, problem ostaje struja jer sam slab sa istom... Samo da napomenem meni se isplati i nije mi to skupo jer to auto zelim slozit za sebe, imam 20 godina i zelim si ispunit ovu dugogodišnju zelju Unaprijed hvala Edited September 4, 2019 by neshaoct precizirao naslov teme 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
horvat 6451 Posted September 4, 2019 (edited) Interesantna ideja, ima po forumu ljudi koji se bakcu sa Fiatovim 2.0 20v turbo iz Coupe-a : @Backo, @bojke npr... Edited September 4, 2019 by horvat 1 Filip_19 reacted to this Quote Share this post Link to post Share on other sites
edinko 5 Posted September 4, 2019 (edited) @Filip_19 Moze. Edited September 4, 2019 by neshaoct dodao tag 1 2 Filip_19, horvat and neshaoct reacted to this Quote Share this post Link to post Share on other sites
bojke 126 Posted September 4, 2019 (edited) @Filip_19 Uzmes kompletan motor sa menjacem,agregatima i strujom i prebacis u lybru bez problema. Edited September 4, 2019 by neshaoct dodao tag 1 2 PremieRacing, Filip_19 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
edinko 5 Posted September 4, 2019 I pumpa u rezervoaru da se sredi pumpa. 2 Filip_19 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
BGMilos 126 Posted September 4, 2019 Moj neostvareni san Jedino što mi pada na pamet je klapna gasa, ona je kod Lybre elektronska, a na papučici gasa je senzor položaja, a ako se ne varam kod Coupe-a je drugačija klapna koja je sajlom povezana sa papučicom gasa. Što znači da bi trebala papučica gasa da se prebaci na sajlu. 2 Filip_19 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
Filip_19 2 Posted September 4, 2019 Hvala raja na pomoci i savjetima, nadam se da cu ubrzo pocet sa rasklapanjem pozz za svu raju ljubitelja Talijana 1 bojke reacted to this Quote Share this post Link to post Share on other sites
