MS PK 7732 Posted October 15, 2018 Original polovan od drugara Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 15, 2018 Ne traktorise vise? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 15, 2018 Jok, nit poskoci kad se pali nit kad se gasi. Tablica zadnja se ne cuje a na volanu nema vibracija Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 15, 2018 Odlicno. Moracu da odradim to sto pre. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 15, 2018 Samo kupi original nov ili neku oroverenu varijantu ovako kao ja. Ne bih ti savetovao neke leve marke Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 15, 2018 Original ce i biti, ne menja se to svaki dan. Mozda sam se zeznuo za one donje sa Akronom ali jbg sad. Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 17, 2018 Opremili smo tablice ledovima, konacno. Quote Share this post Link to post Share on other sites
Flex 1778 Posted November 15, 2018 Odradih danas, konacno, i nosac ispod akumulatora. Auto se preporodio, neuporedivo mirniji. Takodje zamenjeno i kociono ulje i stavljena zimska varijanta. Nadamo se da nece biti nekih vecih ulaganja skorije. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted November 15, 2018 Koji si uzeo na kraju? Quote Share this post Link to post Share on other sites
Flex 1778 Posted November 16, 2018 Original, kod Bogunovica. 6100 dinara, smirio se dosta. Prvo sam montirao neki polovan i pritom mi je "majstor" napravio problem sa ocajnom obradom onog dela sto ide preko nosaca pa je treslo kao da ce da se raspadne. Obradjeno sve ponovo, duzi sraf i sad je ok. Quote Share this post Link to post Share on other sites
Flex 1778 Posted November 28, 2018 Juce smo isli malo do Kragujevca na ovaj zimski pregled u Nikomauto. Vrlo profesionalno i ljubazno, iznenadih se. Na prijemu veoma ljubazan momak odradio nalog, pregledao auto spolja (da vidi ima li ostecenja), uzeo broj telefona i ubacio auto u radionicu. Uputio me na kafic na spratu u kome je, opet iznenadjenje, pice bilo besplatno. Posle sat vremena dobio poziv da mogu doci po auto. Na moje veliko zadovoljstvo nema nikakvih problema. Napomenuto mi je da odradim proveru plocica za 4-5000km i to je to. Mala zamerka ide na to sto nema detaljnijeg izvestaja i voleo bih da sam bio prisutan prilikom pregleda. Ali eto, sta da se radi. Sve u svemu, konacno jedno pozitivno iskustvo sa nekim servisom. P. S. Razmisljao sam da li da idem juce ili danas, ali dobro je sto nisam sacekao. Sneg od sinoc ne prestaje, vreme ocajno. Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 2, 2018 Dobio Stilo i stikere. Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 14, 2018 Ugradih sinoc i multimediju pa da napisem koju ako jos neko bude planirao da ubacuje. U pitanju je PolarLander 8702 7". Android multimedija sa wifi, bluetooth, gps, usb, micro sd. Displej je klasican TFT sa solidnom osetljivoscu (nema preskakanja ni fantomskih dodira). Sam interfejs je veoma prost i intuitivan (sve je tamo gde se i ocekuje da bude) i za 2 minuta se sve podesi. Moze se sinhronizovati kompletan imenik sa telefona i obavljati razgovor preko ugradjenog mikrofona. Kvalitet zvuka je veoma dobar i cist (nema krckanja, puckanja i ostalih gluposti). Reprodukcija sa fles memorije ide bez ikakvih problema i seckanja. Probao sam i par spotova u 1080, ide skroz tecno. Od zamerki imam sto se pojavljuje "image retention" ako je duze staticna slika (posle se izgubi) i nesto neprecizniji potenciometar. Sto se tice ugradnje, potrebno je izvaditi radio i njegov kavez (sa njim sam imao malo problema, nisam znao da se lomi plastika po sredini) i to je sve. Namesti se druga blenda, zasrafi sa 2 srafa i to je to. Evo par slicica : 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted December 15, 2018 Ova kao mesta za dugmiće (na blendi, sa obe strane), ne mogu da se iskoriste kod ove aftermarket navigacije...ili ustvari to i nisu mesta za dugmiće nego samo kriju mesto za skidanje blende? Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 15, 2018 Ako mislis na ove 2 pokrivene cepovima, nema tu dugmica. Tu idu srafovi kojima se fiksira. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 16, 2018 Malo gimnastike. Quote Share this post Link to post Share on other sites
neshtry 14833 Posted December 16, 2018 Mnogo gimnastike (za moje godine) i jedan stari deda pas Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 16, 2018 Ti si ga detaljnije odradio. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 17, 2018 Drugari, imam jedan problemcic sa haubom. Kad je dosta hladno motor standardno malo bucnije radi. E sad, problem je sto hauba dosta vibrira i pravi buku. Kad pritisnem promeni zvuk (smiri se) ali posle opet drnda. Ima li neko stelovanje za haubu uopste? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2018 I meni vibrira u gornjem delu ali to je samo do nosaca Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 17, 2018 Vibrira u gornjem delu, ali drnda dosta spolja (dok se ne smiri motor malo). Kad podignem haubu sve ok. A i menjao sam skoro nosac ispod akumulatora majku mu. Primetio sam da mi se osecaju vibraciji i na naslonu za ruku. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2018 Super, jos 3 nosaca i to ie to Quote Share this post Link to post Share on other sites
Flex 1778 Posted December 17, 2018 2 donja sam menjao pre 3 meseca. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2018 Eto, jos dva gornja i gotovo 1 bit reacted to this Quote Share this post Link to post Share on other sites
