veljasabac 0 Posted May 6, 2019 (edited) fiat punto 1.6 sporting problem verovatno sa kompijuterom, moze li zamena od nkog drugog ili mora orginalni? Edited May 6, 2019 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted May 6, 2019 @Duki 91 je imao dugo, ili još uvek ima Punta sa tim motorom, lepo održavan, možda ima info više... Quote Share this post Link to post Share on other sites
Duki 91 34 Posted May 7, 2019 (edited) Ako se dobro secam jedino je u Punta 1.6 isao GM-ov ECU,u 1.1 i 1.2 motore je ugradjivan Magneti Marelli,dok je kod 1.4 gt ugradjivan Bosch ECU,naravno sve se odnosi na Punta mk1. Edited May 7, 2019 by Duki 91 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
veljasabac 0 Posted May 7, 2019 (edited) @Duki 91 hvala,i kod mene je ecu GM na koja auta jos se ugradjuje gm Edited May 7, 2019 by neshaoct tag Quote Share this post Link to post Share on other sites
Duki 91 34 Posted May 8, 2019 (edited) Nema na cemu.Mislim da je isao u corsu i astru.Evo link ako moze da pomogne: https://www.fiatforum.com/punto/13647-punto-1-6-8v-ecu-fault-codes.html Edited May 8, 2019 by Duki 91 Quote Share this post Link to post Share on other sites
