MiloshBg 1020 Posted July 21, 2022 12 hours ago, Jim9 said: Selenije 5w-30 PE više nema nigde. Na koje ulje preći? U ovlascenim mozes naci ako je zaostalo na stanju. Secam se da je to ulje bas slabo prodavano. Ne znam odakle si, ali verujem da ima par litara u AKK u Rakovici, ja sam ga drzao na stanju uvek iako sam prodavao svega nekoliko litara godisnje. Uostalom ako ga ni tamo nema, kupi Sintium u toj gradaciji u Slodesu. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Jim9 85 Posted July 21, 2022 Ima u ovlašćenom 1500 litar. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Ivanaksentijevic 31 Posted July 21, 2022 (edited) @Jim9 Za koji je ovo motor? Zar u 1.4 ne ide 5w-40 KPE selena? Edited July 21, 2022 by neshaoct dodao tag 2 neshaoct and Ivan reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 21, 2022 @Jim9 Kao što reče @Ivanaksentijevic, ide SAE 5W-40 Selenia K P.E. Vlasničko uputstvo Fiat Nuova Tipo Quote Share this post Link to post Share on other sites
Ivan 17670 Posted July 21, 2022 (edited) 28 minutes ago, Jim9 said: 5wr30 PE ide WR PE (Pure Energy) 5-30 je obicno islo u starije dizelase sa DPF? Novije je ono WR Forward. Za 1.4 benzince je valjda preporuka K PE 5-40 ili bilo koje da ispunjava Fiatov 9.55535 S2. Upravo i ja htedoh da pitam koji je motor u pitanju? Ne znam odakle uopste izvuce WR PE , ako je benzinac u pitanju. Edited July 21, 2022 by Ivan Quote Share this post Link to post Share on other sites
Jim9 85 Posted July 21, 2022 Uzela žena, izgleda sam se prebacio. Zameniću sutra Quote Share this post Link to post Share on other sites
Ivan 17670 Posted July 21, 2022 U Maxiju ili ... ? Quote Share this post Link to post Share on other sites
Jim9 85 Posted July 21, 2022 U Kit Komerc-u.Slikao joj i ona pokazala. Nažalost, omašio sam. Ne znam zašto sam se prebacio da je 5-30. Sad moram da je namolim da ide da zameni. Rade do 16h pa ne stižem zbog posla. Quote Share this post Link to post Share on other sites
MiloshBg 1020 Posted July 21, 2022 (edited) Mislim da je politika da ne menjaju ulja... Srecno! Edited July 21, 2022 by MiloshBg Quote Share this post Link to post Share on other sites
Jim9 85 Posted July 21, 2022 Zamenili su. 3 stex_pb, knezevic76 and MiloshBg reacted to this Quote Share this post Link to post Share on other sites
Zakeralo 126 Posted August 6, 2022 Da se i ja malo oglasim oko potrošnje, kod mene se ustalila na 0,2l na 1000 km. Razlika na između oznaka na šipci je definitivno 0,5 l. E sad što je taj podatak brisan iz uputstva za upotrebu je svinjarija posebne vrste, Ako se konsultuju stara uputstva i postupa se po njima postoji rizik da u motoru ima povremeno određeni višak ulja, veći ili manji ali višak, ili da se stalno visi pod haubom i doliva po malo. Žabari, šta ćeš. Obrni okreni teorijski ovaj motor tokom redovnog servisnog intervala od 15000 km praktično zameni svoje komplet ulje. Quote Share this post Link to post Share on other sites
nesa 169 348 Posted August 6, 2022 (edited) Ja u uputstvu nisam našao podatak koliki je razmak između minimuma i maksimuma, ali mi je prodavac rekao da je pola litra, tako da pazim ako budem dosipavao da ne bih preterao. Inače posle prvih 1300 km nije izgubio ništa, ali to je naravno još suviše malo da bih imao definitivan zaključak. Kontrolišem svaki dan kao što sam radio i na svim prethodnim automobilima. Jedino mogu da preskočim kad pada kiša jer nemam garažu, ali ovih dana nije bilo padavina. Takođe mi je kod dilera jasno naglašeno da izbegavam vožnju s visokim obrtajima jer to povećava potrošnju ulja. Edited August 6, 2022 by nesa 169 1 Zakeralo reacted to this Quote Share this post Link to post Share on other sites
Home 56 Posted August 6, 2022 Potrosnja definitivno ima veze i sa vrstom ulja...Menu najmanje trosi MOTUL ulje okacio sam sliku ranije....Bukvalno na predjenih 5000 km 300-400gr...duplo manje od ravenola VMO Ili trodiplo manje of LM 4100...Jos mi pusta ulje na srafu za ispustanje na karteru...za sada na prvom mestu. Kada vec pisem original rikambi filteri (pravi clean) be drze ulje vec ispustaju svaki put lampica za ulje sporije gasi I ventili zvece dok se ne napune kanali...Ponekad je bolji AM nego OEM. 1 Zakeralo reacted to this Quote Share this post Link to post Share on other sites
Zakeralo 126 Posted August 6, 2022 (edited) @nesa 169 E dobro da su ti rekli i podatak za šipku. Meni su svojevremeno samo rekli da troši i da se mora kontrolisati pa je bilo nedoumica i dovijanja. Da te služi sa srećom a i još je u periodu razrade, pa videćeš kasnije. Inače jedno zapažanje koje je pomalo subjektivno. Ima izgleda nešto i do isparljivosti ulja. Tokom kasne jeseni i zime do sevisa dok je u motoru bila Selenia, značajno je bila pala potrošnja ulja, oko 0,1 l na 1000 km. Videćemo ove zime kako će se motor ponašati sa Šelovim uljem. Edited August 6, 2022 by Zakeralo Quote Share this post Link to post Share on other sites
Ivanaksentijevic 31 Posted August 7, 2022 Ok,koje Motul ulje? Quote Share this post Link to post Share on other sites
Ivanaksentijevic 31 Posted August 7, 2022 Hvala puno 1 Home reacted to this Quote Share this post Link to post Share on other sites
nesa 169 348 Posted August 7, 2022 8 hours ago, Zakeralo said: @nesa 169 E dobro da su ti rekli i podatak za šipku. Meni su svojevremeno samo rekli da troši i da se mora kontrolisati pa je bilo nedoumica i dovijanja. Da te služi sa srećom a i još je u periodu razrade, pa videćeš kasnije. Inače jedno zapažanje koje je pomalo subjektivno. Ima izgleda nešto i do isparljivosti ulja. Tokom kasne jeseni i zime do sevisa dok je u motoru bila Selenia, značajno je bila pala potrošnja ulja, oko 0,1 l na 1000 km. Videćemo ove zime kako će se motor ponašati sa Šelovim uljem. Meni rekoše da je sad u njemu Selenia, pa ću svakako do zamene dodavati to ako bude trebalo. Ionako iskustvo ovde na forumu, a i kolega napolju govori da je sa Seleniom manja potrošnja ulja. Pre neki dan sam pričao sa kolegom koji je prešao oko 220 hiljada. Kaže da na 10 hiljada Seleniu dospe litar, a da je Shell morao 2 do 3. S druge strane ovi u Stojanovu kod mene forsiraju Shell i tu ćemo se razići. Inače svaki auto mi je obavezno zimi trošio manje ulja, što je i normalno. Quote Share this post Link to post Share on other sites
neshtry 14851 Posted August 7, 2022 Svako ulje je bolje od Selenia,zato ga u većini ovlaštenih i ne sipaju.Imaš temu za ulja pa pročitaj Quote Share this post Link to post Share on other sites
MiloshBg 1020 Posted August 7, 2022 Nije tacno! Sipaju ono sto imaju u buricima/bacvama, a to je Shell i Valvoline. Svaki servis ima selenia ulje na stanju. Selenia je odlicno ulje. 2 knezevic76 and Markoni Bg reacted to this Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted August 7, 2022 Mislim da su nijanse u pitanju u potrosnji ulja kod ovog motora , nisam eksperimentisao sa uljima ali u ovaj moj 1.4 16V ide 20k 10W40 tih godina kada je proizveden to je bilo preporuceno , potrosnja je na 1000km malo jace od 100-150ml tu negde ne mogu precizno da odmerim , a ne stedim ga na gasu ni malo. Quote Share this post Link to post Share on other sites
knezevic76 7018 Posted August 7, 2022 Svako ulje je bolje od Selenia,zato ga u većini ovlaštenih i ne sipaju.Imaš temu za ulja pa pročitajNa osnovu čega si ovo zaključio? Quote Share this post Link to post Share on other sites
neshtry 14851 Posted August 7, 2022 52 minutes ago, knezevic76 said: 4 hours ago, neshtry said: Svako ulje je bolje od Selenia,zato ga u većini ovlaštenih i ne sipaju.Imaš temu za ulja pa pročitaj Na osnovu čega si ovo zaključio? na osnovu što sam proverio zadnjih deserak godina,a kako drugačije…. Quote Share this post Link to post Share on other sites
nesa 169 348 Posted August 7, 2022 Mislim da je logično da sipam ono što je i trenutno u njemu, a posle zamene planiram ovo: Full sintetika za plin, pošto ću ga tad već imati. Quote Share this post Link to post Share on other sites
