Flex 1778 Posted May 2, 2019 Pa i trazio sam mu da budu fabrika, nisam pravio pitanje oko cene uopste. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 2, 2019 Ako iole poznatiji farbar.Onda svaka mu cast,pokazao je znanje. Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 2, 2019 Ispravice ove gluposti kako zna i ume, ali smo svakako zavrsili sa saradnjom. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 3, 2019 Pogledah situaciju na kanalu. Pusta ulje na meracu na gumici sa donje strane i creva od turbine su prilicno mokra (verovatno sa njih iscurelo na pleh) i gore na spoju debelog creva sa motorom izgleda pusta. Cekam Gorana da potvrdi kad moze pa da resavamo. Sent from my SM-G950F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 3, 2019 Precesljaj creva turbine,sam vidi dal su pri kraju.Npr meni na bmw donje nije imalo da kaplje sa njega,ali izgleda porozno i resio da ga zamenim.Kada sam ga zamenio ,naravno crevo vise nije bilo porozno,al je auto bio agresivnije na gasu malo,al osetno ipak Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 6, 2019 Zakazano kod[mention=947]Goran Zemun[/mention] za sledeci cetvrtak. Pa da resimo konacno sve. Sent from my SM-G950F using Tapatalk 4 Djuk85, alfini0507, bit and 1 other reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 12, 2019 Drugari, je l' se i kod vas oseti dosta na snazi kad se ukljuci klima? Bez klime je osetno jaci, mnogo lakse ubrzava. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 12, 2019 NeПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 12, 2019 Hvala Mico. Provericu i to kod Gorana. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 12, 2019 Pozovi se na mene samoПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 12, 2019 Obavezno. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 12, 2019 Kad su velike vrucine,na libri sam osetio gubitak 10-15% snage. Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 12, 2019 Pa tako nekako, treba malo vise gasa i nece onako jako i odmah da krene da ubrzava. A mozda je i samo navika da dajem mali gas. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 12, 2019 Pa neka nijansa moze da se primeti, nije ono 100% isto ali nije ni da se primeti gubitak snage da losije vuce , losije radi u leru i slПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 17, 2019 Zavrseno sve kod Gorana. Toliko su se ljudi namucili da je to strasno. Pa da pocnem. Stigao auto u servis, ubrzo zove Natasa i kaze ne valja poluosovina. Rekoh veselo i menjaj. Zamenjena poluosovina, doslo na red crevo usisa (ono sto je pustalo ulje kod klapne i kapalo svuda redom). Zamenjeno i to. Klapna nije uvek zatvarala pa je drmalo kad gasim povremeno (i to su resili). Dolazim u servis i Goran utvrdjuje da sajle rucne ne valjaju (zadnji levi tocak blago blokirao). Zamenismo sajle pa da se pogleda sto trese u leru. Zakacimo dijagnostiku i ne cita parametre protokomera i brlja egr. Skinuse egr i vidimo da je blokiran nekim pretankim limom. Odrade ponovo blokiranje (deblji lim) i opet dijagnostika i opet protokomer zeza. Preflesovali kompjuter i sve ok (neko cackao nesto oko mape nekad). I krece igranka oko drmanja volana u leru. Momci su skidali sva 4 nosaca i montirali nove, utvrdjeno da auspuh drma kod pletenice (opet neki strucnjak jebavao nekad). Otkacise auspuh i opet drma. I na kraju pregledase volan iznutra i utvrdise da je ugradjen zeder (za koji niti sam znao niti imam kljuc) pa odmah rasturise sve i prepakovase na njihov deo (nemam pojma kako se zove) i namontirase nazad. Smirio se konacno volan. U medjuvremenu Goran zamenio i metlicu zadnjeg brisaca jer je brljala. I tako ti ja zadrzao sve njih do 20h u servisu. Krecem, prva krivina i "engine failure" i gas ne prima. Parkiram, Goran odmah vraca auto u servis i resava problem (senzor pedale gasa zabrljavio). Tada je vec bilo skoro 20:30h. Ovakav odnos i profesionalnost nisam nigde doziveo, a Goran je totalni kralj. Plus me je castio ruckom i vecerom i sve ono (i preko toga) sto je ponudio skoro ovde. Sve u svemu, mislim da je ljudima dobro zapao danasnji dan i moj Stilo. Sent from my SM-G950F using Tapatalk 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 17, 2019 E to je pravi majstor.Cim se zadesio problem ,odmah resava,a ne kao neki,e znas doteraj sutra naredicemo. Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 17, 2019 Mislio sam da ovakva profesionalnost ne postoji, da ne poverujes. Covek nije hteo da pusti auto iz servisa dok ne potvrdi 100% zasto trese i dok ne resi svaku sitnicu na koju sam se pozalio. Cak mi je rekao da ga obavezno pozovem kad dodjem u KS da vidi da li je potpuno nestalo tresenje na vecim brzinama. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted May 17, 2019 Svaka čast za majstora. Malo je takvih ljudi... Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 17, 2019 Odlicno. Jesi li miran sad? Послато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 17, 2019 Nikad ja necu biti miran. Sent from my SM-G950F using Tapatalk 1 Nikola 1.6 reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 17, 2019 Znaci dzaba... Послато са SM-J330F уз помоћ Тапатока 1 bit reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 18, 2019 I na novom bih nasao nesto da me jede. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 18, 2019 De kupi dobru biciklu 1 bit reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 18, 2019 Pa da mota pedale do Bg na servis?Послато са SM-J330F уз помоћ Тапатока 3 1 Djuk85, alfini0507, Flex and 1 other reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted May 19, 2019 @danijel55, ne bih nesto uzimao bmw-a bas. Taman bih nabio ozbiljnu kondiciju. Sent from my SM-G950F using Tapatalk 1 danijel55 reacted to this Quote Share this post Link to post Share on other sites
