boki01 30 Posted May 20, 2019 Kupujem plastičnu zaštitu ispod motora, tzv. šus pleh za Punto 2/3 i Zastavu 10 (isti su). Može i delimično oštećen ili napukao. Quote Share this post Link to post Share on other sites
nole@ 2 Posted May 21, 2019 Imam ja... skinut sa auta pre dve godine i više nije vraćan...popodne da ga nađem i uslikam. Quote Share this post Link to post Share on other sites
boki01 30 Posted May 22, 2019 Pošto Nole ne može da nađe, da nema neko drugi? Quote Share this post Link to post Share on other sites
boki01 30 Posted June 5, 2019 Kupljen nov, neki Tajwanski. Tema više nije aktuelna. Sad ga treba ugraditi. Problem su one 3 rupe napred i dve pozadi na mostu. Quote Share this post Link to post Share on other sites
zeljkoci 58 Posted June 6, 2019 A sto ti je to problem??? Na tih 5 mesta zavaris po 1 navrtku M6, i posle ti treba samo 5 vijaka i gotovo! Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted June 6, 2019 Ili kulturnije ovako nesto https://www.google.com/search?safe=off&source=hp&ei=Vif0XOi_BvGgrgTmxai4AQ&q=zakivna+matica+m6&oq=&gs_l=mobile-gws-wiz-hp.1.0.35i39l8.0.0..2124...1.0..0.0.0.......0...........8.G7WTFL3cqk4 ako nemas alat moze da se postavi i uz pomoc srafa, matice i podloske, ima yt snimaka verovatno kako postaviti..... Sent from my LYA-L29 using Tapatalk 1 pedjabj reacted to this Quote Share this post Link to post Share on other sites
shuxx 10798 Posted June 6, 2019 (edited) @boki01i mene interesuje nabavka, gde si kupio, koja cena u vašem kraju, loznica šabac, ima dosta autoplačeva sa fiatovim programom, ja ovde u Nišu i okolini nisam mogao da nađem.... Edited June 6, 2019 by shuxx Quote Share this post Link to post Share on other sites
darkman14 5898 Posted June 6, 2019 @shuxx ima gbg lukas. pogledaj za kontakt. A mozes i ovde preko foruma kontaktirati auto miku. mislim da sam preko njih nasao nov. Mislim da cena ide oko 30 eur, uglavnom su toliko Quote Share this post Link to post Share on other sites
shuxx 10798 Posted June 6, 2019 nova u kitkomercu je 3600 din, ja bi radije polovnu, cca 20 eur... ako može... Quote Share this post Link to post Share on other sites
darkman14 5898 Posted June 6, 2019 Moze, ali ti uglavnom budu malo iskrivljeni. Kada sam gledao za sebe, polovan nijedan valjan nisam nasao, a razlika u 10 evra mi nije cinila toliko koliko je manje zezanja sa uklapanjem iskrivljenog suspleha. Quote Share this post Link to post Share on other sites
shuxx 10798 Posted June 6, 2019 ma znam da ne znače 10 e, ali čisto psihički.... Quote Share this post Link to post Share on other sites
boki01 30 Posted June 14, 2019 (edited) Ja to baš večeras rešio malo elegantnije. U onih 5 rupa sam ubacio 5 tiplova tipa lasta. Ekstra se uklopilo osim što sam morao da svaki od tiplova malo stanjim sa nožem. Tiplovi su 10 mm, a rupe 9 mm. U njih se sad uvrću obični holšrafi sa podloškama. Nema varenja i budženja, a jedan tipl 7-9 din. Inače plastičnu zaštitu motora kupio preko KP-a od neke firme iz Zaječara. 2400 din + poštarina. Solidan kvalitet. Edited June 14, 2019 by boki01 Quote Share this post Link to post Share on other sites
zeljkoci 58 Posted June 14, 2019 Boki, smatram da ces imati problem. - truckanjem automobila po putevima, vremenom ce tiplovi izgubiti kontakt sa susplehom i onda karambol - kod vecih brzina javljaju se velika vrtlozenja u zoni suspleha, tako da tvoj tipl nema dovoljnu silu da zadrzi suspleh da se ne odvoji od sasije. - najbolja je vijcana veza, i da ne mislis da li ce nesto da odleti po autoputu ili magistrali. Samim tim, mozes i da izazoves neku nesrecu 1 pedjabj reacted to this Quote Share this post Link to post Share on other sites
shuxx 10798 Posted July 1, 2019 boki, postavi taj link za oglas, koliko je poštarina, s obzirom na gabarite .... Quote Share this post Link to post Share on other sites
pedjabj 16 Posted July 2, 2019 @Kuvaljavam dao savet nad savetima i vi opet nesto budzite. Poslusajte malo, procenite sta je sigurnije i ne gledajte, mada je takvo vreme, samo kroz prizmu manjih izdataka. Koristite zakivnu maticu ili zakivnu navrtku (postoji alat za nju koji je i dalje skup), i mozete je sami namestiti. Evo linka : Quote Share this post Link to post Share on other sites
