Boris90 367 Posted May 22, 2019 Bas dobro odradjeno 1 neshtry reacted to this Share this post Link to post Share on other sites
shomispc 832 Posted May 22, 2019 ekstra izgleda I preglasno je za 120ks, kad ga poteras na 150 bice taman 2 horvat and neshtry reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 22, 2019 Slobodno napiši broj ovde na temi, ako imaš i link na PA ka njemu, daj sveee trebaće ljudima kontakt... https://www.polovniautomobili.com/auto-delovi/5015780/lajsne-za-pragove Evo ga oglas, sa vazecim brojem telefona Sent from my iPhone using Tapatalk 1 neshtry reacted to this Share this post Link to post Share on other sites
Milutinac 5906 Posted May 23, 2019 Izgled - fabrika a prelepo. Ceo zadnji kraj dobije na ozbiljnosti. Ala ga je odradio Pirke, svaka mu cast... 1 horvat reacted to this Share this post Link to post Share on other sites
dekirs 4819 Posted May 23, 2019 Fi 100? Krivo seceno. To pi na Sad su ovi moji nastavci previse mali Share this post Link to post Share on other sites
Milutinac 5906 Posted May 23, 2019 122 ili nista. Kao top na tenku 1 horvat reacted to this Share this post Link to post Share on other sites
shomispc 832 Posted May 23, 2019 Da ne znas da l' je djulka ili Panzer Share this post Link to post Share on other sites
shomispc 832 Posted May 23, 2019 Bolje zbog cevi nego zbog potrosnje, fleke od ulja ispod i dima Share this post Link to post Share on other sites
dekirs 4819 Posted May 23, 2019 Najjace je kad se vide vozaci dve Djulke pa cestitaju jedan drugom 1 1 neshtry and horvat reacted to this Share this post Link to post Share on other sites
neshtry 14783 Posted May 23, 2019 Sve imam sliku pred očima Poslato sa POT-LX1 uz pomoć Tapatoka 1 dekirs reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 Da napisem koju rec o citavom procesu. Stigao sam u radionicu malo posle 10h, i izasao sam oko 17h... Ceo proces trajao mnogo duze nego sto sam ocekivao, ali ne zato sto su blejali, nego je objektivno komplikovanije. Nisam bio sad u hiljadu auspuh servisa, pa da zna da uporedim, ali rekao bih da Pirke nije dzabe na doborm glasu. Stvarno se svakom detalju pristupi sa maksimalnom paznjom, sve se trude da odrade lepo, svaki nosac, svaku cevku, svaki prelaz, var, itd itd... Znaju znanje, prijatni su, precizni, nema sta, sve pohvale. Resenje koje je na mom autu je sledece: skinut je zadnji lonac (bila je kopca na tom spoju) i onda su na to stavili svoju cev, koja ide ravno pa se racva na dva zavrsetka, a citava ta racva se nalazi u loncu. Znaci lonac ne trpi nikakve gasove, tamo je samo vizuelno da zamaskira racvu. Prakticno sam izbacio zadnji lonac Srednji i katalizator nisu dirani nista. Cevi su od inoxa, a lonac je od aluminiziranog celika (valjda). Posebno je bilo interesantno gledati kako pravi "levak" sa cevi na zavrsetak fi 100... Ono sta je 'problem' oko cele ove price, je sto je jako tesko pricati o zvukovima. "Hteo bih malo glasnije, ali ne preglasno" <--- sta to znaci? Meni jedno, nekom sasvim nesto drugo... Moglo bi se to mozda metrifikovati u dB, ali mislim da to ne govori dovoljno, pa je suvisno trositi vreme. Licno mislim da sam malo preterao sa zvukom. Kad su skinuli lonac, radnik je upalio auto i zaturirao na oko 3-3.5 hiljade rpm, i pitali su me kako mi se svidja. Kako je auto bio u garazi, svi zvuci sto dolaze iz prednjice su odzvanjali, i meni se cinilo da jedva i da cujem izduv nesto glasnije.... I rekao sam da hocu tako otprilike, i otuda to resenje koje su mi napravili. Da sam rekao hocu tise - napravili bi drugacije. Posle kad sa izasao na AP, sam u kolima, ugasena muzika... druga prica skroz. Ubrzanja u 4. i 5. i 6. su, mogu slobodno reci - neprijatna. Jednostavno, nekad zvuci neprikladno, i pomalo mogu reci i nekulturno... Sad zvuci kao da fantaziram, hteo sam izduv, a sad mi 'neprijatno', ali postoji taj neki balans kojeg smatram dobrim, a ovo je ipak malo preko toga. Ali vozicu jos malo ovako, pa cu videti kako sta. Vizuelno, ne moram da komentarisem, izgled mi je apsolutno savrsen 2 Milutinac and Ivan reacted to this Share this post Link to post Share on other sites
Milutinac 5906 Posted May 23, 2019 Imas srednji lonac i katalizator jos uvek... jedna prerada srednjeg lonca bi mogla modifikovati zvuk... Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 (edited) Da, da, ima svakako vise resenja kako da dodjem do zeljenog zvuka. Jedna je i mozda da izolujem gepek maksimalno koliko mogu Jel ima neko iskustva sa ovim: http://www.sinko-garage.rs/catalog/vibrofiltr-damping-materijali ? Radi li posao? Deluje kao 'easy fix' za ovakve probleme, pogotovo sto najvise neprijatnog zvuka dolazi bas od nazad (logicno) a zadnji deo auta i jeste najtanje izolovan, tako da mi deluje kao sasvim moguce resenje... Edited May 23, 2019 by horvat Share this post Link to post Share on other sites
Milutinac 5906 Posted May 23, 2019 Komplikovanija prica nego da ti neko napravi jedan srednji lonac sa namerom da se sve pre ovog sada poduhvata od juce primiri... Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 Pa moze i srednji, a u sustini, moze i prepravka ovog zadnjeg, tako da ne bude samo fejk oko racve, nego da se napravi da 'radi nesto', kontam da bi ga to instant utisalo? Share this post Link to post Share on other sites
Ivan 17587 Posted May 23, 2019 (edited) Vizuelno izgleda perfektno. "Zvucno", sto kazes je mnogo vise subjektivni dozivljaj... Pretpostavljam da su tvoj lonac kompletno izbacili pa stavljali svoj "oklop" oko racve? Ako nije glupo pitanje, koliko je izasla cela operacija, ostavljas njima svoj auspuh uz doplatu ili kako vec...? Ako jeste, slobodno zaobidji pitanje sa cifrom. Ranije sam vidjao i ovakva resenja za Djulku po netu: Edited May 23, 2019 by Ivan 1 Milutinac reacted to this Share this post Link to post Share on other sites
Milutinac 5906 Posted May 23, 2019 Pitanje da li pored racvanja u zadnjem loncu ima mesta i za tako nesto. Pricamo sad napamet, ali...u svakom slucaju prepravka srednjeg ili zadnjeg... Ili jednostavno Ja ih za HGT nisam nikada koristio. Samo ne cujem na levo uvo...malo 2 horvat and shomispc reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 3 minutes ago, Ivan said: Vizuelno izgleda perfektno. "Zvucno", sto kazes je mnogo vise subjektivni dozivljaj... Pretpostavljam da su tvoj lonac kompletno izbacili pa stavljali svoj "oklop" oko racve? Ako nije glupo pitanje, koliko je izasla cela operacija, ostavljas njima svoj auspuh uz doplatu ili kako vec...? Ako jeste, slobodno zaobidji pitanje sa cifrom. Ranije sam vidjao i ovakva resenja za Djulku po netu, pretpostavljam malo tisa: Nije tajna - 170e sve komplet, delovi, ruke. A sve sto je skinuto sa auta - eno u gepeku, ostaje meni. Na ovo treba dodati i tu crnu plastiku-difuzor. Ona ide po otpadima oko 60-70e, ja sam kupio novu u gbg-lucas za oko 9 'iljada rsd sa dostavom. Da, resenje je tako kako si opisao. Oklop oko racve je prakticno lonac (koji ne radi nista, nema gasova u njemu). Sto se zvuka tice, vozicu sad ovako kako jeste, pa cu vec nadoci na pravo resenje Izgled ne menjam, samo cu videti sa tim loncima i serpama, sta da uradim, da ne moram da se izvinjavam putnicima kad raspalim po gasu 1 Ivan reacted to this Share this post Link to post Share on other sites
MS PK 7728 Posted May 23, 2019 Jel, da te pitam, gde peres ova kola odozdo? Послато са SM-J330F уз помоћ Тапатока 2 Milutinac and horvat reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 Ovaj crven nije moj, to je Ivan negde sa neta okacio Share this post Link to post Share on other sites
MS PK 7728 Posted May 23, 2019 Znam ja koji je tvoj Послато са SM-J330F уз помоћ Тапатока 1 neshtry reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 23, 2019 Aha, ok onda Pa nista, rucna praona, zalegnem i prscem. Svaki put ja to radim, i ne samo zadnji deo, nego i sa strane, oko prednjih tockova itd... Zapoceo sam tu praksu zimi, ali navukao sam se, i sad stalno tako perem. Malo je to i bolest, ne bih preporucio ovako 1 shomispc reacted to this Share this post Link to post Share on other sites
horvat 6456 Posted May 28, 2019 Zanemarite malo zakrivljen video u pocetku, nisam bas vest sa video-editorima 5 shomispc, Milutinac, neshaoct and 2 others reacted to this Share this post Link to post Share on other sites
