VladoAssassin 0 Posted November 29, 2018 Kad se vozim ujutro kad je hladno u drugu nece da udje, tek kad se zagrije malo onda ulazi, u cemu je kvaka Mk2 Sporting 16v Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 29, 2018 Sajle trebaju da se promene ili razrade, a mozda je samo i do ulja u menjacu Quote Share this post Link to post Share on other sites
shomispc 832 Posted November 29, 2018 (edited) Zameni ulje, to je najjeftinija opcija a pomoci ce sigurno (samo pitanje u kojoj meri). Verovatno ulje nije menjano dugo pa se razredilo a onda kada je hladno se stegne vise nego sto je normlano. Ako nastavi da pruza otpor -> provera sajli ko sto rece kolega gore.. Edited November 29, 2018 by shomispc Quote Share this post Link to post Share on other sites
rage_man 130 Posted November 29, 2018 Kod mene ista fora samo sa 1.brzinom, navikne covek Quote Share this post Link to post Share on other sites
VladoAssassin 0 Posted November 29, 2018 Budem probao to sa uljem, jeftinije je U svakom slucaju hvala Quote Share this post Link to post Share on other sites
shomispc 832 Posted November 29, 2018 i kod mene jebe prva, od kada sam menjao ulje je lakse ali i dalje odbija saradnju, tako da.... Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 29, 2018 Uvek ili nece dok ne stanes u mestu? Quote Share this post Link to post Share on other sites
VladoAssassin 0 Posted November 29, 2018 U mjestu hoce, uglavnom u voznji, ajmo rec 30% nece a 70% hoce ali tih 70% jedva udje, ne ide glatko, jbg ne znam kako da opisem bolje, uglavnom nije to to kako treba mjenjac raditi Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 29, 2018 Mislio sam kad polazis iz mesta, ubacis bez problema i krenes a recimo u voznji kad ides sporo pa hoces iz druge u prvu, tada nece dok ne stanes? Quote Share this post Link to post Share on other sites
rage_man 130 Posted November 29, 2018 Ja sam provalio da iz neutrala lakse upadne u prvu nego iz druge u prvu, biiip li ga kakve to ima veze Quote Share this post Link to post Share on other sites
VladoAssassin 0 Posted November 29, 2018 Ma ni prva mi nije bas nesto, upali se zeleno, ja hocu u prvu nece, hocu opet nece, i onda moram u ler stavit pa onda u prvu, a iza mene vec lud vozac, haha, strasno Quote Share this post Link to post Share on other sites
Flex 1778 Posted November 29, 2018 Kod mene retko kad hoce u pokretu da vrati u prvu, tek kad stanem skoro skroz. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted November 29, 2018 @VladoAssassin Baci pogled i na ovu temu: https://www.fiat-lancia.org.rs/forum/index.php?/topic/38752-fiat-punto-mk2-problem-sa-menjačem-ispada-iz-brzine-teško-ide-u-brzine/ Quote Share this post Link to post Share on other sites
VladoAssassin 0 Posted November 29, 2018 Gledao, svega tu ima Quote Share this post Link to post Share on other sites
vzr 34 Posted November 30, 2018 18 hours ago, VladoAssassin said: U mjestu hoce, uglavnom u voznji Iz ovga zakljucujem da nisu sajle vec sinhron te brzine koja ti pravi probleme. Mala i jeftina stvar ali izuzetno nezgodna za zamenu jer moras skidati menjac i rastavljati ga u parame i parcadi, i uz to menjati dihtunge, ulje, semeringe... Quote Share this post Link to post Share on other sites
