miljanxXx 26 Posted April 27, 2019 (edited) Konstantno prijavljuje ovu gresku Nekad je obrise i odmah prijavi, a nekad nece U pitanju je motor sa celom alu granom Edited April 27, 2019 by neshaoct tehnički edit Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted April 27, 2019 @miljanxXx Self-adaptability The control unit features a self-adaptive function able to memorise deviations between basic maps and corrections imposed by the lambda probe that occur persistently during operation. Such deviations (due to system and engine component ageing) are saved permanently so that system operation can be adapted to gradual changes in engine and components with regard to original specifications. The corrections are NOT lost even when the batter or control unit is disconnected The strategy is de-activated while the carbon filter flushing solenoid is open. If the ECU is replaced, it is advisable to leave the engine to idle for a few minutes until warm to allow the ECU to store the correction again. Corrections at higher speeds are stored under normal driving conditions. The control unit is also equipped with a self-adaptive function which corrects idle speed actuator opening when idling on the basis of changes due to throttle body leaks or natural engine ageing. This specific correction is lost by disconnecting the battery or control unit. Baci pogled na ovu tehničku dokumentaciju, strana 139, možeš pogledati i strane pre i posle nje da vidiš celinu: https://www.fiat-lancia.org.rs/Manuals/other/Marea/ServiceManual98-99.pdf Quote Share this post Link to post Share on other sites
miljanxXx 26 Posted April 28, 2019 Hvala,izgleda sonda pravi problem Usporeno radi i pravi problem pa prijavljuje to... 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted April 28, 2019 @miljanxXx Da, ima logike sa napisanim u dokumentaciji. Barem to ne bi trebalo biti skupo za rešiti... Quote Share this post Link to post Share on other sites
miljanxXx 26 Posted May 2, 2019 Jos jedno pitanje Map senzor prijavljuje preko dijagnostike ~300 A uredjajem mereno na usisnoj grani ~700 u minusu na leru Zakucao map senzor ili ili ? Quote Share this post Link to post Share on other sites
Memphis 15 Posted June 25, 2019 Jel si uspio riješit ovaj problem? Quote Share this post Link to post Share on other sites
