shuxx 10772 Posted May 25, 2019 Sta reci.... Ugradili mi Stag 200 GoFast pre mesec dana. Majstor ima instaliranu verziju na kompu Stag 200 easy 0.26.0.9096 firmware koju sam i ja skinuo i instalirao... imam kabal / interfejs... ali mi komp ne prepoznaje povezan auto... tj ima neki problem sa USBom....Probao sam update drivera na USB... ali ne pomaze.... Ima li kakav savet sta da radim da omogucim povezivanje kompa sa kolima... Hvala unapred Sent from my SM-A320FL using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
shuxx 10772 Posted May 26, 2019 Svratio sam do majstora. Proverili kabal / interfejs. Radi. Ali on mi ne moze pomoci... i njemu su drugi instalirali i povezali...Zna li neko sta da radimPodesavanja na laptopu... usb......Sent from my SM-A320FL using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 449 Posted May 26, 2019 Jel imas podesavanka na interfejsu? Pregledaj portove da li su isti ako imas to u opcijama. Probaj drugi baud rate porta Quote Share this post Link to post Share on other sites
shuxx 10772 Posted May 26, 2019 Probao sam da menjam mesto prikljucka kabla. Na sve usbove / portove. I nece. Kad god prikljucim kabal..izbaci mi gresku na usb serial portSent from my SM-A320FL using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted May 26, 2019 To znaci da fali drajver, odnosno nije prepoznat. Ako imas softver, reinstaliraj pa probaj opet. Ako ne, pogledaj za taj softver u google sa usb serial port missing ili nesto drugo. Sent from NOMU S10 PRO using TapatalkPS moguce da je i kabl i prikljucak ok, nego jednostavno fali drajver za taj prikljucak/kabl/ interfejs, kao sto sam naveo goreSent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted May 26, 2019 Instaliraj ISB uart ...sa TT Quote Share this post Link to post Share on other sites
shuxx 10772 Posted May 27, 2019 Skinuo jesam. I instalirao. Sta dalje... cemu sluzi....Sent from my SM-A320FL using TapatalkI dalje mi pokazuje gresku na usb portuSent from my SM-A320FL using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted May 27, 2019 Idi na device manager, gde ti je taj USB koji ne prepoznaje, desni klik, update driver. Probaj prvo sa automatic (mozda ga prepozna sam) a ako ne na manual i preko browse, idi gde je drajver instaliran i nadji ga. Ako nisi siguran za lokaciju gde je drajver instalirao, pokreni ponovo instalaciju drajvera pa samo vidi gde je lokacija (ne moras instalirati ponovo), copy-paste lokaciju i paste u windows explorer sa folderima u bar sa trenutnom lokacijom (ne internet) i trebao bi da te direktno baci tamo gdw je instaliran. Sporija varijanta je da upamtis (mozes copy u notepad) pa peske da dodjes do lokacije. Sent from NOMU S10 PRO using TapatalkU principu tako je za sve drajvere koje komp ne moze prepoznati (za XP pogotovu) Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
shuxx 10772 Posted May 27, 2019 MomciSta reci ... RADIIIIIdodjem turu pica. Kad god ste u kraju...Veliko HvalaNasao drivere AutomatskiIdem da cackam po podesavanjimaJos jednom HvalaSent from my SM-A320FL using Tapatalk 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted May 27, 2019 Jedan problem manje Udri po softveru sad Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
shuxx 10772 Posted November 17, 2019 Stag lepo radi. Malo sam mapu stelovao. I bas se dobro poklapa sa benzinskom.... ali...Menjao sam laptop... nov dosao sa Win 10... instalirao program za dijagnostiku... ali ne vidi komp od staga...Ima li pomoci za win 10 + stag program.....Sent from my SM-A320FL using Tapatalk 1 vasqe reacted to this Quote Share this post Link to post Share on other sites
shuxx 10772 Posted November 23, 2019 Ajd malo pomoci... softver za stag...i win 10... kako uklopiti da radiiiiSent from my SM-A320FL using Tapatalk Quote Share this post Link to post Share on other sites
neshtry 14776 Posted November 23, 2019 Drajver instaliraj u kompatibiliti modu za verziju OS za koji drajver pravljenhttps://youtu.be/BUJjuft2yN8Poslato sa POT-LX1 pomoću Tapatoka 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 10772 Posted January 19, 2020 Probah i kompatibiliti mode. Ne pomaze. Ima li neko jos neki predlog kako da stag povezem sa win 10Sent from my POT-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 17, 2020 Vako, ovo je link> Oficijalni sajt AC.COM - STAG 200 EASY gde se nalazi glavni drajver za instalaciju softvera za pomenuti uređaj. Ja skinuo na W10, pokrenuo proces instalacije (video da radi) pa prekinuo jer mi isti ne treba. Ako je to taj softver - to je to. Ako ne, javljaj pa da rešavamo. Quote Share this post Link to post Share on other sites
shuxx 10772 Posted September 17, 2020 Taj sam i ja instalirao. Povezao sa kablom. I probao na sva tri USBa... Ali izbaci poruku No lpg controler...Sent from my POT-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 17, 2020 Da li si probao proceduru sa USB-om kao ranije opisano ? Sigurno ga ne prepoznaje ? PS: Sad vidim da je bio neki update za kontrolere, pa vidi da instaliraš iste, možda postoji neki update za drajver u njima ili slično: AcSTAG controller Inače baci pogled na Uputstvo za povezivanje kontrolera za STAG 200 strana 10, možda ima i tu neki hint. Quote Share this post Link to post Share on other sites
shuxx 10772 Posted September 17, 2020 Sad mi ovo izbacujeSent from my POT-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 17, 2020 Uh, malo je mrljavo. Da li to piše da je drajver kontrolera noviji ? Probaj da postavis screen shot sa PC-ja (da, jeste duže i zamornije, ali čista je slika - Print screen dugme (PC) ili FN + Print screen (laptop) pa u paint i save as (izabereš JPG) i postaviš kao sliku. Ako je drajver noviji, onda zato i neće da uradi update. Quote Share this post Link to post Share on other sites
shuxx 10772 Posted September 17, 2020 Moracu da prekinem ovo. Internet na laptopu mi ide preko telefona. A telefonu baterija prazna...... Sent from my POT-LX1 using Tapatalk 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
shuxx 10772 Posted September 18, 2020 (edited) slike su odlične na telefonu, ali je kompresija zeznula tekst piše its required to update contoller firmware to newer... koliko kapiram moj kabal nije odgovarajući ???? Edited September 18, 2020 by shuxx Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 20, 2020 Aha, sad kontam. Vidi, firmware je neki update vezan za softver ili odredjeni drajver (u ovom slucaju tvoj kontroler) koji bi trebao biti kompatibilan sa novijim softverom (W10 ili neki deo instalacije STAG softvera da bi ga windows mogao detektovati). Ono sto sam nasao, a odnosi se na firmware za STAG 200 go easy je ovo Klik E sad, posto je na poljskom najbolje mu na stranici stavi prevod jer ne umem da 'dodjem' normalnim putem do te sekcije jer ne znam gde se nalazi na sajtu. Istkna, koji firmware koristiti.. Ne znam. Ja bih isao na najnoviji, jer po logici stvari, on bi trebao objediniti sve starije firmware-ove za taj kontroler ili neki potreban deo. Ne znam da li se i kako manifestuje instalacija.. Valjda update pa restart PC. Quote Share this post Link to post Share on other sites
